elhardt
Posted: Thu Feb 16, 2006 9:53 am Post subject:
A6 Sounddiver Adaptation ? |
I just installed Sounddiver 3.0 and it doesn't have an A6 adaptation. There are some later updates to Sounddiver, I think up to 3.0.4 or 3.1. I can't remember if they came before or after the A6 hit the market.
My question is, does anybody know if the latest version of Sounddiver supported the A6 ? If there is an A6 adaptation, do you know where I can download it from ?
Thanks for any info.
-Elhardt |
seraph
Editor
Audio files: 33
Posted: Thu Feb 16, 2006 1:35 pm Post subject:
If you are using OSX you are out of luck because SoundDiver simply doesn't work (never mind the lack of an adaptation) and Apple is not interested in developing it. _________________ homepage - blog - forum - youtube
| Quote: | | Don't die with your music still in you - Wayne Dyer |
elhardt
Posted: Thu Feb 16, 2006 11:41 pm Post subject:
I'm not running OSX. I have Sounddiver on OS9 and Windows. I don't necessary need a later version than 3.0. But if a later version included A6 adaptation files, I would just need those additional files.
It seemed like the A6 came out quite some time before emagic was bought by Apple. But upon spending more time surfing the net, I haven't found an A6 adaptation. I did however find that there is a Sounddiver yahoo group. So I'm going to join that. If anybody knows, they should.
Thanks,
-Elhardt |
klangumsetzer
Audio files: 37
Posted: Fri Feb 17, 2006 12:23 am Post subject:
| elhardt wrote: | | I'm not running OSX. I have Sounddiver on OS9 and Windows. I don't necessary need a later version than 3.0. But if a later version included A6 adaptation files, I would just need those additional files. |
i'm using sounddiver with logic audio gold 5.5.1 under xp - works fine.
there was an update to 3.0.5.2 (win) and a public beta for os x (3.1.0) on the emagic support site which seems to have gone...
the public beta can be downloaded at: http://download.info.apple.com/Apple_Support_Area/emagic/Legacy_SW/OS%20X%20SW/
| elhardt wrote: | | It seemed like the A6 came out quite some time before emagic was bought by Apple. But upon spending more time surfing the net, I haven't found an A6 adaptation. I did however find that there is a Sounddiver yahoo group. So I'm going to join that. If anybody knows, they should. |
that's the place. the a6 adaptation can be found in the files section/sound diver library/mixed library.
best regards
eike
elhardt
Posted: Fri Feb 17, 2006 1:13 am Post subject:
noodulator writes:
>>that's the place. the a6 adaptation can be found in the files section/sound diver library/mixed library<<
I just joined that site and decided to check the files section. Yes, there is a folder that says there's an A6 adaptation, but when I go there, it says the folder is empty. Everything seems just slightly out of reach.
Thanks,
-Elhardt |
klangumsetzer
Audio files: 37
Posted: Fri Feb 17, 2006 5:55 am Post subject:
| elhardt wrote: | | (...) I just joined that site and decided to check the files section. Yes, there is a folder that says there's an A6 adaptation, but when I go there, it says the folder is empty. Everything seems just slightly out of reach. |
ok, try here:
best regards
eike
Seraph edited your post to make it look better  |
fm_xtk
elhardt
Posted: Sun Dec 17, 2006 12:01 am Post subject:
Thanks fx_xtk. I had pretty much given up on trying to get an A6 adaptation. The link noodulator provided above was a bad link and yielded nothing. On the Sounddiver forum there was an A6 folder, but it was empty. It was always just out of reach to the point where I didn't believe it even existed.
-Elhardt |
darlock
Posted: Fri Jun 19, 2009 2:36 am Post subject:
Can you reupload Alesis A6 Andromeda Sounddiver adaptation?
I unable to download attached file. |
Finder
Posted: Fri Jul 03, 2009 3:05 pm Post subject:
| darlock wrote: | Can you reupload Alesis A6 Andromeda Sounddiver adaptation?
if anyone still needs Alesis A6 Andromeda Sounddiver adaptation and\or latest Sounddiver Beta for windows, send me PM or email fine--art@yandex.ru |
