ADSR BS170 Addition
Page 1 of 1 [5 Posts]
Hubaswift
PostPosted: Fri May 26, 2017 8:03 pm    Post subject: ADSR BS170 Addition Reply with quote  Mark this post and the followings unread
I was surprised to find that when I went to start populating the ADSR PCB today, that there was a BS170 that wasn't there last time I built the circuit. I don't have any BS170 lying around, so I was wondering if to get it running I could wire pin 7 of the 7555 to the sustain potentiometer to bypass the JFET. Would that work?
yusynth
PostPosted: Sat May 27, 2017 7:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes it would and it was the case on the previous version. This FET was added to ensure that the DECAY path be deactivated when the GATE returns to 0V and that the cap will only discharge through the RELEASE path.
Yves
Hubaswift
PostPosted: Sat May 27, 2017 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Alright, thanks!
ricochet
PostPosted: Tue Oct 03, 2017 3:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
am I right, that this is the latest version of ADSR-PCB ?!:
"ADSR 2017 wiring" and "ADRS FINAL Layout 2017" (from Yusynth-site)
Now I've got six ready etched ADSR PCBs (and others) from a friend.
They don't look like that obove, but after all I've found some more (older?) PCBs layouts in the net.
My Questions:
Could I use / build these old one ?
Are there any mistakes in it ?
so long
Gerd
wiring for "Final layout"
 Filesize:  123.5 KB
 Viewed:  7227 Time(s)
from Yusynth page "ADSR final Layout (2017)
 Filesize:  133.2 KB
 Viewed:  527 Time(s)
this pcb I have
 Filesize:  96.79 KB
 Viewed:  525 Time(s)
another old version
 Filesize:  228.88 KB
 Viewed:  496 Time(s)
yusynth
PostPosted: Tue Oct 03, 2017 3:59 am    Post subject: Reply with quote  Mark this post and the followings unread
You may build those they will fine as well, the latest version is an improvement and the inclusion of a print an Eurorack psu socket.
Yves
