Lunetta Reverb Circuit
Page 1 of 1 [13 Posts]
Audio files: 83
PostPosted: Sun Feb 24, 2013 7:13 pm    Post subject: Lunetta Reverb Circuit
Subject description: 4006 Digital Delay
I had this idea for a while, but just got around to testing it out tonight. I used two 4006 shift registers to create a digital delay line. It works well with lunetta devices because it can only output square waves, but you can try it with other sound sources if you want. It might sound a little odd though - like the delay is being overdriven.
The attached sound demo starts with just the source waveform, and then I turn up the level of the reverb. Then I play with the pitch of the source. Lastly, I adjust the rate of the delay.
Here is the basic run-down of how it works.
A clock drives two 4006 shift registers. The rate of the clock is essentially the delay rate, but at the same time it is also the sample rate so things can sound a little odd at times.
The shift registers are all set up in series so the output of one goes to the input of the next. This creates a long delay line that spans 36 steps across the two chips.
The input of the first shift register is the sound source input. In my schematic, it is a 40106 oscillator with a momentary switch. That can be replaced with any sound source that goes above the chip's input threshold. Note the need for a pull-down resistor at the input.
I then tap the shift register outputs at four different points. The earliest point has no divider, and the rest have an increased voltage division as they go down the register chain. This makes the first tap point the loudest, and the last tap point the quietest.
All four tap points are mixed with a TL074.
The mixed delayed sounds are sent through a voltage divider volume pot and mixed with the source sound. Adjust the pot controls the level of the reverb.
I also added a 0.1uF cap to ground after the level pot to remove some of the harshness in the reverb sound. This is entirely optional. I like my reverb a little bit warm. I found it makes it sound more like it passed through an actual space, and masks the fact that it is just a repeating square wave of decreasing volume.
THINGS TO TRY
1. Use a complex sound source.
2. More or less tap points.
3. Add more 4006 shift registers to the chain for really long delay time.
4. Increase the clock rate so the sample rate also improves (requires more shift register steps).
5. Try another shift register with more steps.
6. Try filtering the reverb different ways.
4006delay.mp3
4006 Delay Sound Demo
 Filesize:  4.87 MB
 Duration: 2:08
 Viewed:  2444 Time(s)
 Filesize:  24.69 KB
 Viewed:  1357 Time(s)
JacobWatters.com
tony void
PostPosted: Sun Feb 24, 2013 7:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Awesome! I've wondered about this idea before but didn't think it would work. This opens up so many possibilities.
PostPosted: Mon Feb 25, 2013 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmnmm, interesting... Alas, the 4006 is out of production I believe, and getting harder to find for some. But what about the 4031, which is a 64-bit shift register?
Anyway, I'll have to check this out one day... too much stuff on the breadboards and waiting for enclosures.
James.
PostPosted: Mon Feb 25, 2013 4:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
4015 is a dual 4 bit register. I bet 2 or 3 of them could be subbed with the same use. Max clock is only 8MHz, but I don't see that as a drawback....
Audio files: 83
PostPosted: Mon Feb 25, 2013 5:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Even better! That will give you twice the delay length with only one chip. A longer delay length will mean that you can clock it faster and won't get sample rate issues with higher frequencies.
I was nowhere near 8MHz clock speed. I don't have enough steps to have an audible delay with a high frequency clock. Another reason why the 4031 sounds like a good choice.
JacobWatters.com
analog_backlash
Audio files: 21
PostPosted: Mon Feb 25, 2013 5:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is brilliant! Another circuit to add to my impossible list of circuits to try before I die (circuit bucket list?).
I had also thought that this should be possible, but I was too stupid to work it out
Gary
phobos
Audio files: 728
PostPosted: Mon Feb 25, 2013 6:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
redrawn the schematic a bit (and removed the 10K resistors between in- and outputs of the 4006) Cool
CD4006 reverb by Cynosure, redrawn by PHOBoS
 Filesize:  42.69 KB
 Viewed:  1237 Time(s)
The Golden Shrimp Guild
Audio files: 83
PostPosted: Mon Feb 25, 2013 6:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks phobos! <3
James - replace the 4006 ic's with one 4031 and crank up the clock rate Smile
JacobWatters.com
phobos
Audio files: 728
PostPosted: Mon Feb 25, 2013 6:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looking at the schematic again now and I think you can remove the two 1uF caps between the opamps, because you're using
a dual supply with a real GND. And you can remove the 47k resistor to GND aswell.
LeftyLogic
PostPosted: Mon Feb 25, 2013 7:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
After seeing this thread and wondering, "What's a shift register?" I did some reading and it sounds like you could do some really fun things to this circuit with a 4031 chip; it has two inputs that it switches between depending on whether the voltage at the switch pin is high or low, so I bet you could put a toggle switch on that pin, hook up your oscillator to input 1, and then feed the output back into input two for some endless looping fun!
Or, for extra weirdness you could get rid of the toggle switch entirely, divide the input signal down into the LFO range and hook THAT up to the switch pin!
Although I have to admit, I'm seriously new to this whole SDIY/Lunetta stuff so I wouldn't be surprised if none of this works, but hey, it was fun to research Smile
PostPosted: Mon Feb 25, 2013 7:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Brilliant idea! You could feed two such delays and have a stereophonic lunetta.
corex
PostPosted: Tue Feb 26, 2013 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Using a shift register like a BBD is clever. Good idea!
bingmachine
PostPosted: Thu Mar 07, 2013 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just saw the datasheet of the 40105. It's essentially 4 16-bit shift-registers, with common clock - and then some more. It should be ideal for this application, shouldn't it?
