using TV to display audio signals
Page 1 of 4 [85 Posts]
Goto page: 1, 2, 3, 4 Next
dnny
PostPosted: Tue Jul 05, 2005 4:15 am    Post subject:  using TV to display audio signals Reply with quote  Mark this post and the followings unread
Hi all this topic is all about
using TV to display audio signals.
you may have heard about Wobblevision , Wave Vessel , Analog Visualization Unit, AVU, Psychoscope, o-scope , b&w tv into a large screen oscilloscope kits - -
this is it all in one
Posted Image
Before we begin, I have to give everyone a warning.
DO NOT ATTEMPT THIS PROJECT!
MODIFYING TV IS A DANGEROUS PROCESS. DO NOT ATTEMPT THIS UNLESS YOU KNOW THE DANGERS OF CAPACITORS AND
OTHER ELECTRONIC COMPONENTS. THERE IS A GREAT RISK OF POTENTIALLY DEADLY ELECTRIC SHOCK, AND THERE IS
THE POSSIBILITY OF FIRE OR EXPLOSION.
IF YOU TRY TO FOLLOW THESE INSTRUCTIONS, NO-ONE CANNOT BE HELD LIABLE FOR ANY DAMAGE OR DEATH CAUSED
WHILE BUILDING OR USING THE DEVICE
before you begin read these safety instructions:
Safe Discharging of Capacitors in TVs and Video Monitors
cathode-ray tube Safety Issues
Deflection System Safety
There are two areas which have particularly nasty electrical dangers: the non-isolated line power supply and the CRT high voltage.
Posted Image
stay away from the red cable with the suction cup end.
after you have opened the TV unit wear rubber gloves! (longer sleaves better)
Posted Image
the principal of this audio signal displaying is that
when TV is normally operated the Deflection Yoke generates a magnetic field and use it to direct the electron beam in the cathode-ray tube. Deflection Yoke gets signals from Deflection Circuit(Board) - Two of the wires control the horizontal motion, and the other two control the vertical motion. you just replace the Deflection Circuit Board signals whit audio signals and there you go.
i have made some schematics to clear how to route audio signals to Deflection Yoke- these schematics are based on information from Censtrons Wave Vessel page and my own experiments
first you need to find out the two horizontal and two vertical wires -
this will help
here you see the wires going to yoke
Posted Image
H=horizontal
Hg =horizontal ground
V=vertical
Vg=vertical ground
here is the unmoded version
Posted Image
whit this you can see normal TV programs
here is the Censtron version (a
Posted Image
whit this setup you get a bar that differens in length (a bit like panel of Kit[car from Knight Rider] when it was speaking)
Posted Image
here is the Censtron version (b
Posted Image
whit this setup you get vertical line that vibrates
Posted Image
here is the stereo version
Posted Image
whit this setup you get pulsing circles
Posted Image
the experimenting is still in progress so i will post more on this soon as i get more results
DBerning on audiokarma.org wrote:
Magnetic deflection TVs of this era needed the deflection yoke for energy storage for the flyback pulse that was used to provide high voltage for the CRT. Because I was using the yoke for audio deflection, I mounted a second deflection yoke somewhere in the TV cabinet so that the inductance from the winding could be used in the flyback-based high-voltage circuit.
so i might also try to find an extra yoke to the flyback pulse -
but sofar it works fine Smile i have use my unit about 10 minutes at one time
here is a link you might want to read:
Other uses for old TVs
hope to get some comments if anyone have build this type of unit
it might be dangerous but it can be done
i have videoclips of my unit working but there is no support for .mpg-files Sad (maybe this can be fixed)
my philips looks like this:
Posted Image
daniel
ps. the schematics are done whit free RJWSoft Schematic Publisher
davep
Audio files: 10
G2 patch files: 73
PostPosted: Tue Jul 05, 2005 11:12 am    Post subject: Re: using TV to display audio signals Reply with quote  Mark this post and the followings unread
Posted Image
.... just some personal experience with this topic.... when I was still in high school, I had a summer job in a TV repair center. When servicing TVs, the first thing the techs would do would be to discharge the HV cap by shorting it to the chassis using a screwdriver. But sometimes this did not work as expected..... One day, a tech was attempting this, and the discharge arced across the surface of the screwdriver handle to the tech's hand and gave him a huge high voltage shock. He was knocked out instantly, fell over backwards and cracked his skull open on the floor. It nearly killed him. He also bit off the tip of his tongue in the process. I wouldn't stick my fingers in there for anything.
