Using polarity to send two signal from one output?
Page 1 of 1 [2 Posts]
hyperstationjr
G2 patch files: 24
PostPosted: Mon Feb 10, 2020 11:07 am    Post subject: Using polarity to send two signal from one output?
Subject description: Can you adjust the polarity of different signals to create two tracks from out output?
Obviously there are only 4 outputs for the Nord Modular (G2 specifically) but I would love to have 8 for multitrack recording.
I can't change the physical inputs, but what if I changed the polarity of the signals?
If I ran two different sounds, converted the polarity of one signal to positive and only output positive, and converted the other signal to negative and only output negative, mixed them down, ran them out of the one output, recorded the output and then split them somehow, would that work?
Would that then produce two separate signals from one single line of audio?
Studio:
Analog Four Mk2, Digitone, Iridium Desktop, Nord Modular Rack, Nord Modular G2 Engine, Octatrack Mk2, Syntakt, Torso S4, Torso T1
For Sale/Trade:
Alesis Microverb 4, Panasonic RQ-705 Reel-to-reel, Roland Alpha Juno1, Roland R5, Yamaha TG55
Former site admin
Audio files: 353
PostPosted: Mon Feb 10, 2020 11:57 am    Post subject: Reply with quote  Mark this post and the followings unread
you'd have to separate the signals again ... which after the mix can not be done anymore (as you'll have no idea where the signal cam from) - so, no: simple mixing wont do it.
You could, in theory, time multiplex though .. do one sample of one channel and then one sample of the second one - that could be made to be seperable .. but you decoder would still have to be in sync with your encoder (which /could/ be done with your positive / negative idea - one sample all < 0 and the next one all > 0) (but you'd loose some bandwidth in the process ofcourse). It will be quite a project to get it right Shocked
