Wildcat VCF-3 PCB
Page 1 of 1 [17 Posts]
vladosh
Audio files: 55
PostPosted: Wed Oct 08, 2014 12:08 am    Post subject: Wildcat VCF-3 PCB Reply with quote  Mark this post and the followings unread
Made a layout for VCF-3 from EFM's Wildcat ,it's Oberheim type VCF i built once ,liked it so i thought i'll make another ..there were two errors in the layout which i corrected ,but there's no silkscreen so if anyone's making it gonna have to follow schematic ,that's what i do )) ,for the expo pair i used BCM857 cause i had some ,you can find SMD to DIP adapter at the Buchla 258 thread ,here is schematic and ready for print layout ,it could have been done better i'm sure ,there's a 10K resistor going from the expo converter to the OTA which is missing in the schematic but is included in the layout
 Filesize:  201.3 KB
 Viewed:  796 Time(s)
 Filesize:  962.81 KB
 Viewed:  1220 Time(s)
Baloo
PostPosted: Tue Oct 21, 2014 2:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot .. I will build this one for sure never enough filters.
Wink
vladosh
Audio files: 55
PostPosted: Tue Oct 21, 2014 2:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sure Baloo , i still haven't finished mine it's almost done , happy building ))
Baloo
PostPosted: Tue Oct 21, 2014 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Vladosh you can try this other 2 pole filter:
http://www.analogsynth.de/synths/mod2/ms20filter/rene_ms20_filter_clone%20rev%204.pdf
vladosh
Audio files: 55
PostPosted: Tue Oct 21, 2014 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
i am sure Rene's MS20 VCF is great ,thanks
vladosh
Audio files: 55
PostPosted: Wed Oct 22, 2014 11:49 am    Post subject: Reply with quote  Mark this post and the followings unread
there's another error in this layout ,the 10K from output to -15 , but there is room to drill two holes and put a resistor there to fit nicely ,i will update the layout
n.d
PostPosted: Sun Feb 08, 2015 10:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Vladosh: please do, I´m very interested in this filter.
isak
PostPosted: Sat Mar 28, 2015 5:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Vladosh.
thank you for the layout.
few questions if i may please.
1. in lopass will it self osc?
2. does your layout is for using BCM857?
3. is it by any chance sound like this :
https://www.youtube.com/watch?v=0ze0O29O11o
if it does, i'm in Very Happy
Isak E.
vladosh
Audio files: 55
PostPosted: Sat Mar 28, 2015 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
this is a really filter that i like , it sounds sweet , and at high resonance it's wild but not as bad like steiner can be .. this pcb layout is bit wrong ..around the expo , i never fixed it , and i lost the layout , i plan on making a oberheim sem type , but discrete ota based if i get it to work i will prolly post the layout , i used BCM transistors and rebuilt it on stripboard , i dunno how close it's to the demo you posted , it sounds nice
isak
PostPosted: Sat Mar 28, 2015 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for replying.
I wating for your oberheim sem Smile
Are you going to make the board using the original scheme?
http://www.pmerecords.com/Docs/SEM-1A.PDF
If so...good luck my friend.
Isak E.
jbeuckm
Audio files: 9
PostPosted: Tue Dec 01, 2015 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Does the schematic above have any errors? I know that the original schemo was missing a resistor and the layout above was missing a different resistor...
Update: I'm thinking that the 4600 series are more refined than the Wildcat was. I am working mainly from the 4621 and have started 4622:
https://github.com/jbeuckm/EFM_VCF3
https://github.com/jbeuckm/EFM_VCF_4622
LFLab
PostPosted: Tue Dec 08, 2015 4:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Joe,
Found your eagle files of the wildcat ringmod you did on github. I reworked them to the other ringmod on Yves Usson's site Very Happy
"Look Ma, no wiring" Smile
Posted Image
Jacks are Thonkiconn, and PCB dims are 50x62 (mm).
isak
PostPosted: Wed Dec 09, 2015 12:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi guys.
Does enybody knows if the mention EMF multiband VCF above is self oscilating in LP or HP mode?
bamboombaps
PostPosted: Sat Dec 12, 2015 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
hey great work! is it possible to share these eagle files?
LFLab wrote:
Hey Joe,
Posted Image
LFLab
PostPosted: Sat Dec 12, 2015 9:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Sure, I am going to look into getting this into github, so everybody can access the files.
bamboombaps
PostPosted: Sat Dec 12, 2015 9:26 am    Post subject: Reply with quote  Mark this post and the followings unread
jackson dancing
isak
PostPosted: Thu Jun 29, 2017 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi jbeuckm did you ever built the VCF3 you posted over the git?
Isak.