Dave Peck
Audio files: 266
PostPosted: Wed Jul 06, 2005 1:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
I appreciate Dave's warning, and the warnings that DNNY himself posted. As the admin here, I thought quite a bit about removing this post because of the dangers. I've decided to leave it here. There are many things in real life that are dangerous. Composing music can be dangerous too. Many years a ago a guy threatened to kill me because he didn't like my music, or maybe because his girlfriend did. Shocked
Well, working on TV sets is probably much more dangerous than composing music, but be very careful nonetheless. Also, be sure not to walk in front of a moving train and don't put your hand into a garbage disposal unit.
Former site admin
Audio files: 353
PostPosted: Wed Jul 06, 2005 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Remove the post ... you americans are crazy ... this is FUN !!
But indeed try to be carefull, last time I toyed with a TV a power chip from the power supply exploded and parts of it hit the ceiling. An accidental short circuit, but I had to have it on for measurement to be made.
Jan.
dnny
PostPosted: Wed Jul 06, 2005 8:52 pm    Post subject: Re: using TV to display audio signals Reply with quote  Mark this post and the followings unread
okay i did find the extra yoke - but it was not the same type - so this is what happened:
the picture was extremely bright! i mean really really bright. so i was very happy for a while it looked so cool.
after some 15 -30mins both of the TV sets fuses burn.
so what happened is that i drived the CRT whit too much voltage and it started to produce X-rays. so now im feeling really sick maybe because of the radiation overdose- hope that it goes away.
so what did we learn? -
if you want to ad the extra yoke to extra brightnes you need to measure the yokes inductance first and then find another yoke that has the same properties.
(or if you want a cheapo X-ray machine just replace the fuses whit thik wire)Wink
i think deleting this post is not so good idea - i don't courage anyone to build this kind of unit - but there are always some jerks like me- that will do it anyway - so i want to share information that those people that do attempt this have as much info about it as possible
daniel
Audio files: 266
PostPosted: Wed Jul 06, 2005 9:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am really sorry to hear you are not feeling well, Daniel. I certainly hope you weren't exposed to Xrays. Maybe you just happend to get some bug. I hope that's more like it. Be sure to rest up and get your strength back.
No no, I'm not going to delete the thread. I just said that I considered it. Maybe it is pointless to say I'm considering doing something and then not doing it. You are right, it is good for people to learn from each other. That's what we are here for.
dnny
PostPosted: Thu Jul 07, 2005 6:41 am    Post subject: X-ray radiation on TV Reply with quote  Mark this post and the followings unread
hi all im feeling lot better now
i called to The Radiation and Nuclear Safety Authority of Finland
and asked if i have been exposed to any radiation danger by moding my tv. and they sayid that there is very small possibility to get enough radiation from CRTs - in their test the maximum X-ray radiation from television has been 100mGy/h (hundred milliGrays per hour) and after that the tube has collapsed.
to get symptoms from X-rays you need to get at least 100Gy
the symptoms are then the same type of skin burns you get from sun.
the X-ray radiation on tv-set is stronger in the back of the tube than in the front. the X-ray borns when electrode hits the phosphor wall. X-ray bounces back to the inner walls of tube. it keeps bouncing and gets weaker and dies - the glass is thicker in the back so some x-rays get through but we are talking of really small amounts of radiation.
daniel
Audio files: 266
PostPosted: Thu Jul 07, 2005 7:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm glad to hear the chance of Xray radiation is small. Thanks for the update.
Audio files: 19
PostPosted: Mon Jul 11, 2005 6:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi all you twisted people! ;)
I found this little circuit link a while back looking for a TV oscilloscope- for all those who don't want to fry themselves!
http://www.intio.or.jp/jf10zl/tvosc.htm
It's on my 'to build' list but that could take a while to get round to. Please let me know if anyone has any joy with it.
