Steiner VCF CA3096 Version
Page 1 of 1 [4 Posts]
fantozzi
PostPosted: Sun Jan 15, 2012 10:57 am    Post subject: Steiner VCF CA3096 Version
Subject description: noises while turning the RES POT
Hello Yves, Hello Forum,
I build 2 times Steiner VCF in the CA3096 Version(some years ago).
They are working fine, exept the RES POTs.
I hear heavy noises while turning the RES POT and the sounds turns off for a while (as you hear in the mp3).
I try serveral POTs over the time, always with the same result --> so i think i made something wrong while soldering.
Maybe you or somebody who build this filter know the problem and can help?
thanks in advance
fantozzi
scratch1.mp3
 Filesize:  230.2 KB
 Duration: 0:15
 Viewed:  1273 Time(s)
yusynth
PostPosted: Thu Jan 19, 2012 12:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
No unfortunately it is due to the design of the filter itself , the resonance loop in this circuit controls at the same time the gain of the output and is very sensitive to the least imperfection of a carbon track. You must use a very good quality potentiometer (preferably of the plastic track kind).
Yves
fantozzi
PostPosted: Sat Jan 21, 2012 2:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for your reply,
it is good to know that everything is ok.
best regards
fantozzi
jumunius
PostPosted: Mon Mar 19, 2012 9:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, perhaps the info at this thread related to the CGS version would be useful? I assume it's equally relevant to all the Steiner variations.
Good to know about the pot tracks, incidentally. Someday I hope to buy some nicer 1k pots, which would apparently help here.
-Jim
