Posted: Tue May 17, 2016 12:09 pm Post subject:
thru zero VCO Subject description: 4. (SAW) Version added
I drew up and soldered this,
but Iam not shure if this is "thru zero ish" enough, because not all (or no) of the zero crossings are looking so nice roundish like i saw it elsewhere
i really like to haer your opinions
cheers bb
gabbagabi
Filesize:
93.38 KB
Viewed:
1323 Time(s)
Filesize:
59.77 KB
Viewed:
1071 Time(s)
those shapes look interesting for such a small parts count , congrats on the build , could you post some recording from the oscillator , thanks for sharing _________________ http://synthacks.blogspot.com/ шематикс
TZ VCO can go to 0 herz, oszillation stops. Only TZ VCO can do.
Modulation TZ produces FM-sounds when modulation is going TZ.
In your soundsamles I can´t hear either.
Its seem you are discharching the integration cap depending of sign of modulation CV, but it is not going through zero. It produces a rich color of waveforms. For real TZ you need a cap in the plus and minus part.
klangbauköln
Sorry, but I don't agree. Both the images and the sound samples seem to confirm that's through zero to me. The images clearly show the waveform slowing down towards zero, hitting zero at 0V, and then reversing, as you'd expect.
Similarly, the sound samples sound pretty "FM" to me. Ok, 111Hz isn't a high enough frequency to give you the type of clanging metallic noise you might expect, but it definitely sounds like FM.
It seems like there might be an improvement to be made to try and get the offsets of the two directions identical so that there's no glitch when it crosses over, but given the small number of components, I think it's impressive already.
Joined: Feb 01, 2015 Posts: 15 Location: Hiltown, Germany
Posted: Tue Aug 30, 2016 6:40 am Post subject:
I don´t really get what´s going on here, but the offset differences are only on the saw wave. I guess it´s a result of the resistor change needed to magically create the saw...
Could a capacitor on the output even this out, or is more magic needed?
Well, I should just build this great simple circuit and try it myself, right?
Edit: Another thing I don´t understand is how the pitch pot works. If I put it to ie 8V, shouldn´t it always stay positive with a +/- 5V input?
Posted: Mon Sep 12, 2016 3:03 am Post subject:
why i got no eMail notification on your posts? Anyway.
I used the Hangover yesterday to going back to this circuit.
First i found a second TZVCO Idea in the folder that ive forgott totally, starting point was the nicolas3141 supersimple saw vco.
Then i played around with offset compensation for the SAW, by using a double switch.
After that i had some fun by simulating the modulation of some points in the circuit.
@soundworker: nice find, and for osamu a, lets say, "easy" design
@moosgummi: you are rigth, i was thinking about that myself to, may the pitch polarity should follow something, but what: the LFO polarity? hm, i guess TCVCOs living of modulations (that are going thru Zero pitchCV ), otherwise they just producing waveform like "normal" vco do. we will see where it goes...
Posted: Sun Aug 27, 2017 4:21 am Post subject:
ok
first: basic tone, sin-out of common vco feed into tzvco. just to visualize the shape of the wave.
Second: saw-out of common vco with ADSR-Pitch feed into a modulated VCA to tzvco- tcvco tri output. Hand crancked modulation sense pot on tzvco.
Third: Adsr is modulating the pitch of the common vco and the VCA , VCA out to TZVCO In. Then i switched from low(635pfF+2,2nF) to high (635pF). Hand crancked modulation sense pot on tzvco.
Fourth: out of common vco feed into modulated VCA then tzvco, i changed the modulationg waveforms from Sine - tri -saw to rec( i handmodulated the pw a little bit)
For me analog FM is kind of "unstable" even more if u work with more then two oscilators and feedback. So my own rule is if u find a nice sound - press instantly record, u will never find it back.
Second thing is u cant play it "tonaly". Just record that sound and than may pitch it in the DAW.
gl,
hf
gabbagabi tzvco basic sinus.mp3
Filesize:
61.35 KB
Duration:
0:04
Viewed:
2203 Time(s)
Patch tri out - saw mod.mp3
Filesize:
518.78 KB
Duration:
0:33
Viewed:
2190 Time(s)
same adsr patch switch from low to high.mp3
Filesize:
1.26 MB
Duration:
1:22
Viewed:
2160 Time(s)
sinusout-mod-by-sin_tri_saw_rec.mp3
Filesize:
457.96 KB
Duration:
0:29
Viewed:
2115 Time(s)
Filesize:
72.38 KB
Viewed:
634 Time(s)
Joined: Dec 25, 2007 Posts: 251 Location: Sydney, Australia
Audio files: 27
Posted: Thu Dec 14, 2017 7:23 pm Post subject:
Nice trick with the comparators!
(Oops I misread them; I thought you had put inverting halfwave rectification, adding this at twice the signal level, so that the negative saw got reflected about 0V. That would be a nice circuit too.)
Posted: Sat Dec 16, 2017 6:25 am Post subject:
Hi Rick,
good idea and i will make a note about it, but i guess i will stick to the comparators.
I have putted two comparators because after the first one u could find some "ripples" in the square wave (there where the Saw touches gently the 0V line), after the second they where boosted out.
R11 and R12 in the schemo have probably wrong values, they are more likely 10k or 100k, have to confirm this.
I would call this first version of this circuit "the precise one". I have already simulated a component saving version, which is expected to be less precise.
I have attached a preview of it.
a nice weekend for us all
cheers, bb
Filesize:
93.09 KB
Viewed:
666 Time(s)
I really like to follow the process of design of this VCO, but the voltages you mention in this diagram are confusing to say the least.. _________________ my synth
Posted: Wed Mar 07, 2018 8:11 am Post subject:
sorry i thought nobody is listening
the green one is the CV
the red one we could call the RAW-SAW
the blue one is the final result after processing it with a trigger which changes polarity when the voltage of the raw-saw (not the frequency) goes thru zero.
a part of that rectangle signal is then mixed thogether with the RAW-SAW to center it around 0V.
Haha, no I mean the voltages you place at the opamps, like vcc, vdd, 15v and -15v.
Some just seem to float and not connected to anything _________________ my synth
