Coming up on Radio 1 at
 Forum index » Clavia Nord Modular » Editor programs » Nomad - NM1 Open Source Editor
Nomad MicroModular & Leopard
Page 1 of 1 [9 Posts]
vyedmic
PostPosted: Sat Jan 12, 2008 8:16 pm    Post subject: Nomad MicroModular & Leopard Reply with quote  Mark this post and the followings unread
As you may know OS X Leopard doesn't support Classic applications anymore so Clavia's OS X Editor no longer works. Nomad is the only alternative.
I managed to run it with Mandolane, the Humatic Java Midi Subsystem(MMJ) didn't work for me. I could construct some basic patches and they worked - I could download them into the Micro but upload didn't work at all. Also when I changed any parameter I had to re-download the patch every time although cable connections weren't affected and I could mess with cables as I wanted without re-downloading.
This is not very usable at the time being but I have my faith in this great editor (at least it looks great Wink).
Specs:
Intel Macbook Santa Rosa 2GHz 1GB RAM
Mac OS X Leopard 10.5.1
Edirol UM2-EX MIDI Interface
Nomad 0.2.1
Mandolane MIDI SPI 2.04
These are only first impressions I intend to test it more thoroughly.
Martin
vyedmic
PostPosted: Sun Apr 06, 2008 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Back on the case after couple of months Cool. New Nomad prerelease looks great but when I try to setup connection settings I get this:
Code:
net.sf.nmedit.jsynth.SynthException: Invalid plug MidiPlug[name=Port 1 <MIn>,vendor=EDIROL,description=Midi IN port:1] for net.sf.nmedit.jsynth.midi.MidiPort[name='pc-out',type=TRANSMITTER,plug=MidiPlug[name=null,vendor=null,description=null]].
   at net.sf.nmedit.jsynth.midi.MidiPort.setPlug(MidiPort.java:110)
   at net.sf.nmedit.jsynth.nomad.forms.SynthPropertiesDialog$PortSettingsDialog.applyPortSettings(SynthPropertiesDialog.java:248)
   at net.sf.nmedit.jsynth.nomad.forms.SynthPropertiesDialog$PortSettingsDialog$MyAction.run(SynthPropertiesDialog.java:223)
   at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
   at java.awt.EventQueue.dispatchEvent(EventQueue.java:461)
   at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
   at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
   at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:180)
   at java.awt.Dialog$1.run(Dialog.java:535)
   at java.awt.Dialog$2.run(Dialog.java:563)
   at java.security.AccessController.doPrivileged(Native Method)
   at java.awt.Dialog.show(Dialog.java:561)
   at java.awt.Component.show(Component.java:1302)
   at java.awt.Component.setVisible(Component.java:1255)
   at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm.showSettings(SynthObjectForm.java:1257)
   at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm$2.actionPerformed(SynthObjectForm.java:609)
   at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1882)
   at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2202)
   at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:420)
   at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:258)
   at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:236)
   at java.awt.Component.processMouseEvent(Component.java:5602)
   at javax.swing.JComponent.processMouseEvent(JComponent.java:3135)
   at java.awt.Component.processEvent(Component.java:5367)
   at java.awt.Container.processEvent(Container.java:2010)
   at java.awt.Component.dispatchEventImpl(Component.java:4068)
   at java.awt.Container.dispatchEventImpl(Container.java:2068)
   at java.awt.Component.dispatchEvent(Component.java:3903)
   at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4256)
   at java.awt.LightweightDispatcher.processMouseEvent(Container.java:3936)
   at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3866)
   at java.awt.Container.dispatchEventImpl(Container.java:2054)
   at java.awt.Window.dispatchEventImpl(Window.java:1791)
   at java.awt.EventQueue.dispatchEvent(EventQueue.java:463)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
   at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
Still only Mandolane works for me neither supplied extensions nor mmj show anything in connection settings.
Poster
PostPosted: Mon Apr 07, 2008 1:28 pm    Post subject: Re: Nomad MicroModular & Leopard Reply with quote  Mark this post and the followings unread
Confused erm.. the Clavia OSX editor is running fine here on Leopard..
sure you tried using the OSX editor?
vyedmic
PostPosted: Tue Apr 08, 2008 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Am I stupid or what???
Sure it works....I feel embarrased Shocked Sad
But that doesn't change the problems I have with Java midi extensions. Weak justification of the topic but at least something Wink
Cheers Poster
Poster
PostPosted: Tue Apr 08, 2008 3:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cheers Poster
no worries mate..
Nomad works fine here on 10.5.2..
Though I have a NM Rack, might be a difference..
Nomad looks very promesing but I still prefer Clavia's editor for the moment..
One reason being not able to 'auto temp load' presets directly from the Finder by double click>load..
This is still a real showstopper for me personally..
Also don't understand why it keeps all opened presets open in the tabs.. quite messy..
anyway.. appreciate the efforts being put into NM1..
cheers..
vyedmic
PostPosted: Wed Apr 09, 2008 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Did you have any problems with Java MIDI extensions or did you just use the ones bundled?
Poster
PostPosted: Wed Apr 09, 2008 3:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
I only used osxmidispi.jar and libosxmidispi.jnilib and all works fine..
fransb
PostPosted: Sat Jun 07, 2008 8:21 am    Post subject: No connection with micromodular in os x 10.5.3
Subject description: os x 10.5.3
First of all, I am impressed by this piece of work!
After installing nm-edit 0.3 revision 2 on my Mac Book Pro, including libosxmidispi.jnilib and osxmidispi.jar, a connection with my micromodular couldn't be established. I got the following message:
net.sf.nmedit.jsynth.SynthException: net.sf.nmedit.jnmprotocol2.MidiException: timeout: 10000ms (net.sf.nmedit.jnmprotocol2.SynthSettingsMessage) [error=-1001]
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:411)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.setConnected(NordModular.java:881)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm.trySetConnectedState(SynthObjectForm.java:958)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm$1$1.run(SynthObjectForm.java:599)
Caused by: net.sf.nmedit.jnmprotocol2.MidiException: timeout: 10000ms (net.sf.nmedit.jnmprotocol2.SynthSettingsMessage) [error=-1001]
at net.sf.nmedit.jnmprotocol2.NmMessageAcceptor.waitForReply(NmMessageAcceptor.java:111)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:400)
... 10 more
Is there anything I could try???
Thx, fransb
fransb
PostPosted: Sun Jun 08, 2008 2:05 am    Post subject: No connection with micromodular in os x 10.5.3
Subject description: Connected!
After enabling external midi clock, I got connected.
fransb
