thapoke
G2 patch files: 5
thapoke
G2 patch files: 5
Posted: Tue Jan 07, 2014 4:13 pm Post subject:
| just got it to save to the synth memory, I had to select "open patch" first... |
thapoke
G2 patch files: 5
Posted: Tue Jan 07, 2014 4:20 pm Post subject:
| and now saving files to internal storage, I had to select the filetype for saving and loading... fully working tablet editor! |
Audio files: 353
Posted: Tue Jan 07, 2014 6:13 pm Post subject:
Wow, nice  |
Assembler
Posted: Sat Feb 01, 2014 11:41 am Post subject:
Midi with the Nord and Ubuntu Subject description: How to get patches from, and save patches to the Nord G1 from Nomad or editor run in Wine |
I managed to get Nomad and the editor running under Wine, but how did you get the patches loading, and saving to and from the Nord? I've had no luck.
I'm using Ubuntu 12.04 and have a midi to USB connector.
Let me know. |
Assembler
Posted: Sat Feb 01, 2014 12:01 pm Post subject:
NordEditor under Wine loading and saving, but not Nomad |
| As of just now, I can get the NordEditor running with Wine, imorting and saving patches to and from the synth, but not Nomad. I used aconnectgui, but it's not working with Nomad. I would prefer to experiment with Nomad. |
thapoke
G2 patch files: 5
Posted: Fri Feb 07, 2014 7:22 am Post subject:
I didnt need to use aconnectgui
Did you get nomad to start?
I ran nomad from the linux terminal using
$ java -jar nomad.jar
Then connected to the nord using the connection dialog in nomad, the midi ports of my maudio controller were listed there automatically.
After pressing connect again the current patch in the nord loaded up.
For loading and saving to linux I had to make sure the file type was selected in the save dialog.
For saving patches to the nord make sure to deselect "save in slot" and select "save in bank" , this worked for me
Are you using a nexus 7? I had to switch to the Gnome environment, for some reason it wouldnt run in the standard ubuntu desktop.
Ive now also got this running on a raspberry pi with slightly less hassle in the setup, and over vnc wifi on an ipad... its quite good! |
Assembler
Posted: Fri Feb 07, 2014 10:03 am Post subject:
I can get Nomad running, saving and making patches okay, but not communicating with the synth, neither to save or to load. Where did you get to a 'connnect dialog'. I can't brows the banks, or change any settings under the 'Nord Properties'.
I'm running Ubuntu on a PC I built. I've been able to run the NordEditor under Wine with success, but not Nomad.
JH |
thapoke
G2 patch files: 5
Posted: Fri Feb 07, 2014 10:08 am Post subject:
Have you tried File/New/synth ?
Then the spanner settings icon that appears in the bottom left section to set up midi. The yellow diamond icon next to that should connect you to the synth once your midi interface is selected. |
Assembler
Posted: Thu Feb 13, 2014 4:39 pm Post subject:
Indeed I have. I get an error that communication has timed out.
Unfortunate.
JH |
geslotencirkel
Posted: Sat Apr 11, 2015 9:13 am Post subject:
have you tried another midi cable? turned out to be my culprit all this time.
ubuntu + midisport 2x2. |
