Safe for expression pedal?
Page 1 of 1 [3 Posts]
pulsewave
PostPosted: Wed Nov 16, 2022 6:57 am    Post subject: Safe for expression pedal? Reply with quote  Mark this post and the followings unread
Is this "expression pedal knob" safe to use in the a6's expression jack?? "It is powered with 9V center negative as most pedals."
https://elgaratge.com/product/echo-knob/
sunny pedaal
Audio files: 12
PostPosted: Wed Dec 14, 2022 3:34 am    Post subject: Reply with quote  Mark this post and the followings unread
the expression pedal input is not 9 volt powered.
it can be used with a normal passive 20k-100k ohm reciter/pot / knob connected between tip and ring. base is ground
no 9 volt as far as I know
pulsewave
PostPosted: Fri Dec 16, 2022 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, thanks. I think I’ll have to pursue another option (like using an Expert Sleepers disting module).