Tom
dnny
PostPosted: Tue Jul 12, 2005 12:23 am    Post subject: Reply with quote  Mark this post and the followings unread
v-un-v wrote:
Hi all you twisted people! Wink
so if we take a look also on these NON-fry yourself -models of TV oscilloscopes here is nice page whit detailed instructions and PCB layouts, front panels and all . . . its bit more complicated but it has more options
Tele-Scope
Posted Image
dnny
Audio files: 19
PostPosted: Tue Jul 12, 2005 1:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah the tele-scope looks great- but have you tried looking on the internet for a few of the chips inside? Secondhand oscilloscopes are really cheap these days (I bought mine for a tenner).
However, while we are on the subject of oscilloscopes, I found this one the other day;
http://www.elektor-electronics.co.uk/Default.aspx?tabid=30&ProductID=2418
dead cute eh?
dnny
PostPosted: Tue Jul 12, 2005 5:52 am    Post subject: Reply with quote  Mark this post and the followings unread
dead cute eh?
well i haven't figure out all those chips but i think all can be substituted -whit newer versions and im not even sure if im going to build the tele-scope. my AVU- has still some things to be done
if someone is building the tele-scope here are the ICs Descriptions for substitutes
74HCT00 = Quad 2-input NAND gate
74HCT04 = Hex inverter
74HCT4040 = 12-stage binary ripple counter
SAA1043 = Universal sync generator
74HCT541 = Octal buffer/line driver; 3-state
74HCT4075 = High Speed CMOS Logic Triple 3-Input OR Gate
HM0-6116-2 = 2K X 8 GENERAL PURPOSE CMOS SRAM
74HCT74 = Dual D-type flip-flop with set and reset; positive-edge trigger
74HCT688 = 8-bit magnitude comparator
74HCT02 = Quad 2-input NOR gate
74HCT4024 = 7-stage binary ripple counter
74LS90 = Decade counter; divide-by-twelve counter; 4-bit binary counter
ZN439 = A/D converter
yeah- secondhand O-scopes are great if you find one.
the GBDSO is a real cutie!
if you don´t want to pay £103.00 here are the PCB-layouts and instructions to make GBDSO (GameBoy Digital Sampling Oscilloscope) PDF (needs some SMD skills) you still have to order the EPROM chip from Elektor Electronics (£13.60) the pcb is also available for £8 . . .
but lets continue on this DIY oscilloscope talk by adding this LED-matrix oscilloscope schematic
dnny
Wild Zebra
PostPosted: Tue Jul 12, 2005 7:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Well I'll be darned. What will they think of next
"your stripes are killer bro"
Rob
G2 patch files: 109
PostPosted: Thu Jul 14, 2005 10:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Hihi, this is something I did when some 15 years of age. Connect the vertical connections of the deflection coils to the output of a small amp and turn the coils 90 degrees. Instant scope.
I was aware of the hazards and some experienced older fellow was looking over my shoulder when discharging the high anode voltage. Luckily I never got fried.
Around that time I did get quite a blow from a tube radio though. Luckily the radio fell from my hands as I was paralized by the high voltage. Have been very, very, very careful ever since.
As one can not depend on luck when messing around with high voltages.
Audio files: 266
PostPosted: Thu Jul 14, 2005 1:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Experimenters who have been electrocuted while bending TV sets rarely post their stories on a forum... Crying or Very sad
All the rest of us have some shocking tales. Twisted Evil
dnny
PostPosted: Sun Apr 02, 2006 10:22 am    Post subject: Reply with quote  Mark this post and the followings unread
update of my philips TX :
the thing that happened to my Philips TX is that i tried to get the most of it and i used a random coil i savaged from some "i don´t remember what".
