ssg schematic question
Page 1 of 1 [4 Posts]
R_Gol
PostPosted: Tue Nov 03, 2020 11:51 pm    Post subject: ssg schematic question Reply with quote  Mark this post and the followings unread
Regarding the red led located at the 741 ic https://imgur.com/a/kLaJ3Mr
should I just place it on the board? does it need to be at front panel ?
If the above led function is only for visualization can I omit it?
Actually - can I omit the 2x 072 ICs and their related components if I give up on led visualization?
Thanks for any clarification!
khakifridge
PostPosted: Fri Nov 20, 2020 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Ken's article doesn't show this LED on the front panel and there's nothing connected to CA and CK in the wiring diagram. Though there are wires connected in a board photo. scratch You can definitely omit the LED. But U3 is used for the coupler outputs.
R_Gol
PostPosted: Sun Nov 22, 2020 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you!
I meant to omit the op amps marked in green in here: https://imgur.com/a/Npq1q8L
their only function is as led indicator ?
if so, can I omit the part of the circuit markin green?
khakifridge
PostPosted: Sun Nov 22, 2020 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, those pairs of opamps drive the LEDs. If you don't want the LEDs, you can omit them.
