basic wet / dry for effects circuit
Page 1 of 1 [4 Posts]
floating-water
PostPosted: Tue Dec 08, 2020 4:02 pm    Post subject: basic wet / dry for effects circuit Reply with quote  Mark this post and the followings unread
Apologies of this bores someone but whats the usual protocol for setting up a wet dry knob on a circuit? I have a delay circuit on the breadboard, ive buffered the input, sent it to the delay aswell as to the 1st pin of a potentiometer then the output of the delay to a buffer then to the 3rd pin of potentiometer. Output is from the middle pin of potentiometer. I have a feeling the problem is where the output from the input buffer goes to both the delay and the pot how do you get two outputs from one output? Resistors?
Audio files: 32
PostPosted: Wed Dec 09, 2020 2:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, resistors:
 Filesize:  14.16 KB
 Viewed:  390 Time(s)
my synth
floating-water
PostPosted: Wed Dec 09, 2020 3:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Excellent, thanks Grumble
floating-water
PostPosted: Mon Jan 25, 2021 10:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Is there a different way to wire up buffers with guitar as opposed to synthesizer signals? I am having trouble getting this to work. I took a month off electronics so im a bit rusty. I've got a fuzz circuit and a delay circuit I am trying to blend, I only have TL072's
edit: i've got the fuzz coming through now but theres a constant hum that disappears when I cut power rail to the op amp. The sound is clean when its not connected to 9v?? The bias voltage is connected to pin 3 is that all thats required?