so i connected the coil lets say it was 50mH to the points of horizontal and horizontal ground of the Deflection Circuit(Board) - and wow it was cosmic - the beam was so bright - it was just like looking to sun. well i realized that the unit heated a lot - so i attached two ventilators . . . and i took it to "koneisto" ( The Festival For Electronic Music in Helsinki) it was in stage whit Aavikko. it lasted one hour all most the whole gig and died of over heating Sad but i have to say that no TV has ever be so bright! all the time it looked that it will explode any minute Smile
this is the setup what i did -
Posted Image
so i have been looking for the next TV (victim) to my experiments -
and i got now a correct size coil from the broken Philips TX
and meanwhile Censtron has made their first color vessel:
Posted Image
We just finished making the first Color Wave Vessel, with it you can now make the visualizations any color from invisible to white. Check out the auction for more information.
take care
daniel
www.koelse.org
flickr: cable porn group
destroyifyer
PostPosted: Fri May 19, 2006 10:38 am    Post subject: Reply with quote  Mark this post and the followings unread
oh, sweet, totally awesome. impressive stuff
yay
dnny
PostPosted: Thu Jul 20, 2006 12:53 am    Post subject: Reply with quote  Mark this post and the followings unread
my Friend gave me a old soviet travel-TV that was not working but, it could display the usual noise. so i did the things described in this topic - but whit a 2mm pinjack -patch panel and speakon connector - so i can connect straight to my amp.
here are some pictures:
Posted Image
not much space inside so i removed the speaker
the patch panel made of perspex:
Posted Image
the whole unit:
Posted Image
Posted Image
this video shows the beauty of electron beam bouncing whit music
sorry about the quality Sad but you get the picture
daniel
www.koelse.org
seraph
Editor
Editor
Audio files: 33
PostPosted: Thu Jul 20, 2006 1:34 am    Post subject: Reply with quote  Mark this post and the followings unread
it would really look cool on stage Very Happy
dnny
PostPosted: Thu Jul 20, 2006 2:00 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah. i will try to get it to stage, if not it will nicely fit between my light console and mixer. - - - but my "wannabe"-scope is so lame when you see these teslas Zap >
Tesla coil music
will this be my next project? Shocked (there should be emoticon for electric shock)
this project also looks nice
> Making a Hard Drive Laser Oscilloscope
but then you would need to have a powerfull laser... hmm... power laser and eyes ... maybe not so good idea after all cyclops
www.koelse.org
EraSer
PostPosted: Thu Jul 20, 2006 2:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi dnny
Great!
very cool TV! Cool
Do you know if is it possible to modify that little b/w portable TV? Even in these there is the danger of elect shock? Rolling Eyes
dnny
PostPosted: Thu Jul 20, 2006 2:56 am    Post subject: Reply with quote  Mark this post and the followings unread
if it's a CRT (cathode-ray tube) type of TV then it's possible - but is if it's LCD or other flat type then it´s not.
so the older the TV you have. the better Smile
Exclamation and if you decide to do this project don't add the extra coil/yoke for the extra bright beam. it will fry you TV Exclamation
read all the warnings and safety instructions and wear rubber gloves!
and if you have any droughts just ask before doing Wink
thanks.
and sorry if you feel that im over protective - i just don´t want that some of you get fryed because of my instructions
daniel
www.koelse.org
EraSer
PostPosted: Thu Jul 20, 2006 3:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you very much for WARNINGS. Wink
I would make it.....I'm very fascinated by circuit bending TV ....but at the same time I'm afraid Embarassed.I think this should be make only by expert people like you who know what is to do.
I'll wait for your next cool thing Very Happy
go dnny go! cheers
bye
-balance-
dnny
PostPosted: Thu Jul 20, 2006 3:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks balance
I'm not an expert i just like experimenting - nowadays I'm coming more careful - specially after that "x-ray"-day Smile and few other shocks that i got when working whit dimmers and strobes... but you can never be too careful and on the other hand if you scare too much you can never do anything - because the danger lurks everywhere Wink
www.koelse.org
SuperKoopa
PostPosted: Fri Jul 21, 2006 2:23 am    Post subject: Reply with quote  Mark this post and the followings unread
HI dnny! great bending!
just one question:
how do you connect the ten jacks on the patch panel?
