Recent Changes - Search:
go to the forum
Contents
Site
Help
« sep 2026 · jan 2027 »
add a calendar item
PmWiki / Basic PmWiki editing rules
authors (basic)
The pages on this site are wiki-based pages, which means that pages can be created and edited by multiple authors. To edit a page, click the Edit link that exists somewhere on the page, usually in the header or footer. Some pages may be password-protected, depending on the system's security policies, but many systems allow open editing of pages.
PmWiki is not WYSIWYG - When editing a page, you see the markup text that describes the content of the page. The basic rules for page markup are simple:
  1. Use a blank line to start a new paragraph more.
  2. To make a list, start each line with # for numbered (ordered) lists or * for bulleted (unordered) lists more.
  3. To make a heading, start a line with two or more ! marks; !! is a subheading, and !!! is a sub-subheading more.
  4. To emphasize text, enclose it in 2 or 3 single quotes; ''text'' for italics or '''text''' for bold more.
  5. To make a link to another page, enclose the page's name in double brackets; for example [[basic editing]] links to this page.
  6. To make a link to another site, type its address, such as [[http://example.com/]]. Email links must have "mailto:" before such as mailto:xyz@example.com
If you want to experiment with editing a page, try it on the Wiki Sandbox. You can edit the Wiki Sandbox without affecting anything important on this site. On talk pages and discussions, it's courteous to sign your contribution; using ~~~ effectively 'signs' the name that you provide in the Author field on the Page Edit form.
Examples of common markups
The tables below demonstrate many of the common markups used to format pages. The left column shows what to write to achieve the effect, the right column shows the effect of the markup. More details are available from the text formatting rules and other documentation pages. An exhaustive list of default markup is available as the markup master index.
Paragraphs and line breaks
What to type
What it looks like
Consecutive lines
will be merged together
as part of the same paragraph.
One or more empty lines will start a new
paragraph.
Consecutive lines will be merged together as part of the same paragraph.
One or more empty lines will start a new paragraph.
Two backslashes at the end of a line \\
force a line break.
Or use this markup: [[<<]] to
force a break.
force a line break.
Or use this markup:
to force a break.
Further reading:
  • text formatting rules for more information on linebreaks, indented or hanging paragraphs.
  • wiki styles for centered or right justified paragraphs and "floating" text (boxes), borders and much more.
Lists
Start each line with # for numbered (ordered) lists or * for bulleted (unordered) lists:
* Bullet list
* Another item
** More asterisks produce sub-items
** etc.
  • Bullet list
  • Another item
    • More asterisks produce sub-items
    • etc.
# Numbered lists
# Another item
## more hashes produce sub-items
  1. Numbered lists
  2. Another item
    1. more hashes produce sub-items
# List types
# can be mixed
** numbered list with unordered sub-list
  1. List types
  2. can be mixed
    • numbered list with unordered sub-list
Learn more about lists (including definition lists) and list styles.
Headings
Headings are useful for creating a "well-structured" page. They're not just for making big text.
What to type
What it looks like
!! Major Subheading
!!! Minor Subheading
!!!! And More
!!!!! Subheadings
Major Subheading
Minor Subheading
And More
Subheadings
Text Emphasis
To emphasize, enclose text in apostrophes (single-quote marks), not double-quotes.
What to type
What it looks like
''Emphasize'' (italics),
'''strong''' (bold),
'''''very strong''''' (bold italics).
Emphasize (italics), strong (bold), very strong (bold italics).
Links
To make a link to another page, enclose the page's name in double square brackets.
What to type
What it looks like
Practice editing in the [[wiki sandbox]]
Practice editing in the wiki sandbox
Note that words are automatically capitalized in page titles. The link above links to the page WikiSandbox.
Text after a pipe (|) is used as the link text:
[[WikiSandbox | practice area]].
Practice editing in the practice area.
Endings become part of the link text, parentheses hide parts of the link name:
[[wiki sandbox]]es.
[[(wiki) sandbox]].
wiki sandboxes.
sandbox.
When linking to a page in a different WikiGroup, provide the group name, followed by a separator, and then the page name:
[[Main.Wiki Sandbox]] shows group + name
[[Main/Wiki Sandbox]] shows only name
Main.Wiki Sandbox shows group + name
Wiki Sandbox shows only name
Links to external sites
bare url:  http://www.pmwiki.org
link text: [[http://www.pmwiki.org |
PmWiki home]]
link text: PmWiki home
Links as reference to external sites
link text: [[http://www.pmwiki.org | #]]
link text: [1]
Colons make InterMap (also called InterWiki) links to other wikis:
What's an [[Wikipedia:aardvark]],
anyway?
