TOG, Top Octave Generator DIY (Mostek MK50240 emulation)
Page 2 of 2 [40 Posts]
Goto page: Previous 1, 2
delayed
PostPosted: Mon Jan 23, 2012 1:22 am    Post subject: Reply with quote  Mark this post and the followings unread
does anyone have the pnp blue layout for these? the link on the top is dead.
sizone
Audio files: 48
PostPosted: Wed Jan 25, 2012 2:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Just finished the circuit for my mono version of this. Will post the connections after I draw them up. Basics is that it's a 23 key keyboard (bottom C would've required either sacrificing several octaves of range or putting in way more extra circuitry than it would be worth. In case you're wondering why it's because you can't get a close enough division for it (c8 or c7, can't remember which) from 2mhz with the 4040) with a 4 position octave selector switch. Chips used are the 4046, 2 4040s, a 4051 and, currently, 1/6th of a 4069 (don't worry, I'll at least use the other ins for lfos and an always useful inverted square wave). Everything's pretty much straight-from-the-datasheet straight forward. Only really clever (alright, at least by my standards) thing I did was to split the reset pin output on the 4040 going to the keyboard switch array into a separate output for each octave, then take a lead from the lower octave and run it to the 4069 so that the voltage drop when a key is depressed (in that octave) triggers a high out on the 4069 which is routed to the A control of the 4051......ummmm...it'll probably make more sense in the drawing.
Playing will probably sound better after I glue my freshly cut lexan strips over the switches.
Wish I'd had the foresight to pick up some IC sockets today when I was getting my perfboard so that I could start transferring this to the perfboard.
Oh, also of note is that the plastic VHS case that the switches are glued to was found on the side of the road. The tape it contained had 80's porn on it. Thought you should know.
test2.mp3
 Filesize:  1.88 MB
 Duration: 1:02
 Viewed:  2345 Time(s)
inlifeindeath
PostPosted: Mon Jan 30, 2012 11:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice dude! looking forward to seeing this thing
bod
PostPosted: Thu May 10, 2012 1:04 am    Post subject: Reply with quote  Mark this post and the followings unread
i finally got round to starting this project, thanks for the schematics Marco!! Very Happy took about 11 hours to build the TOG board, now to work on wave shapers, EG, VCF and VCA per voice......
 Filesize:  3.3 MB
 Viewed:  2813 Time(s)
Audio files: 83
PostPosted: Thu May 10, 2012 5:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow bod. Very clean and organised work. I didn't follow this schematic, but my top octave synth was a little messier...
Posted Image
JacobWatters.com
bod
PostPosted: Thu May 10, 2012 6:08 am    Post subject: Reply with quote  Mark this post and the followings unread
good work! thats some rats nest!! to be fair mine will end up the same in all likelihood!
think i'm going to aim for an LM13700 hp/bp/lp vcf and vac for each note, but i need to work out a simple voltage controlled a/r envelope generator first.
AnalogCustom
PostPosted: Fri May 11, 2012 11:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello:
You will use this schematics for wave converter ?
Posted Image
If the answer is yes give me some time to upload the chart value (capacitors and resistors: C1, C2, R1).
Saludos!
Marco.
Audio files: 83
PostPosted: Thu Jun 14, 2012 7:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Analog Custom - I was hoping to try your mk50240 emulation for my next top octave synth, but all the images are gone. Can you please repost them? You should be able to upload them directly to the forum instead of hosting on another site.
JacobWatters.com
AnalogCustom
PostPosted: Thu Jun 14, 2012 4:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi:
Here the full access to all information, including files .pcb and "Protel PCB program" (old 1.5 version) to make changes on the pcb. Soon try to upload the information to this site.
https://docs.google.com/folder/d/0B8HNN2LiZQlGNS03ekJDMnZ5ZUU/edit
Marco
JingleJoe
PostPosted: Sat Jun 16, 2012 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Ahahahaha oh thats just brilliant Laughing
Did you ever re-combobulate the schematics you mentioned one page back in the thread?
