One more simple VCF
Page 1 of 1 [21 Posts]
Hammer
PostPosted: Fri Apr 20, 2018 2:14 am    Post subject: One more simple VCF Reply with quote  Mark this post and the followings unread
Hello!
This is just one more 4069 SVF, but with additional BP feedback, which makes it more "waspy".
Example with 561LN2, sorry for accent: https://www.youtube.com/watch?v=6Vt1AKOakLE
 Filesize:  118.38 KB
 Viewed:  3059 Time(s)
Audio files: 25
PostPosted: Sun Jul 01, 2018 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Filer sounds good and dirty !! What is the range of CV on the FET transistors?
Bill
Hammer
PostPosted: Sun Jul 01, 2018 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello, Bill!
The range of CV is between 0 and 2.5V
Audio files: 25
PostPosted: Mon Jul 02, 2018 8:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the reply. Going to save this schematic and this information. The CV can always be scaled in other applications. Would be good to get my hands on the 561LN2 to hear a difference. For now the 4069 will suffice.
Hammer
PostPosted: Mon Dec 10, 2018 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
One more 5V single supply 4069 SVF, very musical and simple, inspired by this topic: http://www.electro-music.com/forum/topic-29678.html
Tested on breadboard.
 Filesize:  109.8 KB
 Viewed:  1857 Time(s)
J-chot
PostPosted: Mon Dec 10, 2018 8:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
NICE!!!! That's REALLY warm and great sounding!!!
I[m totally going to build this when I get home from work tomorrow!
your accent is awesome!
J-chot
PostPosted: Mon Dec 10, 2018 8:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
What is the Drum envelope generator you're using???
oh man, how does that resonance even work?
Hammer
PostPosted: Tue Dec 11, 2018 12:36 am    Post subject: Reply with quote  Mark this post and the followings unread
This one:
Posted Image
Are you mean the second filter?
I do not really understand why, but when you block resonance with parallel cap. in long fedback line, it's starting to resonate when you change coefficient of summing amp.
cslammy
PostPosted: Mon May 20, 2019 11:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi there Hammer
I created a PCB and built up your "screams wilder" Russian 4069 circuit this weekend. Used a Russian 4069UB. sounds GREAT Very Happy maybe a cross between a MS20 filter with peak cranked up and a synthacon, but gnarlier!
Keep up the good work!
Hammer
PostPosted: Wed May 22, 2019 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
One more CMOS LPF design!
I've read the article written by people who are much smarter than me: https://ftp.unpad.ac.id/orari/orari-diklat/teknik/homebrew/filter/active-filter/docs/A%20Beginners%20Guide%20to%20Filter%20Topologies.htm
New design have much cleaner resonance and less distortions.
1. If you will remove ~1k resistors, you will have no resonance when filter is open.
2. Feedback resistor should be a little bit less 100k:
> 100K - distortions
< 100K - more resonance, lower amplification
Just find your value.
Certainly better to use 561LN2 Very Happy
CD4069 / 561LN2 LPF
 Filesize:  115.49 KB
 Viewed:  1315 Time(s)
Hammer
PostPosted: Wed May 22, 2019 12:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
I will remove stereo pot. with digital potentiometers and piece of Arduino - ATtiny85.
And here are some samples of previous LPF version. New version is not very different.
http://electro-music.com/forum/download.php?id=46550
http://electro-music.com/forum/download.php?id=46546
http://electro-music.com/forum/download.php?id=46545
Hammer
PostPosted: Sun May 26, 2019 9:22 am    Post subject: Reply with quote  Mark this post and the followings unread
And here is the newer newer version. Almost linear resonance and a loads of it. Self oscillation and so on. This version works better with CD4069 unbuffered. Low pass bypass and hipass also available.
Tested on breadboard with digital potentiometers.
