How can I use the full range of the freq knob?
Page 1 of 1 [3 Posts]
simonbreak
PostPosted: Fri Feb 22, 2013 11:20 am    Post subject: How can I use the full range of the freq knob? Reply with quote  Mark this post and the followings unread
Hi guys, hoping an Andro guru can help me with this tricky problem.
Both my freq knobs have an annoying issue: only about 2/3rds of their total throw has an effect on the value. In other words, from about 7 o clock to about 9 o clock the value stays at it's minimum, then from 9 o clock to about 3 o clock it ramps from min to max, then from 3 o clock to 5 o clock it just stays at maximum.
I have tried messing with the offset value on the filter page and this didn't fix it. Is there some way I can configure the effective range of the two freq knobs, ideally on a global basis so I don't have to set it for every patch?
Cheers for any help! [sb]
The Real MC
PostPosted: Fri Feb 22, 2013 2:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
The ribbon cables between the pront panel circuit boards need to be re-seated, they oxidize with age and will cause problems like this. MAKE SURE THE CONNECTORS ARE NOT OFFSET WITH PINS OR YOU WILL DAMAGE THE A6!
simonbreak
PostPosted: Fri Feb 22, 2013 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot, will give this a try!
