rafal_sommerfeld
Posted: Sun Nov 19, 2017 8:45 am Post subject:
CC assignments behringer compact |
Quick question, does anyone know how to assign expression to digital mixer.? Like a expression, velocity, tremolo etc. I have behringer compact and I have tried with X touch editor but even when I assign it, it doesn't work with my Cubase, and also I have heard that even if some how people manage to do it, seems like a people have problem with recording with expressions, apparently expressions doesn't record during recording. Also what is different between Mackie control mode and standard? Alternatively I could use Ableton or anything just to get that done.
Does any one who to do it step by step? I can even pay for solution as I struggle with it few days
Many Thanks guys
Back to top |
Joined: Aug 08, 2009 Posts: 1082 Location: Out scouting . . .
Posted: Sun Nov 19, 2017 12:06 pm Post subject:
It used to be that "Expression" was defined as CC [Continuous Controller] #11 and was something like a sub-level of CC# 7 [volume]. For example, a breath controller might output values for CC#11 which could be mapped [routed] to any synth parameter that was mappable to CC#11.
Since then, people have used "expression" [also "expressive midi"] to mean a variety of things. That being said, it sounds like you are asking how to record CC#11 [expression], but I am not sure.
I am not familiar with the controllers you mention but have had success with reading manuals and sometimes figuring it all out.
Do you have links to the pdfs for the manuals of the gear and software you are using?
Steve
Is this what you are using? https://www.music-group.com/Categories/Behringer/Computer-Audio/Desktop-Controllers/X-TOUCH-COMPACT/p/P0B3L/downloads If so, are you trying to assign the faders to CC#11 so you can play some gear that responds to it?
I opened the X-Touch editor in dummy mode (since I don't have an X-Touch device) and it seems straight forward--set up a button, fader, encoder, etc. to CC#11 and set up the behavior, the min. value, the max, value, etc.
Once you do that, if you have a tool like midi-ox, you can check to see if the encoder, or whatever you used, is outputting CC#11.
Your recorder [e.g., DAW, sequencer] should be set up to record CCs. Also, if there are midi data filters somewhere in your data chain, make sure CCs in general and CC#11 are not being filtered out.
I assume your gear/software is set up so that the controllers send data where you want in both record and playback modes. Some times gear and/or software can do that directly; sometimes you need some sort of midi router [gear or software utility]. |
rafal_sommerfeld
Posted: Sun Nov 19, 2017 1:41 pm Post subject:
| Thanks Music Man, I will check that and let you know straight away. |
rafal_sommerfeld
Posted: Mon Nov 20, 2017 4:45 pm Post subject:
Hi Music Man,
I did as you said, I have oppened x touch editor and assigned cc11 on first fader, also I have checked with midi-ox and its showing that it is CC11, but when I open cubase fader is not respondig, only when I swiched to MC mode, the are 2 faders working automaticly which is fader 1 for volume for track, and fader 8 which is the one with main volume. Any solution ?
Many Thanks |
