Problem with Baby 8 cd4017 not consistent steps
Page 1 of 1 [2 Posts]
orangetones
PostPosted: Mon Mar 02, 2020 8:19 am    Post subject: Problem with Baby 8 cd4017 not consistent steps
Subject description: When steps are removed from the sequence, the timing changes/pauses
I have built a sequencer using the schematic found on this page:
https://hackaday.com/2016/01/14/oh-baby-baby10-build-a-classic-analog-music-sequencer/
But it seems when I put switches between the outputs of the 4017 and the LED/Pots to cut out a step, the timing changes. It seems to pause longer on the step that is missing. In other words, it doesn't keep the same consistent beat. It is as though the timer takes a little extra time on the missing step.
Can anyone help with why this might be happening? I can definitely post more info and even a video with the sound/problem if needed.
Thanks
Audio files: 730
PostPosted: Tue Mar 03, 2020 8:19 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome party!
Are you powering it from a battery ?
It sounds like a pot/LED cause the supply voltage to drop somewhat which will make the oscillator run faster.
So it runs slower on a step without a pot/LED. An oscillator like this will be less affected by changes in the supply voltage.
The Golden Shrimp Guild
