Joined: Jan 31, 2003 Posts: 18512 Location: Durham, NC
Audio files: 266
Posted: Tue Aug 16, 2005 11:37 am Post subject:
Wow, that is a great article. I wish I would have read this one years ago. Thanks for posting this. This is practical information you never get in engineering school. Seems this topic is worth making a sticky one. _________________ --Howard
my music and other stuff |
Posted: Tue Aug 16, 2005 12:02 pm Post subject:
| Sticky = YES! It'd be nice to keep a well moderated sticky for any reference material like this found to be invaluable. |
Audio files: 19
Posted: Thu Nov 24, 2005 1:46 pm Post subject:
Re: How to Choose the right Capacitor |
| jksuperstar wrote: | | Slightly older reference, but still holds it's water. |
That may be the case- but it's bloody hard to read (for me anyway)- which is such a shame
I'm so pleased the internet is here today and this old font hell is left for those remaining who can read it- and people like me can use Comic Sans MS (although I know most type setters HATE comic sans!!) _________________ ACHTUNG!
Benjamin
Posted: Thu Dec 21, 2006 11:50 am Post subject:
Hello hello.
The links don't work, which is really a shame since I was hoping to find out what a capacitator is.
Audio files: 353
Audio files: 373
Audio files: 353
Posted: Sat Jun 02, 2007 6:06 am Post subject:
| Antimon wrote: | | (who is making his first journey into musical soldering, trying to decode that tantalum capacitor...) |
I imagine you using contact microphones to document the sounds made during the construction process ...
You can post a picture of the tantalum to see if someone else has a clue. |
Audio files: 373
Posted: Sat Jun 02, 2007 9:13 am Post subject:
| Blue Hell wrote: | | Antimon wrote: | | (who is making his first journey into musical soldering, trying to decode that tantalum capacitor...) |
That's ok, I think I found what I needed. There is so much stuff in here that's probably wrong anyway, so I'll save it for an error tracing session later on. Doing one of Ray Wilson's mini-synths, by the way
paults
Joined: May 08, 2006 Posts: 21 Location: Fort Worth, TX
Posted: Wed Aug 06, 2008 12:07 pm Post subject:
a) the best caps for VCO integrators are polystyrene. Look for Mouser series 23PSxxx.
b) for 'general purpose' caps 0.47uf and under (VCFs, etc) use a polyproplyene. A really good size/cost are the WIMA FKP2 series (also at Mouser) or the Panasonic ECQ-P from Digikey.
c) for 0.1uf bypass, use axial ceramic monolythic, such as AVX SA 'Spinguard' series (SA105E104M) at Mouser.
d) for electrolytics, avoid tantalum like the plague (they fail *shorted*) and use a low ESR, 105C type. I like Nichicon UPW series (Mouser). |
meloditech
Joined: Feb 16, 2009 Posts: 12 Location: Orange County NY
Posted: Mon Feb 16, 2009 4:32 pm Post subject:
Caps |
Also,when going across a power cable tapped off a car or other high current battery avoid monolithic ceramic surface mount caps directly
across the bus...if they are damadged or physically shocked,they can crack internally to where they dont short complety but experience a great reduction in resistance. No blowout,but you have created a minature infraread heater device in the middle of your project's real estate.A fire after the lights are out is quite possible. Depending on your wiring and whether or not you fused,fusible linked or went direct ;you could short out enough harness wiring to intiate a catastrophic failure of your high current source.Lead-acid battery burns are no fun. i work with these high current taken for granted devices and have learned a healthy respect for both their maintenance and use. Please do not wire these types of caps directly across the battery bus. _________________ John 3:16 |
meloditech
Posted: Mon Feb 16, 2009 4:35 pm Post subject:
A clarification on my comment |
Some experimenters use batteries for some synth,electro -art sculptures or amp projects. I felt the comments concerning high current appropriate. _________________ John 3:16 |
gwaidan
Joined: Mar 07, 2009 Posts: 53 Location: Sydney, Australia
3phase
G2 patch files: 141
Posted: Tue May 19, 2009 4:17 pm Post subject:
just one remark..
