4-octave polyphony, one chip per note
Page 1 of 1 [11 Posts]
trav
Audio files: 17
PostPosted: Mon Jan 11, 2016 1:50 am    Post subject: 4-octave polyphony, one chip per note Reply with quote  Mark this post and the followings unread
For my next lunetta I have been thinking about a polyphonic tone generator which strikes an acceptable balance between having a low chip count and not sounding too awful. Here is what I up with:
I started with the frequency ratios for just intonation...
Code:
   C     D     E     F     G     A     B
  1/1   9/8   5/4   4/3   3/2   5/3  15/8
then divided through by 15...
Code:
   C     D     E     F     G     A     B
  1/15  9/120 1/12  4/45  1/10  1/9   1/8
I decided I could cope with a slightly flat D and F, so simplified to...
Code:
   C     D     E     F     G     A     B
  1/15  1/13  1/12  1/11  1/10  1/9   1/8
...familiar Melody Generator stuff. I'm after polyphony, though, so instead of using a mux to select the divisions, I devote a counter to each note. Each counter is hardwired to reset at the appropriate step using diodes:
Code:
note   count   diodes
 C      14      1110
 D      12      1100
 E      11      1011
 F      10      1010
 G      9       1001
 A      8       1000
 B      7       0111
Then I need to turn the pulses into a squarewave. The 4520 has two 4-bit counters, so I can do the division and then get 4 octaves from the result all on the one chip. A fairly high frequency osc to clock them all, and bingo, plenty of notes to play with.
The concept seemed promising on the breadboard, but I didn't have enough room to fit everything on and get a scale going, so I'll record something once it's soldered.
 Filesize:  33.69 KB
 Viewed:  664 Time(s)
trav
Audio files: 17
PostPosted: Mon Jan 11, 2016 1:55 am    Post subject: Reply with quote  Mark this post and the followings unread
err, CLOCK A on ICs 2 and 3 should obviously be connect with the others.
synaesthesia
Audio files: 87
PostPosted: Mon Jan 11, 2016 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
That's a promising design, trav. I tried the same with shift register dividers and ended up with a sharp E, F and B (around 2%). But it was alright for the intended purpose. Looking forward to hear how your solution sounds.
trav
Audio files: 17
PostPosted: Thu Jan 14, 2016 10:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Okay, it took a bit of troubleshooting. I don't know what made me think I had to count to one less than the desired division. Also the division by 8 can of course be taken straight from Q2 without having to reset the counter. I decided to take the UnB clock from one of the Q outputs on UnA too, instead of the reset line. My neater-than-usual soldering job was ruined by having to make these changes on the board (lesson: get a bigger breadboard!), but in the end it works. Recording and updated schematic below.
Code:
note   division  diodes  tap
 C        15      1111   Q3
 D        13      1101   Q3
 E        12      1100   Q3
 F        11      1011   Q2
 G        10      1010   Q2
 A        9       1001   Q2
 B        8       n/a    Q2
polyphony.mp3
 Filesize:  446.94 KB
 Duration: 0:29
 Viewed:  1495 Time(s)
 Filesize:  34.8 KB
 Viewed:  695 Time(s)
trav
Audio files: 17
PostPosted: Thu Jan 14, 2016 10:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't know whether I expected it to be in better tune or not. Maybe I got the divisions wrong or maybe it's just the compromises I mentioned above. The different "modes" (scales starting on different notes) are interesting, though, and there are plenty of harmonic intervals in there, so I am quite pleased with the result. The principle of selecting seven divisions between 1/8 and 1/16 has yielded a good selection of frequencies to play around with; I am sure I'll be happily patching melodies (and chord progressions???) in no time.
First, though, I have to put together a sequencer: patching up a 32-channel mux for the recording was a job in itself!
trav
Audio files: 17
PostPosted: Fri Jan 15, 2016 3:50 am    Post subject: Reply with quote  Mark this post and the followings unread
some dyads (two-note chords) in this recording
combining more than two notes sounds pretty crunchy with just the diodes; will need resistor mixing to build bigger chords
dyads.mp3
 Filesize:  284.49 KB
 Duration: 0:18
 Viewed:  1498 Time(s)
Audio files: 730
PostPosted: Fri Jan 15, 2016 7:04 am    Post subject: Reply with quote  Mark this post and the followings unread
yep
Say what ?! Shocked
The Golden Shrimp Guild
synaesthesia
Audio files: 87
PostPosted: Fri Jan 15, 2016 12:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Using the highest Qn output from QnA will give a wider clock pulse than the short reset pulse. This only means that the clock for the octave divider (UnB) will arrive a bit earlier, but still with the same frequency.
However, check F, G and A. I believe you need to use Q3 there, not Q2. Otherwise there will be two clock signals for UnB per division cycle instead of one.
Audio files: 730
PostPosted: Fri Jan 15, 2016 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah, that's what I was thinking. I first thought that using the Q3 outputs might give some phasing problems
when mixing the notes, but that shouldn't matter since they are already at a different frequency anyway.
However I do also wonder about those F, G, A notes. I haven't given it much thought yet though, it's just my
first impression from looking at it, maybe it does work correct.
trav
Audio files: 17
PostPosted: Fri Jan 15, 2016 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think it's fine...
Code:
count  0123456789ABCDEF
  Q2   ____----____----
  Q3   ________--------
note
 C(Q3) ________-------
 D(Q3) ________-----
 E(Q3) ________----
 F(Q2) ____----___
 G(Q2) ____----__
 A(Q2) ____----_
 B(Q2) ____----
I don't know why I decided to do it this way. While troubleshooting I thought the short clock pulses might be a problem, so took the clock from the Q output which gave the longest on time per cycle. Of course that wasn't the problem at all, and using the reset line should work.
synaesthesia
Audio files: 87
PostPosted: Fri Jan 15, 2016 3:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Correct, Q2 would go HIGH for the second time at 12 (0b1100), but the counter already resets before that. Cool!
