DIY Euclidean Polyrhythm Generator
Page 1 of 3 [71 Posts]
Goto page: 1, 2, 3 Next
sneakthief
PostPosted: Fri Feb 07, 2014 7:04 am    Post subject: DIY Euclidean Polyrhythm Generator
Subject description: for ~$20
Overview:
A couple a years ago, a guy called Tombola made a Euclidean Polyrhythm generator for Arduino. The documentation was very sparse and the code was rough: http://www.muffwiggler.com/forum/topic-45485.html
Here's the original video demo from then:
I cleaned up Tombola's code somewhat, added Offset controls and imported a much better encoder-reading library. Now the encoders work great! I also made a schematic and included much-needed diode input-protection.
[FEB 2015 UPDATE]
User Interface:
When the rhythms are playing, the display flips between page 1 (steps 1-8 ) and page 2 (steps 9-16).
Here's what the display shows...
Row 1: What step is Output 1 playing
Row 2: Output 1 Pattern (steps 1-8 or 9-16)
Row 3: What step is Output 2 playing
Row 4: Output 2 Pattern (steps 1-8 or 9-16)
Row 5: What step is Output 3 playing
Row 6: Output 3 Pattern (steps 1-8 or 9-16)
Row 7: Which channel is selected
- 2 dots on the left for Channel 1
- 2 dots in the middle for Channel 2
- 2 dots on the right for Channel 3
Row 8: Current triggers
1. Input trigger
2. -
3. Output 1 trigger
4. Output 1 off-beat trigger (all the steps when Output 1 isn't playing)
5. Output 2 trigger
6. -
7. Output 3 trigger
8. -
- When you have Channel 1 selected and you rotate the N- and K- and Offset knobs, Rows 1 and 2 will respectively show the pattern length (N), pattern density (K) or Offset (O).
The same goes for Channel 2 (Rows 3 and 4) and Channel 3 (Rows 5 and 6)
- Rotating the Offset encoder clockwise rotates the steps up to one full rotation.
Example:
X 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 - Original 16-step pattern (N = 16, K = 1)
0 X 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 - Offset of 1
0 0 X 0 0 0 0 0 0 0 0 0 0 0 0 0 0 - Offset of 2
0 0 0 X 0 0 0 0 0 0 0 0 0 0 0 0 0 - Offset of 3
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 X - Offset of 15
X 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 - Offset of 16
Updated Code:
http://sneak-thief.com/modular/Tombola_Euclidean_v0.5.zip
(Arduino sketch, LED & Midi libraries & schematic)
Notes:
- I included a modified LED library in case you have an LED-matrix which runs backwards.
- Tombola's code doesn't always recall the flash memory properly when rebooted
These two libraries are included:
- LedControl (or LedControl2 in my zip for led matrices that run backwards)
http://playground.arduino.cc/Main/LedControl
- Encoder
http://www.pjrc.com/teensy/td_libs_Encoder.html
Parts (about $20 USD):
$1.80 USD - LED Matrix
$2.88 USD - Arduino Nano with USB
$3-6 USD - 3x EC11 Encoders with switches
http://www.ebay.com/itm/1Pcs-KY-040-Rotary-Encoder-Module-Brick-Sensor-Development-For-Arduino-/171772090202?pt=LH_DefaultDomain_0&hash=item27fe6a175a
http://www.ebay.com/itm/Nano-V3-0-ATmega328P-Improve-Controller-Board-XTWduino-USB-Driver-For-Arduino-/391000702325?pt=LH_DefaultDomain_0&hash=item5b09753d75
http://www.ebay.com/itm/5PCS-Rotary-encoder-with-switch-EC11-Audio-digital-potentiometer-handle-20mm-/181356150848?pt=LH_DefaultDomain_0&hash=item2a39ab4040
The rest I recommend ordering from Tayda for about $5:
- 6x 5.1V Zener diodes (protects inputs by limiting voltages both over and under 0-5V)
- 6x 200 Ohm resistors (one for each input/output)
- 6x Jacks (4 gates outs, 1 clock in, reset in)
- SPST button (if you want a reset switch)
- 4x 15k resistors
Extras: There's a possibility of adding another 4 analog/digital ins for future CV/gate usage. for CV control, I recommend using 2x 1N5819's per CV input. I'll draw a schematic for that later.
