MS-20 VCF Euro Format (working with sample)
Page 1 of 1 [9 Posts]
jbeuckm
Audio files: 9
PostPosted: Sun Nov 29, 2015 6:37 pm    Post subject: MS-20 VCF Euro Format (working with sample) Reply with quote  Mark this post and the followings unread
This is almost the SchmitzBits schematic but I didn't have a log pot for resonance so the sample is with a linear resonance pot.
Eagle files and a panel layout here: https://github.com/jbeuckm/MS20-VCF
ms20_vcf_ramp_sample.mp3
This shows the LPF input for 30seconds, then the HPF input for the next 30s.
 Filesize:  1.15 MB
 Duration: 1:00
 Viewed:  1747 Time(s)
CV2 with attenuator is available inboard and could also be installed.
 Filesize:  34 KB
 Viewed:  923 Time(s)
isak
PostPosted: Thu Dec 17, 2015 12:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for your work Smile
Hope you can do the polivoks vcf next Wink
Isak E.
jbeuckm
Audio files: 9
PostPosted: Thu Dec 17, 2015 9:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe I will. But, where do I get NTE888M?
jbeuckm
Audio files: 9
PostPosted: Thu Dec 17, 2015 10:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Because of the LEDs, I noticed that I can make the filter self oscillate at very low frequencies UNTIL I plug a cable into the output - then the lights go dark. I wonder if an output buffer would help maintain whatever is going on there when audio is connected?
isak
PostPosted: Thu Dec 17, 2015 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
You can use an LM4250 instead Smile
You just need to change two resistor values.
See all in here:
http://m.bareille.free.fr/modular1/vcf_polivoks/vcf_polivoks.htm
And to this scheme there are also small mods, maybe consider doing them as well Smile
http://modularsynthesis.com/kuzmin/polivoks/djb-polivoks_schematic.jpg
You can read all about it here:
http://modularsynthesis.com/kuzmin/polivoks/polivoks_vcf.htm
Thanks again for your hard work!
isak
PostPosted: Thu Dec 17, 2015 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
What scheme did you used?
jbeuckm
Audio files: 9
PostPosted: Tue Dec 29, 2015 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's this with 13700 directly subbed for ca3080:
http://www.schmitzbits.de/ms20.html
Does anyone know where to get an Eagle library for the LM4250? I'm working on Polyvoks Smile
Update: I found the package here: https://github.com/pichenettes/shruthi-1/blob/master/shruthi/hardware_design/pcb/Shruthi-Analog-Polivoks-v01.sch
isak
PostPosted: Tue Dec 29, 2015 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Holy s*** Smile
Wow man, thats is amazing!
Ill look for you the eagle files Smile
isak
PostPosted: Wed Dec 30, 2015 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
You can use 741 as an eagle library.
Its the same pinout Wink
