Building a new drum synth
Page 2 of 2 [49 Posts]
Goto page: Previous 1, 2
Audio files: 163
PostPosted: Mon Dec 22, 2014 4:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thomas Henry MPS number 2 finished first with mfos dual A/R generator.
I wanted a couple of A/R generators with repeat function and a couple of simple LFO's (lfo's to be fitted on MPS number 1 module, under construction).
These will be used to modulate the mps , cynare , mfos VC echo, mfos VC pan & battery acid CV , when required.
Slowly getting near the end Smile Smile.
 Filesize:  246.97 KB
 Viewed:  422 Time(s)
 Filesize:  586.75 KB
 Viewed:  460 Time(s)
Audio files: 163
PostPosted: Sat Jan 10, 2015 5:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi all , I managed to get a little bit of soldering done over the past week....
MPS with 2 mfos simple skew lfo's added at the end finished now .
 Filesize:  355.63 KB
 Viewed:  425 Time(s)
Audio files: 163
PostPosted: Sat Jan 10, 2015 5:17 am    Post subject: Reply with quote  Mark this post and the followings unread
And also got the Quad-BASS++ finished too Smile after a battle with finding a little slither of copper between tracks on my veroboard daughter board for the pitch bump & wave mods , got it though and working now Smile .
That's all the sound making panels loosly fitted in place in the case, now the long list of snagging jobs to do (wrong direction pots , couple of volume level increases & wire the FX send rotary switches to the modules that don't have an audio output jack on their panels.
 Filesize:  364.04 KB
 Viewed:  420 Time(s)
Audio files: 163
PostPosted: Sun Jan 11, 2015 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy
Hey hey Finished , phew , Smile , ............
testing & demo Sounds & stuff to come through the week ..........
 Filesize:  1.3 MB
 Viewed:  489 Time(s)
Former site admin
Audio files: 353
PostPosted: Sun Jan 11, 2015 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
drunken
looks great!
party! party!
roglok
PostPosted: Sun Jan 11, 2015 12:53 pm    Post subject:   Reply with quote  Mark this post and the followings unread
great job!
mcop
PostPosted: Mon Jan 12, 2015 2:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Awesome! looking forward to the demo's.
roglok
PostPosted: Mon Jan 12, 2015 2:45 am    Post subject: Reply with quote  Mark this post and the followings unread
may i ask whether you considered a central bus system for the gate/trigger/cv inputs and if yes, what made you go completely modular?
Paradigm X
PostPosted: Mon Jan 12, 2015 3:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Incredible work, looks amazing.
Cool
Audio files: 163
PostPosted: Wed Jan 14, 2015 11:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jan , roglok , mcop , Ben Smile Smile Smile
 Filesize:  1.86 MB
 Viewed:  472 Time(s)
Audio files: 163
PostPosted: Wed Jan 14, 2015 11:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi , I did think about bussing the triggers & audio, but when I received the engineers at work midi to 24trig converter, I ended up just running the trigger cables direct to the screw clamp terminals on the converter .
The drum system is run from the heart of my studio... RM1X midi sequencer , I included a few trigger inputs on some modules, when an external trigger is plugged in , it breaks the midi trigger with the switch jacks .
On the nein oh nein modules , the accent inputs are great for adding a bit of velocity changing cv's.
The previous drum synth I built in 2009 had a single panel with 8 voices , it was a pain when wanting to mod something later on having to take the whole panel off .
This 12 panel system (18 voice) will be easier to remove stuff for maintenance or modding.
Audio files: 163
PostPosted: Wed Jan 14, 2015 1:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
A bit of info about the build...........
Top Row Left..
808 kick & snare :- Eric Archer layouts + some mods
808 HH's / Cymbal / cowbell :- Minus layouts on electro-music.
http://www.ericarcher.net/
http://www.electro-music.com/forum/topic-54826.html
http://www.stereoping.com/e-drums/?lang=en
By studying these pages and the 808 service manual I was able to cross reference between them to help me lower the tuning of the kick and extend the decay a little on the snare & cymbal.
2X CYNARE :- as the original CGS47 cynare with the 6 shimmer control pots brought out to the panel.
http://www.cgs.synth.net/
Mega Percussive Synth :- Got these in 2009 standard build without inserts .
http://www.birthofasynth.com/Thomas_Henry/Pages/MPS.html
Bottom Row Left.....
Nein oh nein :- as per purchased pcb kick, snare , rimshot, claps, with all the mods done in the documents.
http://cv.hexinverter.net/?page=projects&id=neinohnein--kick-drum-v10
Quad Bass++ :- as the original plan with bump mod and Wave mod.
http://www.birthofasynth.com/Thomas_Henry/Pages/Bass_Plus.html
http://www.electro-music.com/forum/topic-53420.html
http://electro-music.com/forum/topic-40457.html
Pan Control :- all the modules have their own volume out controls, the outputs from each module are wired in screened cable to this panel's veroboad circuits , nearly all the voices were reasonably balance in level , only a couple of drum sounds needed a little pre amp to boost.
