A6 Sounddiver Adaptation ?
Page 1 of 1 [10 Posts]
elhardt
PostPosted: Thu Feb 16, 2006 9:53 am    Post subject: A6 Sounddiver Adaptation ? Reply with quote  Mark this post and the followings unread
I just installed Sounddiver 3.0 and it doesn't have an A6 adaptation. There are some later updates to Sounddiver, I think up to 3.0.4 or 3.1. I can't remember if they came before or after the A6 hit the market.
My question is, does anybody know if the latest version of Sounddiver supported the A6 ? If there is an A6 adaptation, do you know where I can download it from ?
Thanks for any info.
-Elhardt
seraph
Editor
Editor
Audio files: 33
PostPosted: Thu Feb 16, 2006 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you are using OSX you are out of luck because SoundDiver simply doesn't work (never mind the lack of an adaptation) and Apple is not interested in developing it.
elhardt
PostPosted: Thu Feb 16, 2006 11:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm not running OSX. I have Sounddiver on OS9 and Windows. I don't necessary need a later version than 3.0. But if a later version included A6 adaptation files, I would just need those additional files.
It seemed like the A6 came out quite some time before emagic was bought by Apple. But upon spending more time surfing the net, I haven't found an A6 adaptation. I did however find that there is a Sounddiver yahoo group. So I'm going to join that. If anybody knows, they should.
Thanks,
-Elhardt
klangumsetzer
Audio files: 37
PostPosted: Fri Feb 17, 2006 12:23 am    Post subject:   Reply with quote  Mark this post and the followings unread
i'm using sounddiver with logic audio gold 5.5.1 under xp - works fine.
there was an update to 3.0.5.2 (win) and a public beta for os x (3.1.0) on the emagic support site which seems to have gone... Shocked
the public beta can be downloaded at: http://download.info.apple.com/Apple_Support_Area/emagic/Legacy_SW/OS%20X%20SW/
that's the place. the a6 adaptation can be found in the files section/sound diver library/mixed library.
best regards
eike
elhardt
PostPosted: Fri Feb 17, 2006 1:13 am    Post subject: Reply with quote  Mark this post and the followings unread
noodulator writes:
>>that's the place. the a6 adaptation can be found in the files section/sound diver library/mixed library<<
I just joined that site and decided to check the files section. Yes, there is a folder that says there's an A6 adaptation, but when I go there, it says the folder is empty. Everything seems just slightly out of reach.
Thanks,
-Elhardt
klangumsetzer
Audio files: 37
PostPosted: Fri Feb 17, 2006 5:55 am    Post subject: Reply with quote  Mark this post and the followings unread
elhardt wrote:
(...) I just joined that site and decided to check the files section. Yes, there is a folder that says there's an A6 adaptation, but when I go there, it says the folder is empty. Everything seems just slightly out of reach.
ok, try here:
best regards
eike
Seraph edited your post to make it look better Smile
fm_xtk
PostPosted: Tue Dec 12, 2006 5:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I have just installed SD for OS9 on my Powerbook running OS 10.4.8. I did this because the public beta for SD kept crashing when trying to receive the memory contents of the synth.
So far I have only installed the program and checked that it is working. It is working fine in classic, with no trouble accessing any of the computer's MIDI ports. The adaptation that came with SD 3.0.5 seems to be the same one as the one floating around on the internet (creation date 24/05/2002). I will attach it here in case it is of any use to you.
A6 Andromeda.ADA.zip
Alesis A6 Andromeda Sounddiver adaptation, latest version as far as I know.
 Filename:  A6 Andromeda.ADA.zip
 Filesize:  19.89 KB
 Downloaded:  716 Time(s)
elhardt
PostPosted: Sun Dec 17, 2006 12:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks fx_xtk. I had pretty much given up on trying to get an A6 adaptation. The link noodulator provided above was a bad link and yielded nothing. On the Sounddiver forum there was an A6 folder, but it was empty. It was always just out of reach to the point where I didn't believe it even existed.
-Elhardt
darlock
PostPosted: Fri Jun 19, 2009 2:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Can you reupload Alesis A6 Andromeda Sounddiver adaptation?
I unable to download attached file.
Finder
PostPosted: Fri Jul 03, 2009 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
if anyone still needs Alesis A6 Andromeda Sounddiver adaptation and\or latest Sounddiver Beta for windows, send me PM or email fine--art@yandex.ru