for service of vintage modules i started to collect old capaciators from the 50´s and 60´s..
mainly to recap vintage studio modules...
but i realized that some of these big old beasts are very beautifull in synth circuits...
so i recomend to dont throw the old 50´s valve tape machine into the trash without getting the caps out...
of cause you need to test them..but after a few years in this game i can state that caps from 50´s to late 60´s are often in a better condition than the ones from the 80´s.. at least with german gear from that time...
old grundig gearf has often strange time resistance telefunken caps inside...
old measuring equipment is also a source of high quality caps...
at least european stuff
picking the wright cap in a synth circuit very well can be using an audiophil cap..but also can be using a standard shit cap...
they all sound different... and in synth circuits you really hear that..
in the generation of sound details seem to matter more than in the reproduction of sound..
but in the generation of sound also so called bad components can give a nice charakter... while in the reproduction any dirt hurts that might be musical in a synth circuit.
I just wanted to mention that choosing the wright cap is altering sound..and thats worth on special modules to connect a breadboard and have a listen...
can be worth the effort..
picking the wright cap is testing it... |
Audio files: 266
Posted: Wed May 20, 2009 12:33 pm Post subject:
3phase makes a great point. We tend to think of capacitors, resistors and inductors as ideal components, but in reality the devices are not ideal. Every capacitor has some parasitic resistance and inductance, and these are, to various extents, non-linear. The same goes for the other parts as well.
It is convenient for us to ignore these parasitics, and in most cases we can get away with it. But even though we can sometimes ignore them, we should always remember that they are there. While the parasitics are quite difficult to measure, they can sometimes be easy to hear.  _________________ --Howard
LektroiD
Joined: Aug 23, 2008 Posts: 1019 Location: Scottish Borders
Posted: Wed Jun 10, 2009 4:33 pm Post subject:
404 on both links? _________________ LektroiD |
Audio files: 353
Posted: Wed Jun 10, 2009 4:55 pm Post subject:
That one still seems to work ... |
fretless
Posted: Thu Dec 10, 2009 5:51 pm Post subject:
| mosc wrote: | | Wow, that is a great article. I wish I would have read this one years ago. Thanks for posting this. This is practical information you never get in engineering school. Seems this topic is worth making a sticky one. |
This is a great article. I see it as having at least two valid points
1. In a resistance coupled tube amp the voltage source of each stage is high impedance, so the quality of the coupling cap must be high ($$$).
2. If the source impedance is low, tantalum is OK. This is why the Ibanez Tube Screamer actually works. |
fretless
Posted: Thu Dec 10, 2009 6:23 pm Post subject:
Nothing is tossed unless it might cause a fire.
Tube rolling and cap rolling....
Program EQ vs. source EQ. Program EQ is something that Hirsh Labs would want to measure. Source EQ is measured at the source.
Talkin' about caps and music is talking about "creamy guitar", or Air Studios, or Judy Garland in a field of poppies, oh I digress... |
beep
Posted: Mon May 20, 2013 4:24 am Post subject:
Does Anyone still have the PDFs? I get only 404.
400 nanofarad. lol. _________________ Is the future obsolete? |
Audio files: 353
beep
Posted: Mon May 20, 2013 5:36 am Post subject:
thanksalot.
the butler looks inviting. _________________ Is the future obsolete? |
JovianPyx
Audio files: 237
rogerlatur
Posted: Tue Oct 15, 2013 12:39 am Post subject:
Is it ok to use 50v caps in place of 25v caps? For instance 1uF 50v instead of 1uF/25v and vice versa?
Of course I will read all documents about capacitors linked here to know about the subject, but I am ordering right now and wondered as I also have some stock with other voltage values. |
rogerlatur
Posted: Tue Oct 15, 2013 12:32 pm Post subject:
Found this evening the answer to my question (could have search a bit more before asking !):
http://www.youtube.com/watch?v=YCSNWi3UHf4
Now what I don't understand is why using 25v when 50v can handle more voltage ? I mean why not always using a capacitor with the highest voltage value ? |
