S/H => bitcrusher-style
Page 4 of 4 [84 Posts]
synthmonger
PostPosted: Tue Feb 17, 2009 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Tom you might wanna try using the 40106 vco I posted in the Lunetta thread as your main clock source for this circuit. Works pretty good!
rumpofsteelskin
PostPosted: Wed Jun 17, 2009 9:54 am    Post subject: Reply with quote  Mark this post and the followings unread
bigtex wrote:
It all starts with a sawtooth wave. This is quantized by the first S&H chip and turned from a ramp shape into a staircase shape at a rate determined by the clock.
That same original sawtooth wave is also fed into a comparator. It is compared to the audio input. Every time the comparator's state changes (caused by the sawtooth wave or audio input becoming higher or lower than the other) the second S&H samples the current step of the staircase wave.
Has this been abandoned?? I was toying around with it but noticed two problems -
- Changing the sample rate also changes the amount of quantization levels; lower sample rate = more amplitude levels. This could be sorted by phase locking the square wave to the sawtooth wave.
- The speed of the square/pulse wave looks to be prohibitively fast. Say if you want maximum resolution at 20KHz, then a minimum of 40K sawtooth wave to sample it with, and then assuming that 14bits is the maximum fidelity bit depth, that means 2^14 = 16384 possible amplitude levels. Which means the square wave clock must be at minimum 166384x40000 = 655MHz. This must also be variable to give the lowest resolution at the lowest frequency, say 30Hz. 30x2x2 = 120Hz.
Unfortunately, this doesn't look feasible which is quite a shame, the idea of it is pretty clever.
I think probably the only way to do the amplitude quantization is digitally...
does anyone know how the frostwave sonic annihilator works??
rumpofsteelskin
PostPosted: Wed Jun 17, 2009 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
*sonic alienator, rather...
rosch
PostPosted: Tue Mar 16, 2010 4:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi guys!
i have built modularkomplex's LF398 based rate reducer today (from page 3 of this topic).
i have one issue here. there's a very audible cv, almost as loud as the audio signal. when i turn the pot the pitch of the noise goes all the way up/down.
the effect itself works fine on the audio signal (edit: at least seems so).
i played bass through it and could turn the rate down (1M pot) so much that it sounded detuned (edit: with the cv i guess) and got pitch modulated. but i must have made a mistake so the cv comes through...
any idea what i could have done wrong here?
thanks!
edit: just created a new thread here
nilsomat
PostPosted: Mon Nov 21, 2011 2:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello everybody, my first post Very Happy I have been reading this forum for quite a while, a great level of expertise here, good stuff!
I have been thinking about building a bugcrusher-like-device for some time so i thought it would be a good idea to bump this thread to ask for any updates, schematics and the like. I would prefer a LF398 based device because of better availability.
Thanks a lot for any input!
Greetings,
Nils
bugbrand
PostPosted: Thu Oct 23, 2014 7:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Many moons after this thread initially appeared..
Today I'm publishing a new project version WorkshopCrusher in kit form.
Kits go on sale tomorrow via thonk: http://www.thonk.co.uk/shop/bugbrand-workshopcrusher/
And I'm also holding 2 workshops this weekend in Manchester:
http://opencircuit-network.tumblr.com/post/96401943051/build-your-own-workshop-crusher-with-tom-bugs-25th
Full build docs (inc. schematics) are now online:
http://www.bugbrand.co.uk/docs/workshopcrusher.pdf
[the no-AD781 approach may be of particular interest given how this thread started..]
Hopefully interesting, useful, enjoyable for some of you!
Cheers, Tom
http://www.bugbrand.co.uk/forums.html?main_page=product_info&cPath=1&products_id=120
Posted Image
Posted Image
PostPosted: Fri Oct 24, 2014 5:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is really cool Tom. Smile
isak
PostPosted: Sun Oct 26, 2014 1:12 am    Post subject: Reply with quote  Mark this post and the followings unread
amazing work!
this is great Smile
vladosh
Audio files: 55
PostPosted: Thu Aug 13, 2020 6:23 am    Post subject: Reply with quote  Mark this post and the followings unread
i just made pcb layout for the original LF398 Bug crusher ,but with vc control ,added pads to include the voltage divider as in YASH from Rene Schmitz ,i am yet to build this ,so i hope there won't be too much bleed from the clock ,only later i saw the workshop crusher schematic ,maybe better idea to make it this vc with 4066
 Filesize:  428.49 KB
 Viewed:  442 Time(s)