What's an Wikipedia:aardvark, anyway?
Links to nonexistent pages? are displayed specially, to invite others to create the page.
PmWiki supports more link types and a lot of display options, see Links to learn more.
Preformatted text
Preformatted text is displayed using a monospace font and not generating linebreaks except where explicitly indicated in the markup.
Note that very long lines of preformatted text can cause the whole page to be wide.
For preformatted text with markup (e.g. emphasis) being processed, start each line with a space:
 Lines that begin with a space
 are formatted exactly as typed
 in a '''fixed-width''' font.
 in a fixed-width font.
If you don't want Wiki markup to be processed, use [@ @]. Can also be used inline.
Text escaped this way has
the HTML ''code'' style
Escape sequence
If you don't want Wiki markup to be processed, but lines reformatted use [= =]. Can also be used inline.
markup is ''not'' processed
but lines are reformatted
markup is ''not'' processed but lines are reformatted
Horizontal line
Four or more dashes at
the beginning of a line
produce a "horizontal rule"
Four or more dashes at the beginning of a line
Tables
Simple tables use double pipe characters to separate cells:
|| border=1
||! head 1 ||! head 2 ||! head 3 ||
|| cell 1  ||  cell 2 ||  cell 3 ||
head 1head 2head 3
cell 1cell 2cell 3
See simple tables and advanced tables to learn more about the rich feature set of PmWiki tables.
Images
See Images
Character formatting
What to type
What it looks like
* @@Monospaced text@@
* Text with '^superscripts^'
* Text with '_subscripts_'
* deleted {-strikethrough-} text
* inserted {+underline+} text
* [+big+], [++bigger++] text
* [-small-], [--smaller--] text
  • Monospaced text
  • Text with superscripts
  • Text with subscripts
  • deleted strikethrough text
  • inserted underline text
  • big, bigger text
  • small, smaller text
Use WikiStyles to change the text color .
Page titles
The (:title:) directive sets the page's title to something other than its page name.
(:Title Basic PmWiki editing rules:)
The name of this page is "{$Name}", and
its title is "{$Title}".
The name of this page is "BasicEditing", and its title is "Basic PmWiki editing rules".
Page Description
  • The (:Description Page summary here:) directive sets the page description. The description is used by search engines, and can be displayed in search results and in page lists.
(:Description PmWiki's basic edit
syntax:)
The summary description of this page is
{$Description}.
The summary description of this page is PmWiki's basic edit syntax.
I'm new to PmWiki, where can I find some basic help for getting started?
The Basic Editing page is a good start. From there, you can just follow the navigational links at the top or the bottom of the page (they are called Wiki Trails) to the next pages, or to the Documentation Index page, which provides an outline style index of essential documentation pages, organized from basic to advanced.
How do I include special characters such as Copyright (©) and Trademark (® or ™) on my wiki pages?
See special characters on how to insert special characters that don't appear on your keyboard.
How can I preserve line-breaks from the source text?
PmWiki normally treats consecutive lines of text as being a paragraph, and merges and wraps lines together on output. This is consistent with most other wiki packages. An author can use the (:linebreaks:) directive to cause the following lines of markup text in the page to be kept as separate lines in the output. Or a wiki administrator can set in config.php $HTMLPNewline = '
to force literal new lines for the whole site.
Can I just enter HTML directly?
By default (and by design), PmWiki does not support the use of HTML elements in the editable markup for wiki pages. There are a number of reasons for this described in the PmWiki Philosophy and Audiences. Enabling HTML markup within wiki pages in a collaborative environment may exclude some potential authors from being able to edit pages, and pose a number of display and security issues. However, a site administrator can use the Cookbook:Enable HTML recipe to enable the use of HTML markup directly in pages.
Where can I find more documentation?
See the documentation index and the markup master index pages.
This page may have a more recent version on pmwiki.org: PmWiki:BasicEditing, and a talk page: PmWiki:BasicEditing-Talk.
Edit - History - Print - Recent Changes? - Search Page last modified on 2012-06-12 21:35 [UTC-7] - 2311 views
