Coming up on Radio 1 at
 Forum index » Clavia Nord Modular » Editor programs » g2ools utilities
Supported Python versions
Page 1 of 1 [7 Posts]
jdd
PostPosted: Tue Dec 01, 2015 12:34 pm    Post subject: Supported Python versions Reply with quote  Mark this post and the followings unread
I'm getting started with g2ools, and trying to run it in several environments, but not having much luck. On Python 2.7 I get errors about __init__ having the wrong number of arguments. On Python 2.5.4 I get an error that the global name "bytearray" does not exist. (I also tried Jython 2.5 and couldn't get g2ools to run there, not because of any problem in g2ools but because Jython has a limit on compiled class size and the Modules class is too big for it).
Does anyone have any advice?
Thanks,
JD
Electromagnetic Wave
G2 patch files: 38
PostPosted: Tue Dec 01, 2015 3:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi jdd,
From my side :
YES! I'ts work with python v2.7.5 ! But not with v2.2.3
http://www.electro-music.com/forum/post-389612.html#389612
jdd
PostPosted: Wed Dec 02, 2015 10:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Nope, I definitely don't have any luck using g2ools from github with Python 2.7.5:
File "g2ools/nord/g2/file.py", line 119, in parse
bitstream = BitStream(data, 7*8)
TypeError: __init__() takes exactly 2 arguments (3 given)
And here's the error with 2.4.4:
File "g2ools/nord/g2/file.py", line 84, in __init__
self.data = bytearray(64<<10)
NameError: global name 'bytearray' is not defined
jdd
PostPosted: Wed Dec 02, 2015 12:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
After some research it seems that bytearray was introduced in 2.6, and the change to object.__init__ was also introduced in 2.6. So I tried Python 2.6.0 and got this:
File "g2ools/nord/g2/file.py", line 912, in read
memview = self.parse_header(memoryview(self.data), filename)
NameError: global name 'memoryview' is not defined
Well, the Python docs say memoryview was introduced in 2.7. Curiouser and curiouser.
G2 patch files: 38
PostPosted: Wed Dec 02, 2015 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
What is your file.py ? Are you sure this file is ok ?
All your files are in the g2ools-1.5 folder ?
Can you try with another .py file ?
jdd
PostPosted: Wed Dec 02, 2015 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was using g2ools cloned from github, not the g2ools-1.5 distribution.
Now I have g2ools-1.5 with Python 2.7 and so far it is looking better.
cappy2112
PostPosted: Mon Mar 13, 2017 9:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very strange. G2ools was created when Python 2.5 was released, so all version of Python 2.x since then should work.
I don't know if someone modified the version on GitHub, because g2ools use to be in mercurial. Fingers (the author) original had it hosted there.
Not sure why the Bytearray issue came up...
