toneburst
Posted: Tue Nov 18, 2008 5:31 am Post subject:
Modular G2 NRPN Output |
quick question:
anyone know if it's possible to output NRPN values from the MIDI out of a Nord Modular G2 Engine? I have a synth that responds to NRPNs, but not CCs, and was wondering if there was a way I could control it via the G2.
a|x |
jksuperstar
G2 patch files: 18
Posted: Tue Nov 18, 2008 9:19 am Post subject:
Yes! I'm at work, so I can't post a patch. But if you look up the constructs of an NRPN, it's just 4 CC msgs sent back-to-back. 2 for address, and 2 for data. Just link together 4 CC-send modules.
For starters, read this:
http://www.philrees.co.uk/nrpnq.htm |
toneburst
Posted: Tue Nov 18, 2008 11:32 am Post subject:
Hi there,
thanks for getting back to me!
Wouldn't the messages need to be sent in the right order though? Not sure how you'd make sure this happened. Maybe you've done it though...
I'd love to see a patch, if you have.
a|x |
Former site admin
Joined: Apr 03, 2004 Posts: 24864 Location: The Netherlands, Enschede
Audio files: 353
Posted: Tue Nov 18, 2008 2:13 pm Post subject:
| toneburst wrote: | | Wouldn't the messages need to be sent in the right order though? Not sure how you'd make sure this happened. |
You can chain the CC send modules using the two leftmost connectors, I think the help explains it. Additionally you might want to add one or two sample and holds to make sure no data is sent unless the first change input gets triggered, or build a change detector that triggers the whole lot. |
toneburst
Posted: Wed Nov 19, 2008 6:52 am Post subject:
Ah, thanks for the tips. I will try this as soon as I get a chance.
Thanks again,
a|x |
gauthier
Posted: Fri Mar 31, 2017 2:25 pm Post subject:
I wonder if there is a building block which has been shared regarding sending NRPNs, I've found a patch which seems to receive those but not for sending (http://electro-music.com/forum/viewtopic.php?highlight=nrpn&t=9977).
Also, if there are ways to scale back a single 0-127 constant to an arbitrary "more than 7 bit" range that will be a nice complement. |
Electromagnetic Wave
G2 patch files: 38
gauthier
Posted: Sun Apr 02, 2017 1:30 am Post subject:
Hello, thanks I didn't find this post!
I've tried it, it seems to be seemingly correct, but I haven't figured the range yet.
I'm trying this with Andromeda filter, and it requires values from 0 to 31 for CC6 (coarse) and 0 to 127 for CC38 (fine, I've added a module for that one), nor I've had success to hear proper sweep (even coarse) so far.
It seems at times the CC won't be sent in good order or consistently also.
I'll need more experimentation but this seems so close... Maybe I just need to do it with a small program on my computer instead but this is a bit cumbersome if the G2 can do it. |
Former site admin
Audio files: 353
Posted: Sun Apr 02, 2017 2:30 am Post subject:
| You can control the order things are sent in by chaining the send in and outputs. |
gauthier
G2 patch files: 38
Posted: Sun Apr 02, 2017 6:22 am Post subject:
From Tim Kleinert :
| Quote: | | The problem in the NRPN scenario is that the first two CC messages of the NRPN protocol do not change. So, one has to detect a change in the value to be sent and use this to trigger the sending of the entire NRPN string. |
http://www.electro-music.com/forum/post-393441.html#393441
Did you tried the patch from Sinuosity or Tim Kleinert ? |
gauthier
Posted: Sun Apr 02, 2017 6:25 am Post subject:
Electromagnetic Wave, yes I've changed Tim's patch as shown in the picture.
It does send the 4 CC, albeit sometimes not properly as it kind of trips up (noticed especially when decreasing the value) and I'm not able to figure out how to do scalling to have something smooth happening. |
Former site admin
Audio files: 353
Posted: Sun Apr 02, 2017 7:23 am Post subject:
Random transmit orders could be caused by (from the module help) :
| Quote: | • Note that as soon as the Value changes, either by manually turning the knob or by inputting a changing control signal, the module will output MIDI data even if the logic Send input is not activated.
So you'll need to sync changes there ... hairy stuff  |