I'm doing something now which may require "top octave" methods ... Neutral
LeBon
PostPosted: Mon Mar 23, 2015 8:36 am    Post subject: Reply with quote  Mark this post and the followings unread
@AnalogCustom:
thanks for the schematics, i'll give it a try.
instead of using an entire cd4024 to make only one division, you could also use a cd4027 and save some board space
a ba634 would save even more space
can you post the values for resistors and capacitors on the wave converter?
thanks
AnalogCustom
PostPosted: Wed Apr 29, 2015 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
ericcoleridge wrote:
AnalogCustom wrote:
I did tests with 4 wave shaper (solina, crumar,..).
I'm curious as to what were the 4 waveshapes you tried, and which string synths they were based on? I'm amazed at the differences in tone that one hears across the various vintage string synth models. Some sound more like organs played through a chorus pedal, and others like an other-worldly lush string ensemble (I'm thinking of the Solina particularly). I feel like these differences in tone must have as much to do with the waveshapers as it does the chorus circuits--yes?
The PolyMoog is another one with an unbelievable, unmistakeable sound that I'm guessing has much to do with the waveshapers and fixed filters on the individual voices.
Id be all over it, if someone made a project available that mimicked the circuit path of one of these machines-- divide down, shapers and fixed filters, bbd ensemble.
Each step affects the final sound (wave shaper, ensemble-chorus, resonant filter, etc ...). Whaveshapes types:
Saw RC (nonlinear):
Crumar Multiman, Elka Rapsody, Roland VP330, etc...
Posted Image
Posted Image
Posted Image
Posted Image
Saw differentiator circuit (high-pass rc, nonlinear):
Arp Omni, Solina String Ensemble, etc...
Posted Image
Posted Image
Posted Image
Saw Staircase:
Roland RS strings (i´m not sure),... some monophonics Korgs...
Posted Image
From Elektor...
Posted Image
Special metod from Elektor (linear):
Automatic constant amplitude
Posted Image
(for experiment... input signal square 50% duty cycle, add cap 1nF in series with R1, change C1 = 33nF and R4=10M ohm for low frecuency)
Saw RC linear converter:
(schematic that I will use in my polysynth project)
Posted Image
Marco.
AnalogCustom
PostPosted: Wed Apr 29, 2015 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
LeBon wrote:
@AnalogCustom:
thanks
Hello:
I've had this project abandoned, but I am planning to retake these days. Please give me a few days to sort the information you ask. I will open a new topic called: "Full Polysynth Project").
greetings
pascalien
PostPosted: Fri Feb 24, 2023 12:35 pm    Post subject: Re: TOG, Top Octave Generator DIY (Mostek MK50240 emulation)
Subject description: For string ensemble clones, organs, full poly synths...
AnalogCustom wrote:
PCB transfer:
http://dl.dropbox.com/u/7154576/TOG%20pcb%20transfer.pdf
PDF archives:
http://dl.dropbox.com/u/7154576/TOG.rar
Hello from France
Anyone saved the two files at start of thread or knows where to find them?
Thanks.
AnalogCustom
PostPosted: Wed Apr 19, 2023 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
¡Hola!
Acá el link
https://drive.google.com/drive/folders/1Uqup8XC3MIWePfT9N1PR3IMNItm1G0n5?usp=share_link
adjunto archivos PROTEL
Me avisas si no funciona.
Saludos cordiales desde Chile.
TOPOCT3.PCB
 Filename:  TOPOCT3.PCB
 Filesize:  28 KB
 Downloaded:  339 Time(s)
TOPOCT2.PCB
 Filename:  TOPOCT2.PCB
 Filesize:  24 KB
 Downloaded:  311 Time(s)
TOPOCT1.PCB
 Filename:  TOPOCT1.PCB
 Filesize:  24 KB
 Downloaded:  298 Time(s)
TOPOCT.PCB
 Filename:  TOPOCT.PCB
 Filesize:  28 KB
 Downloaded:  330 Time(s)
