sonicwarrior
Joined: Dec 22, 2005 Posts: 266 Location: Cologne, Germany
Posted: Tue Oct 15, 2013 12:38 pm Post subject:
| rogerlatur wrote: | | I mean why not always using a capacitor with the highest voltage value? |
Size and price. |
Joined: Jan 31, 2003 Posts: 18507 Location: Durham, NC
Audio files: 266
Posted: Tue Oct 15, 2013 2:15 pm Post subject:
| rogerlatur wrote: |
Now what I don't understand is why using 25v when 50v can handle more voltage ? I mean why not always using a capacitor with the highest voltage value ? |
No reason not to use a higher voltage rating than necessary, but for size and expense.
When the voltage rating is exceeded, they don't always immediately explode. Some will be fine when used at a voltage higher than identified on the can, but beware, the explosion can happen after a long time, even after years. I built a power supply that I used for two years before the capacitor exploded. It worked fine until then. I didn't use the wrong voltage rating, I accidentally wired in up backwards.  _________________ --Howard
my music and other stuff |
caffeine_addict
Joined: May 15, 2015 Posts: 1 Location: Beaudesert, QLD, Australia
Posted: Fri May 15, 2015 4:23 pm Post subject:
I'm in the process of converting designs to use SMD components, (I'm starting with The Peasants Synthbend for a controller), and am currently stuck on the capacitors. Ray Wilson's Single Bus Keyboard controller circuit calls for a .01uf Polycarbonate or Polystyrene Cap, but it seems in SMD that those two materials (As far as I have found anyway) don't seem to be an option.
I'm wondering how the other film types compare for Sample and Hold circuits, films like PPS and PEN seem to be the most readily available, are they suitable replacements?
Sorry if this is a newb question, I've been scouring the internet for days trying to figure it out, and I'm just not reading anything that makes sense to me sorry.
I know I could just use through hole and be done with it, but I like a challenge, and it tickled my fancy to make an SMD modular.
Thanks in advance. |
ablablablablabla
Posted: Tue Feb 09, 2016 4:54 pm Post subject:
Re: How to Choose the right Capacitor |
404
i'd like to read those...
Audio files: 353
ablablablablabla
Posted: Tue Feb 09, 2016 5:11 pm Post subject:
oh, yeah.. lol.
and thank you, glad to be here. been lurking for a while and didn't know where to drop my 1st post so i thought a quick brainless one would be the best.
hello!
VA1
Posted: Wed Jun 19, 2019 9:24 am Post subject:
| Size, check the dimensions, if it dont matters then i choose the highest, they last longer. |
J-chot
Posted: Wed Oct 16, 2019 11:02 am Post subject:
| All the links are dead now... |
Audio files: 353
Posted: Wed Oct 16, 2019 3:26 pm Post subject:
Messy eh .. I found 'm "somewhere" .. and I'm going to commit a coyright crime by just uploading 'm here ...
These seem to be the original ones.
 Download (listen) |
| Filename: |
Picking_Capacitors_1.pdf |
1.95 MB |
| Downloaded: |
812 Time(s) |
 Download (listen) |
| Filename: |
Picking_Capacitors_2.pdf |
1.14 MB |
| Downloaded: |
909 Time(s) |
Posted: Thu Oct 17, 2019 2:28 am Post subject:
Thanks Jan!
I love vintage stuff
Though they were printed in 1980, I think a lot still is valid, but one must take into account that there a at least "some" improvements made in 40 years  _________________ my synth |
Audio files: 266
Posted: Fri Oct 18, 2019 1:52 pm Post subject:
After 39 years, maybe fair use law applies. The sources are cited directly in the attachments. When we are contacted by copyright holders we almost always take things down promptly; so read and memorize.  _________________ --Howard
J-chot
Posted: Sat Oct 19, 2019 12:50 am Post subject:
| It's easier to beg forgiveness than ask permission in these matters... |