Schematics and Hardware:
Posted Image
Posted Image
SVG Panel file:
http://sneak-thief.com/modular/Tombola-Euclid-Panel.svg
Posted Image
I put A, B, C & D as placeholders for whatever inputs make sense. I decided to set mine to gate inputs for density and length:
Posted Image
Sneak-Thief - raw electrofunk
inlifeindeath
PostPosted: Fri Feb 07, 2014 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
looks awesome, thanks for sharing!
looking forward to building one!
AuDioMiRage
PostPosted: Mon Feb 02, 2015 7:36 am    Post subject: Anyone completed this? :?:
Subject description: Problems with LED Matrix
This is a fantastic project. I've managed to assemble the hardware parts, but the software is another issue. Checked rotary encoders, they are good. Some data is getting to the display, but it is garbled. Swapped MAX72xx chips = same problem. Swapped LED Matrix = same problem.
Not familiar with editing library for Arduino, suspecting that now is the time to learn.
Any help will be greatly appreciated.
sneakthief
PostPosted: Mon Feb 02, 2015 8:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I just updated the schematic and software in the first post - here's the parent thread:
https://www.muffwiggler.com/forum/post-1786613.html#1786613
sneakthief
PostPosted: Mon Feb 02, 2015 10:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Please post a pic of your board showing the pin connections and wires to the display.
A pic of your display would help too.
AuDioMiRage
PostPosted: Tue Feb 03, 2015 11:58 pm    Post subject: Display Issue Fixed :D Reply with quote  Mark this post and the followings unread
Very Happy I swapped the display board and it works! Very Happy
Haven't "ohmed" out the board yet to find it's problem, just enjoying the fact that this module is working!
Thanks sneakthief for your help.
I will post some pic and samples when I get it all wrapped up.
commathe
PostPosted: Wed Feb 04, 2015 3:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow! I've been writing off the arduino for far too long
yusynth
PostPosted: Sun Mar 01, 2015 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool stuff indeed
Yves
ericcoleridge
PostPosted: Mon Mar 23, 2015 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
man, this looks amazing
for some reason I've never yet made a micro controller project of any kind-- but I think this is the one that's gonna get me started.
thanks for posting
dub halley
PostPosted: Wed Apr 29, 2015 8:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Very cool stuff
I start to build one now !!
Thanks
dub halley
PostPosted: Sat May 02, 2015 7:06 am    Post subject: Reply with quote  Mark this post and the followings unread
ok ,it's don't work .... Smile
I'm not sure about the pin out of the encoder to wiring them ?
I Bought the stuff on the e-bay link shown at the top of this topic, it's low cost, but no explainations, no paper, no datasheet ...
And on the encoder the ABC are not show. ....
I search but there is different pinout possible ...
Is anyone know the good way ? Smile
Thanks
sneakthief
PostPosted: Sat May 02, 2015 7:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Please post a picture of your board and encoders.
The side with 2 pins is the switch.
On the side with the 3 pins, the middle pin is usually the common (C).
The other 2 are A and B. If it doesn't work one way, then reverse those 2 wires.
dub halley
PostPosted: Sat May 02, 2015 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Waouuu your are so quick to answer ... Very Happy
Thank for the answer.
I Plug as you tell ...
But There is another problem, because the matrix still showthe same "picture" and don't move ...
Here is my picture.
Thanks for helping Very Happy
 Filesize:  798.61 KB
 Viewed:  833 Time(s)
dub halley
PostPosted: Sat May 02, 2015 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Still looking for a solution... Smile
I solder all the wire on a male connector to be sure that the connection in the Arduino is good.
I send a LFO in the trig in ...
I swap the 3 encoder wire ...
I probably miss something ...
The night bring me some advices Very Happy
sneakthief
PostPosted: Sat May 02, 2015 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Your display is showing a problem! Somehow I think it's connected wrong.
sneakthief
PostPosted: Sat May 02, 2015 1:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I see you have an Uno.
The original program is for an Arduino Nano, so maybe there are some pins that are different.
All I know is that when the display shows that pattern, it means that the data it's receiving is scrambled,
dub halley
PostPosted: Sun May 03, 2015 1:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
Thanks for answering Smile
I tried on a uno because I didn't have a nano ... and It'was a mistake
I checked the differences between uno and nano.
