 Forum index » electro-music.org » Streaming Radio Station
Antimon Waves
Page 2 of 3 [75 Posts]
Audio files: 522
PostPosted: Wed Aug 30, 2017 3:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice indeed! Cool
Audio files: 373
PostPosted: Thu Aug 31, 2017 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Rob! Smile
Audio files: 373
PostPosted: Fri Sep 01, 2017 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Antimon Waves #6!
This was a bit more droney and relaxed I think. Probably because I was a bit tired... drunken
Got inspired by robsol's work with the Kaossilator, so I tried to pull a large part of the mix through the octatrack and sequence that thru machine to make it stutter a bit when I threw the slider to the right.
Antimon Waves 2017-09-01.mp3
 Filesize:  94.37 MB
 Duration: 1:01:20
 Viewed:  3482 Time(s)
Audio files: 373
PostPosted: Fri Sep 08, 2017 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's #7.
This one went so-so as far as handling the gear goes. I went for the Nord Modular G2, with a bunch of sequencers mapped onto the panel, which is a great concept, but unfortunately stuff didn't work perfectly when sending midi to the four rockets I had connected, plus it fell out of sync with the octrack running master midi clock. Oh well, some sounds and beeps and vocal samples happened anyway, so here is the recording. Smile
Antimon Waves 2017-09-08.mp3
 Filesize:  87.87 MB
 Duration: 1:01:10
 Viewed:  3484 Time(s)
Audio files: 373
PostPosted: Fri Sep 15, 2017 2:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Show number eight!
Despite having some troubles with sequencing on the G2 last time, I didn't want to give up on that, so did that again, this time sending midi to the Dominion 1 and working three sequencers on internal sounds. Something didn't work as I planned for the internal things, but the Dominion thing worked fine.
I kept my four Rockets from last time, but this time I sequenced them from the Octatrack again, which brought some nice sounds. The Rocket has a life of its own, there's usually a sound to be found however you tweak the knobs, but you don't always know what it's going to be. Smile I got a cool fuzzy bass sound going near the end.
Besides that, PO Rythm for drums, SQ-1 sequencing my modular with the polivoks filter (I think I'm starting to get the hang of the SQ-1), a Volca Bass.
Also, I have caught a cold which may have affected the set a bit - at the least I only set up stuff that I could reach while sitting on my stool, as I didn't feel like standing or walking around too much - my back has been complaining after previous sets and it's a bit worse right now.
Antimon Waves 2017-09-15.mp3
 Filesize:  96.74 MB
 Duration: 1:02:56
 Viewed:  3483 Time(s)
Audio files: 373
PostPosted: Fri Sep 22, 2017 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Antimon Waves #9! Approaching the 10 show jubilee!
I used the same setup as last time, with some fixes on the g2 stuff that didn't work like I wanted last time (surprise! it didn't fully work this time either Wink ). Getting more and more fluent on the g2 panel.
Antimon Waves 2017-09-22.mp3
 Filesize:  101.18 MB
 Duration: 1:02:55
 Viewed:  3472 Time(s)
Audio files: 522
PostPosted: Fri Sep 29, 2017 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice 10th show Stefan! well done afro
Audio files: 373
PostPosted: Fri Sep 29, 2017 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Rob! Very Happy As befits the #10 jubilee it was a bit of a mess, chat room issues, my stream crapped out, I couldn't use half the synths I had hooked up properly because I had forgotten to connect the to the MIDI chain, but oh well.. Here's a recording.
Antimon Waves 2017-09-29.mp3
 Filesize:  87.07 MB
 Duration: 1:01:01
 Viewed:  3460 Time(s)
Audio files: 373
PostPosted: Fri Oct 06, 2017 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
And it was time for #11, and it went more according to plan, and there was only a small stream glitch, and it was a show.
Antimon Waves 2017-10-06.mp3
 Filesize:  81.62 MB
 Duration: 1:00:46
 Viewed:  3491 Time(s)
Audio files: 163
PostPosted: Sat Oct 07, 2017 3:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice set Stefan Smile
Audio files: 373
PostPosted: Sat Oct 07, 2017 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers Dave, much appreciated! Very Happy
Audio files: 522
PostPosted: Wed Oct 11, 2017 5:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I agree, lovely set. Cool
You seem to be pretty much in control of the loop, but at the same time keeping it interesting. Nicely done.
Audio files: 373
PostPosted: Thu Oct 12, 2017 11:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cheers Rob, thanks! Very Happy
I think I would like to be a bit less in control, to make things happen a bit more quickly, but that could just be me. Smile
Audio files: 730
PostPosted: Fri Oct 13, 2017 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
you could tie one hand behind your back for less control Wink
I am looking forward to it. My head is a bit clogged because of a cold so maybe it will shake things loose.
The Golden Shrimp Guild
Airlock
Audio files: 54
PostPosted: Fri Oct 13, 2017 1:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Antimon wrote:
A picture of today's setup. Smile
Looking at the pic again I realized that you may at some point be in need of some of the rare OEM parts that I happen to have some numbers of...
...so if you ever find yourself in need of replacement bells for that vintage phone, I'm your man. Laughing
Audio files: 373
PostPosted: Fri Oct 13, 2017 2:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nummer tolv - show #12 done and dusted! Same setup as last time, with additional special drum patching on the Nord Modular, heard especially at the very end. Went well I think!
Antimon Waves 2017-10-13.mp3
 Filesize:  94.08 MB
 Duration: 1:10:12
 Viewed:  3394 Time(s)
Audio files: 730
PostPosted: Fri Oct 13, 2017 5:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think that went REALLY well cheers
Audio files: 373
PostPosted: Sat Oct 14, 2017 1:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers PHOBoS, glad you agree! Very Happy Wink
Audio files: 373
PostPosted: Fri Oct 20, 2017 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Show #13! Same setup as last time, with a pinch of FS1R thrown into the mix. Had a bit of a drop while streaming so I threw in some extra minutes.
Antimon Waves 2017-10-20.mp3
 Filesize:  104.55 MB
 Duration: 1:17:40
 Viewed:  3411 Time(s)
Audio files: 373
PostPosted: Sat Oct 21, 2017 2:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
There will be no Antimon Waves next friday, the show will return the friday after that.
Audio files: 373
PostPosted: Fri Nov 03, 2017 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Antimon Waves #14 was a great success, apart from Audacity crashing and losing the recording. Wink I'll have a look later to see if I can salvage something.
Audio files: 373
PostPosted: Fri Nov 10, 2017 3:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Show #15! Changed the setup a bit.
Prepared some guitar clips and set up for some live looped e-piano on the Octatrack.
Made a filter pluck patch for the G2, that I set up in three slots.
Mixed the four Rockets I've been using for many Waves, but this time I pulled that mix through the Chase Bliss Brothers distortion pedal.
Plus some usual suspects - analog synths, PO Rythm, OP-1...
Antimon Waves 2017-11-10.mp3
 Filesize:  93.96 MB
 Duration: 1:03:59
 Viewed:  3308 Time(s)
Former site admin
Audio files: 353
PostPosted: Fri Nov 10, 2017 3:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Loved it!
Audio files: 373
PostPosted: Sat Nov 11, 2017 3:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jan! Very Happy
Audio files: 373
PostPosted: Fri Nov 17, 2017 3:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Numero 16!
Tried to patch up some dirtier sounds for this one, especially some kind of FM filter patch on the G2. Held notes longer. Some U-Bass too.
Antimon Waves 2017-11-17.mp3
 Filesize:  88.7 MB
 Duration: 1:03:40
 Viewed:  3358 Time(s)