Mfos oldies but goodies pan mixer
http://www.musicfromouterspace.com/forums.html?MAINTAB=SYNTHDIY&PROJARG=OLDIESBUTGOODIES/AUDIOMIXER/panningmixer.html&VPW=1124&VPH=500
FX and mixer :- Hexinverter battery acid CV , compressor & MXR distortion built as per document & pcb , stand alone FX
,Drum voices or external sounds / instruments can be pluged into it.
http://cv.hexinverter.net/?projects=batteryacid-cv-diy-version-of-idow-edition
Mfos cv panner speaker simulator , the outputs are hard wired to the stereo bus , input level is set with a trimmer on the pcb it is set for the drum modules levels only.
2x Mfos CV echo , built as per design & pcb , these are both stand alone FX (in & out jacks).
http://www.musicfromouterspace.com/forums.html?MAINTAB=SYNTHDIY&PROJARG=STEREOPANNER/STEREOPANNER.html&VPW=1124&VPH=500
http://www.musicfromouterspace.com/forums.html?MAINTAB=SYNTHDIY&PROJARG=ECHOFXXX/ECHOFXXX.php&VPW=1124&VPH=500
The two rotary switches are FX sends for the modules that don't have an audio output socket on their panels , rotary 1 handles Bass++ 1,2,3 & 4.
Rotary 2 handles Cynare 1&2, MPS 1&2 , both selectors send their signals through a unity gain buffer to the single socket under their dials ready to patch to FX .
The little 5 channel pan mixer above those acts as FX returns to the stereo bus or plug an external instrument in if needed or the returns from an external FX unit .
That's my brain empty of drum info now , I'm off to programme some demo patterns Very Happy Very Happy
Audio files: 163
PostPosted: Sat Jan 17, 2015 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Smile
Sounds......
First mp3 ...jam & dial twist 808 kick / snare / hi hats / cymbal & cowbell , (dry sound , no FX).
Second mp3...808 sounds & a bass line , (no FX).
third mp3... 808 you suffer, but why? , .
fourth mp3... 909 sounds & bass++ sounds (lfo's into bass++ cv inputs).
fifth mp3... 808 / 909 / cynares / MPS's (mfos echo on cymbal).
Drum synth 808 sounds.mp3
 Filesize:  2.53 MB
 Duration: 2:46
 Viewed:  1864 Time(s)
Drum synth 808 & bass line.mp3
 Filesize:  1.19 MB
 Duration: 1:18
 Viewed:  1849 Time(s)
Drum synth 808 you suffer but why.mp3
 Filesize:  83.48 KB
 Duration: 0:05
 Viewed:  1829 Time(s)
Drum synth 909 & quad bass++ sounds.mp3
 Filesize:  3.42 MB
 Duration: 3:44
 Viewed:  1832 Time(s)
Drum synth 808 909 cynares mps's.mp3
 Filesize:  3.09 MB
 Duration: 3:23
 Viewed:  1877 Time(s)
DUBmatze
PostPosted: Sat Jan 17, 2015 8:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice build, nice build documentation, nice link overview and nice sound samples !!!!
Audio files: 163
PostPosted: Mon Jan 19, 2015 11:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks DUBmatze Smile
Been a long project but fun (at times) Very Happy
roglok
PostPosted: Tue Jan 20, 2015 3:48 am    Post subject: Reply with quote  Mark this post and the followings unread
very cool demos. i like the sound of your 808, the low-pitched cowbell sounds nice. did you install a switch for the timing caps or is it fixed?
roglok
PostPosted: Tue Jan 20, 2015 3:57 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you for the explanation. i totally missed this post as well as page one of the thread. with the midi > trigger converter it makes perfect sense, thought you were using the front panel jacks only...
Audio files: 163
PostPosted: Tue Jan 20, 2015 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Smile
The cowbell had 2 trimmers showen on the circuit to tune the cowbell (& cymbal & hats) I changed those for panel pots for some adjustable tuning , also the hi-hats both have the white noise from the snare available with a 2 way switch to select the original 6 square osc's or the white noise.
the 808 kick & snare panel was a bit empty when designing the stickers, I put the trigger sockets in to fill it up a bit Wink.
Paradigm X
PostPosted: Tue Jan 20, 2015 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
looks and sounds amazing man... what a drum box.
great demos too, they all sound fat as fook.
Nice one.
Audio files: 163
PostPosted: Tue Jan 20, 2015 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanx Ben , really chuffed with it , Smile
isak
PostPosted: Tue Jan 20, 2015 3:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Dave.
kick ass work man, its not a drum box...its a DREAM BOX Cool
i was very happy to follow this post, keep up your great building posts.
Isak E Smile
Audio files: 163
PostPosted: Wed Jan 21, 2015 1:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Isak Smile Smile
mcop
PostPosted: Thu Jan 22, 2015 10:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds great. Hope you have a lot of fun with it.
Audio files: 163
PostPosted: Sat Jan 24, 2015 2:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks mcop Smile
