Who can help to make a stripboard layout? Buffered Multiple
Page 2 of 2 [35 Posts]
Goto page: Previous 1, 2
Nardu
PostPosted: Sun Jan 27, 2013 8:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Here o version of CV distribuitor II with attenuators, no pots on board, using an 1/2 - H25SR050 stripboard
 Filesize:  102.32 KB
 Viewed:  837 Time(s)
citric acid
PostPosted: Mon Feb 11, 2013 4:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Nardu wrote:
Stripboards
hi nardu,
verry nice work. can you please say witch part values you used on the cv distribuitor 2 ?
thanks for your nice stripboard layouts ....
http://soundcloud.com/citric-acid-303
citric acid
PostPosted: Thu Feb 21, 2013 2:37 am    Post subject: Reply with quote  Mark this post and the followings unread
at muffs is a simmilar treat now. i hope its ok to share it on both forums.
http://www.muffwiggler.com/forum/topic-21611-0-0.html
rogerlatur
PostPosted: Sat Jul 13, 2013 2:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Nardu wrote:
Stripboards
Great ! Thank you !!!!!!!
I will be able to compare when I have done my own stripboard if I did something wrong. This really helps.
rogerlatur
PostPosted: Sat Jul 13, 2013 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
elmegil wrote:
I like the buffers from this project of Ray's:
http://www.musicfromouterspace.com/forums.html?MAINTAB=SYNTHDIY&PROJARG=CVANDGATEDIST/CVANDGATEDIST.html
I built a utility board that includes both the gate/trigger distribution and the CV distribution portions of that, one with and one without the voltage offsets.
Thank you for the advice.
I realize that the MFOS pages are actually in many ways very interesting.
rogerlatur
PostPosted: Sat Jul 13, 2013 2:55 am    Post subject: Reply with quote  Mark this post and the followings unread
citric acid wrote:
Nardu wrote:
Stripboards
hi nardu,
Nardu's stripboards are illustrating the CV Distributor version found here: http://www.musicfromouterspace.com/analogsynth_new/OLDIESBUTGOODIES/VOLTAGEMIXER/voltagedist2.html
djthopa
PostPosted: Mon Oct 07, 2013 3:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I built the circuit at the beggining of the post and it works great, i also added a led driver that gives ferdback of the input signal.
I just realized i havent put the 1uf caps...
Thanks for this Smile
mercury8
PostPosted: Sun Dec 30, 2018 3:06 pm    Post subject: g Reply with quote  Mark this post and the followings unread
can a tl074 be used instead of 084?
PostPosted: Sun Dec 30, 2018 6:17 pm    Post subject: Re: g Reply with quote  Mark this post and the followings unread
Usually. In this case I'd say probably yes.
mercury8
PostPosted: Mon Dec 31, 2018 6:20 pm    Post subject: Re: g Reply with quote  Mark this post and the followings unread
thanks I figured since they have about the same specs. I actually used a 1-2 PASSIVE multiple to slit my midi-cv convertor in order to control 2 vcos and I figured there would be pitch problems but there wasn't so I tried it again later and still no pitch problems. I doubt a passive 3-1 for 3 vcos would work but maybe ill give it a try. but there 2 really stable vcos. ones a th vco-1 which is pretty pricise and stable and the other is a cem3340 design.
