vyedmic
Posted: Sat Jan 12, 2008 8:16 pm Post subject:
Nomad MicroModular & Leopard |
As you may know OS X Leopard doesn't support Classic applications anymore so Clavia's OS X Editor no longer works. Nomad is the only alternative.
I managed to run it with Mandolane, the Humatic Java Midi Subsystem(MMJ) didn't work for me. I could construct some basic patches and they worked - I could download them into the Micro but upload didn't work at all. Also when I changed any parameter I had to re-download the patch every time although cable connections weren't affected and I could mess with cables as I wanted without re-downloading.
This is not very usable at the time being but I have my faith in this great editor (at least it looks great ).
Specs:
Intel Macbook Santa Rosa 2GHz 1GB RAM
Mac OS X Leopard 10.5.1
Edirol UM2-EX MIDI Interface
Nomad 0.2.1
Mandolane MIDI SPI 2.04
These are only first impressions I intend to test it more thoroughly.
Martin |
vyedmic
Posted: Sun Apr 06, 2008 11:07 am Post subject:
Back on the case after couple of months . New Nomad prerelease looks great but when I try to setup connection settings I get this:
| Code: | net.sf.nmedit.jsynth.SynthException: Invalid plug MidiPlug[name=Port 1 <MIn>,vendor=EDIROL,description=Midi IN port:1] for net.sf.nmedit.jsynth.midi.MidiPort[name='pc-out',type=TRANSMITTER,plug=MidiPlug[name=null,vendor=null,description=null]].
at net.sf.nmedit.jsynth.midi.MidiPort.setPlug(MidiPort.java:110)
at net.sf.nmedit.jsynth.nomad.forms.SynthPropertiesDialog$PortSettingsDialog.applyPortSettings(SynthPropertiesDialog.java:248)
at net.sf.nmedit.jsynth.nomad.forms.SynthPropertiesDialog$PortSettingsDialog$MyAction.run(SynthPropertiesDialog.java:223)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:461)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:180)
at java.awt.Dialog$1.run(Dialog.java:535)
at java.awt.Dialog$2.run(Dialog.java:563)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Dialog.show(Dialog.java:561)
at java.awt.Component.show(Component.java:1302)
at java.awt.Component.setVisible(Component.java:1255)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm.showSettings(SynthObjectForm.java:1257)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm$2.actionPerformed(SynthObjectForm.java:609)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1882)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2202)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:420)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:258)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:236)
at java.awt.Component.processMouseEvent(Component.java:5602)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3135)
at java.awt.Component.processEvent(Component.java:5367)
at java.awt.Container.processEvent(Container.java:2010)
at java.awt.Component.dispatchEventImpl(Component.java:4068)
at java.awt.Container.dispatchEventImpl(Container.java:2068)
at java.awt.Component.dispatchEvent(Component.java:3903)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4256)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:3936)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3866)
at java.awt.Container.dispatchEventImpl(Container.java:2054)
at java.awt.Window.dispatchEventImpl(Window.java:1791)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:463)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:110) |
Still only Mandolane works for me neither supplied extensions nor mmj show anything in connection settings. |
Poster
Posted: Mon Apr 07, 2008 1:28 pm Post subject:
Re: Nomad MicroModular & Leopard |
| vyedmic wrote: | As you may know OS X Leopard doesn't support Classic applications anymore so Clavia's OS X Editor no longer works. Nomad is the only alternative.
erm.. the Clavia OSX editor is running fine here on Leopard..
sure you tried using the OSX editor? |
vyedmic
Posted: Tue Apr 08, 2008 2:56 pm Post subject:
Am I stupid or what???
Sure it works....I feel embarrased
But that doesn't change the problems I have with Java midi extensions. Weak justification of the topic but at least something
Cheers Poster |
Poster
Posted: Tue Apr 08, 2008 3:49 pm Post subject:
| vyedmic wrote: | Am I stupid or what???
Cheers Poster |
no worries mate..
Nomad works fine here on 10.5.2..
Though I have a NM Rack, might be a difference..
Nomad looks very promesing but I still prefer Clavia's editor for the moment..
One reason being not able to 'auto temp load' presets directly from the Finder by double click>load..
This is still a real showstopper for me personally..
Also don't understand why it keeps all opened presets open in the tabs.. quite messy..
anyway.. appreciate the efforts being put into NM1..
cheers.. |
vyedmic
Posted: Wed Apr 09, 2008 2:06 pm Post subject:
| Did you have any problems with Java MIDI extensions or did you just use the ones bundled? |
Poster
Posted: Wed Apr 09, 2008 3:09 pm Post subject:
| vyedmic wrote: | | Did you have any problems with Java MIDI extensions or did you just use the ones bundled? |
I only used osxmidispi.jar and libosxmidispi.jnilib and all works fine.. |
fransb
Posted: Sat Jun 07, 2008 8:21 am Post subject:
No connection with micromodular in os x 10.5.3 Subject description: os x 10.5.3 |
First of all, I am impressed by this piece of work!
After installing nm-edit 0.3 revision 2 on my Mac Book Pro, including libosxmidispi.jnilib and osxmidispi.jar, a connection with my micromodular couldn't be established. I got the following message:
net.sf.nmedit.jsynth.SynthException: net.sf.nmedit.jnmprotocol2.MidiException: timeout: 10000ms (net.sf.nmedit.jnmprotocol2.SynthSettingsMessage) [error=-1001]
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:411)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.setConnected(NordModular.java:881)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm.trySetConnectedState(SynthObjectForm.java:958)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm$1$1.run(SynthObjectForm.java:599)
Caused by: net.sf.nmedit.jnmprotocol2.MidiException: timeout: 10000ms (net.sf.nmedit.jnmprotocol2.SynthSettingsMessage) [error=-1001]
at net.sf.nmedit.jnmprotocol2.NmMessageAcceptor.waitForReply(NmMessageAcceptor.java:111)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:400)
... 10 more
Is there anything I could try???
Thx, fransb |
fransb
Posted: Sun Jun 08, 2008 2:05 am Post subject:
No connection with micromodular in os x 10.5.3 Subject description: Connected! |
After enabling external midi clock, I got connected.
fransb |
