djfoxyfox
Joined: Feb 05, 2003 Posts: 3706 Location: Nazareth, Pennsylvania, USA
Audio files: 9
Posted: Wed Jun 05, 2013 7:34 am Post subject:
Mastering Software for Burning the Master CD |
The last stage of matering a CD is to actually burn your tracks to CD, i.e. authoring. What software do you use? Does it let you select how much blank space there is between tracks? Is that one setting for the entire disk or can that be set per track?
Some tracks are meant to run together with continuous sound and others require some silence. I am not interested in all the various ways people accomplish this using run-of-the-mill music players that also happen to allow you to rip and burn CDs. At this point of my investigation, all I want to know is what are the "proper" mastering/authoring programs that are available. _________________ Bill Fox------------------|\-------------
-----------()----soundscapes.us/bill |
Audio files: 21
Posted: Wed Jun 05, 2013 9:42 am Post subject:
Simply a Red Book compliant authoring application? Do you plan to send a file to a CD manufacturing plant? Or do you plan to burn your own CD-ROMs? _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Audio files: 21
Posted: Wed Jun 05, 2013 9:56 am Post subject:
A proper red book CD is essentially a continuous stream of data, and the "songs", offsets, or tracks are written in the TOC that is at the start of the data stream. You will also want to handle the ISRC. And also DDP.
Try http://www.sonorissoftware.com ? _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
djfoxyfox
Audio files: 9
Posted: Wed Jun 05, 2013 10:45 am Post subject:
| elektro80 wrote: | | Simply a Red Book compliant authoring application? Do you plan to send a file to a CD manufacturing plant? Or do you plan to burn your own CD-ROMs? | Excellent question. The anwser is "Yes."
I'd want to be able to do both. Sometimes, a release needs to be manufactured and sometimes a CDR release is good enough. _________________ Bill Fox------------------|\-------------
djfoxyfox
Audio files: 9
Posted: Wed Jun 05, 2013 10:50 am Post subject:
| elektro80 wrote: | A proper red book CD is essentially a continuous stream of data, and the "songs", offsets, or tracks are written in the TOC that is at the start of the data stream. You will also want to handle the ISRC. And also DDP.
Try http://www.sonorissoftware.com ? | I've dealt with ISRC codes before when releasing albums for my Progressive Rock band Pinnacle. I'll have to google DDP. Thanks for the link. I'll read up. _________________ Bill Fox------------------|\-------------
Audio files: 21
Bertsbeats
Posted: Sun Feb 12, 2017 1:13 pm Post subject:
Mastering |
Izotype is good but expensive you can master now with a lot of daws like using fl studio _________________ The trance tutorial blog http://edmtutorials4u.blogspot.com |
DES
Posted: Fri Feb 17, 2017 8:06 pm Post subject:
I use Wavelab, albeit an older version (4 I believe) I've thought about upgrading but it's a bit pricey though to be honest I think its worth it. Good for mastering, track layout, CD text, etc.. _________________ Dave
www.davesneed.com |