I thought it was the same ATmega328 ...
But not .... Embarassed
UNO : ATMega328p - pu : http://www.arduino.cc/en/uploads/Main/Arduino_Uno_Rev3-schematic.pdf
NANO : ATMega 328 : http://www.arduino.cc/en/uploads/Main/ArduinoNano30Schematic.pdf
And you've right, some pins are not exactly at the sameplace.
So this projetct couldn't work on a uno without changing the code.
I'll found a nano and try again. Rolling Eyes
Thank You !! Very Happy
sneakthief
PostPosted: Mon May 04, 2015 1:53 am    Post subject: Reply with quote  Mark this post and the followings unread
dub halley: Can you try to CAREFULLY unplug the LED matrix from the PCB and rotate it 180 degrees?
Does the display show anything different?
dub halley
PostPosted: Mon May 04, 2015 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok,I did that and ... "black screen" so it was on the good way.
Tomorrow I hope to have time to go to my favourite electronic shop and buy a nano.
Nevertheless I'm sure it's possible to modify the code and adapt the good pins.
But I'm not a good "code man" Very Happy
I'll try with the good board and show you the result !!
Thanks Very Happy
dub halley
PostPosted: Fri May 08, 2015 7:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
Ok, it's work better with the nano ... Very Happy
Now the row of leds look like the video above.
And when I turn the potentiometer I see some change in the matrix
Thanks you sneak-thief Very Happy thumb up
I'll put all this stuff on a module and show you (and anyone who want) the result !!!!
sneakthief
PostPosted: Fri May 08, 2015 7:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Good news - I'm glad it worked.
Félicitations Smile
dub halley
PostPosted: Sun May 10, 2015 7:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
It's work good ! happy smoker
First I want to say thanks to Sneakthief and Tombola for this good job !! thumb up
I did a smal video with the out of the euclidean in 1V/oct of my VCOZ3000
euclidean.mpg
Then if someone want to realise this project.
Encoders
The picture encoder.png show how I have solder the wires.
Because if you buy the ebay stuff, there is no sign on it to know which is the ABC.
And the for the two others you can't do mistake.
Matrix
As well there is no "good" mark to know the good way to plug it.
I put this reference next to FC-16 DISY1. At the opposite of IN / OUT
PCB
I don't think a pcb is indispensable.
It was just to test, I'll correctly wire this stuff to put on a module. Very Happy
Upgrade:
It could be good to add a 555 LFO like here :
http://www.555-timer-circuits.com/metronome.html
It allow you to save a LFO on your modular.
And it's possible to plug the LFO with a switch jack, so, without some jack in trig, you use the 555 and when you plug a jack, the 555 is disable.
Euclidean.MPG
 Filesize:  11.22 MB
 Viewed:  832 Time(s)
 Filesize:  1.48 MB
 Viewed:  727 Time(s)
 Filesize:  701.11 KB
 Viewed:  715 Time(s)
 Filesize:  789.6 KB
 Viewed:  719 Time(s)
 Filesize:  831.47 KB
 Viewed:  805 Time(s)
sneakthief
PostPosted: Sun May 10, 2015 7:51 am    Post subject: Reply with quote  Mark this post and the followings unread
I notice your display is going backwards.
Try my alternate Matrix firmware in the zip archive. It's called LedControl2.
Erase the LedControl folder and rename LedControl2 to LedControl.
dub halley
PostPosted: Sun May 10, 2015 9:36 am    Post subject: Reply with quote  Mark this post and the followings unread
ok, I'll test that when i finished my front panel ...
Everything is unplug .... Embarassed
I've got some questions : Wink
1 - On the schema there are 6 jacks, and on your module there are 10 ??
2 - I'm not sure to understand what the offbeat is ?
Thanks Very Happy
sneakthief
PostPosted: Sun May 10, 2015 9:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Offbeat: play a beat every on step that trigger #1 does NOT play.
Re. My extra jacks: as I wrote above in the front panel description " Extras: There's a possibility of adding another 4 analog/digital ins for future CV/gate usage. for CV control, I recommend using 2x 1N5819's per CV input. I'll draw a schematic for that later.
...I put A, B, C & D as placeholders for whatever inputs make sense. I decided to set mine to gate inputs for density and length"
