Posted: Sun May 13, 2018 11:49 am Post subject:
Suitcase lunetta tour/AD generator
Hello,
I've been reading this forum for around a year and built my lunetta with your help, however I never got around to registering and posting something. Sooo, here's the suitcase lunetta, audio sample attached (EQ and a bit of reverb added).
I don't have exact schematics for it, but here are the resources I've used to build it, hope it will be useful to someone.
1) 4067 based 16 step sequencer.
Mostly relied on this schematic but used 4067 instead of 4051: https://hackaday.com/2015/02/23/logic-noise-the-switching-sequencer/. The outputs from 4040 to 4067 can be patched. Also there is a clock output to drive the second sequencer or something else. For 40106 range 20K pots and 1uF caps were used, it sounds a bit nicer that way.
2) 4051 based 8 step sequencer.
Same as 1)
3) Passive 6 channel mixer.
Nothing special about this one, just pots to output
4) 4 octave synth with vibrato
Pretty much relied on this schematic: http://www.electro-music.com/forum/topic-45583.html. Used 4068 instead of diodes to form AND gates. I recall reading somewhere that diode AND gates might be a bit unstable. For vibrato more simple circuit was used - filtered 40106 square wave to resemble a sine instead of generating an actual sine
5) 40106 x 6 oscillators
Just simple oscillators. 3 x audio range and 3 x LFO
6) R-2R ladder
Used this website to build it:http://castlerocktronics.com/modular.html. I thought that it could make cool waveshapes, but after building it I discovered that it does divides the frequency greatly, but it can be used to drive a VCO or modulate oscillators/sequencers.
12) 40106 x 6 oscillators
Same as 5) but added option to modulate the waves through a cap or a pot. There's a nice video about it on youtube: https://www.youtube.com/watch?v=FaoJaLmZaL4
Found another suitcase near the dumpster outside my house, so I'll make another one
The actual question I have is regarding attack/decay generation for a sequencer. It has a clock output, so I think I could use it as gate/trigger (I still don't fully understand this) for VCA, but the schematics are a bit too difficult for me. Are there any resources for this or simpler schematics?
Audio files: 730
Posted: Mon May 14, 2018 10:25 am Post subject:
Excellent build with a nice selection of modules. I like that you put a 4 octave synth with so many buttons in there.
Your post gave me a boost to continue with my own lunetta in a suitcase.
Do I understand it correct that you want to use an AD generator + a VCA clocked by the sequencer ?
If you a refering to the sequencer from hackaday than you can use any output from the 4040 but most likely
you want to use output Q4, at least if you connected it in the same way.