4069_LPF_RAVEN_L.mp3
 Filesize:  77.11 KB
 Viewed:  1914 Time(s)
4069_LPF_RAVEN_B.mp3
 Filesize:  91.92 KB
 Viewed:  1842 Time(s)
4069_LPF_RAVEN_RIFF.mp3
 Filesize:  190.03 KB
 Viewed:  1886 Time(s)
 Filesize:  122.8 KB
 Viewed:  1151 Time(s)
cslammy
PostPosted: Sun May 26, 2019 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
To change cutoff with CV use digital 100K pots and an arduino right?
I have the audio demo of the original design finished, will post it soon.
Hammer
PostPosted: Sun May 26, 2019 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not exactly. I do not use CV, Arduino have simple decay envelope function and analog pot. to control decay. It's only gate signal here.
Digital 100k pots connected in series with analog 100k pots to have manual control of cutoff. Low end of one digital pot is connected to the 1/2 Vcc, it works like VCA.
I haven't decided yet, do I need fully functional ADSR, CV, or just single pot, like Korg Monotron have. Single pot also can have slow and fast attack angles.
You can hear some hiss sounds, but this is because it's builded on breadboard and use USB power right from PC without any capacitors.
cslammy
PostPosted: Tue May 28, 2019 6:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Hammer
I will breadboard when I have some time and see how I can interface with my system (0-5 or 0-8V CV control, 10V p-p audio waveforms).
Good filter to experiment with arduino controlled digital pots!
Blog post of the original circuit (which sounds good!) coming soon--it's working, demo is done.
cslammy
PostPosted: Fri May 31, 2019 8:02 am    Post subject: PCB/blog of Hammer's design Reply with quote  Mark this post and the followings unread
Hi there, with Hammer's help I fab'd a PC of his initial design, and yes, it really does scream wilder with a Russian 4069. Interesting VCF I think!
https://audiodiwhy.blogspot.com/2019/05/hammer-cocktail-low-parts-count-4069ub.html
Sound clip here:
https://soundcloud.com/cslamm/hammer
4069UB in audio (op amp? We dont need no stinking op amps!)
https://audiodiwhy.blogspot.com/2019/05/a-rolling-stone-gathers-no-cmos-4069ub.html
Thanks to Hammer for help with this project and post! He's continually updating and I may fab a Eurorack version down the road.
Hammer
PostPosted: Fri May 31, 2019 8:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you a lot!
oberkorn
PostPosted: Tue Jan 05, 2021 1:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello Hammer and all of you
reviving this thread after 1.5 years with a question as I have started to test your filter.
when I check for Russian CMOS chip equivalents I find no 4069.
and К561ЛН2 is supposed to be a 4049 according to this page http://zpostbox.ru/ussr_analogs_of_cmos_ic.html
is this correct? not a problem anyway but important to consider regarding the pinout Cool
Posted Image
 Filesize:  162.3 KB
 Viewed:  496 Time(s)
Hammer
PostPosted: Tue Jan 05, 2021 2:24 am    Post subject: Reply with quote  Mark this post and the followings unread
К561ЛН2 have the same pinout as 4069U. And both inverters are unbuffered.
К561ЛН2 have higher frequency of operating i.e. higher "resolution".
Check this PDF https://static.chipdip.ru/lib/031/DOC001031294.pdf
Now I think that any another unbuffered CMOS hex inverter with high frequency of operation (> 2 Mhz) will be better than too old but cool К561ЛН2. Maybe 4049.
oberkorn
PostPosted: Tue Jan 05, 2021 2:29 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you for the clarification!
elrengofa
PostPosted: Sun Sep 14, 2025 5:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello! Greetings from Argentina. While searching for variable filter circuits, I ended up here. I designed a PCB based on the schematics I found in this forum and added an output for the high-pass filter.
PCB.pdf
pcb
 Filename:  PCB.pdf
 Filesize:  15.89 KB
 Downloaded:  279 Time(s)
LAYOUT.pdf
layout
 Filename:  LAYOUT.pdf
 Filesize:  30.74 KB
 Downloaded:  261 Time(s)
ESQUEMA.pdf
schematic
 Filename:  ESQUEMA.pdf
 Filesize:  15.34 KB
 Downloaded:  304 Time(s)
