Gated slew issue
Page 1 of 1 [7 Posts]
roman_f
PostPosted: Mon Dec 19, 2011 6:08 pm    Post subject: Gated slew issue
Subject description: works only in one (LIN/LOG) position
my gated slew works only in one of the lin/log positions
when i put the switch it into the other one - i have a constant -13.7V on the output
up/both/down switch works fine
diablojoy
PostPosted: Tue Dec 20, 2011 2:25 am    Post subject: Reply with quote  Mark this post and the followings unread
OK you could try checking this part first
The lin/log switch must be an DPDT
in the linear position besides changing the feedback path for U1 it must also open the connection from the source of Q1 and the intersecting point of R4, P1/1 and sw1 center pin
ask where the hell am I
as good an answer as any
roman_f
PostPosted: Tue Dec 20, 2011 3:08 am    Post subject: Reply with quote  Mark this post and the followings unread
it seems that mine are SPDT on-on, i didn't know there are SPDTs with 6 lugs
marfoski
PostPosted: Tue Dec 20, 2011 4:21 am    Post subject: Reply with quote  Mark this post and the followings unread
roman_f wrote:
it seems that mine are SPDT on-off-on, i didn't know there are SPDTs with 6 lugs
It's wrong. The LIN/LOG must be a DPDT on-on switch. One of the poles works as a circuit breaker and so, IMHO, it could possibly explain why it works in LIN mode only.
roman_f
PostPosted: Tue Dec 20, 2011 4:30 am    Post subject: Reply with quote  Mark this post and the followings unread
my mistake - they are on-on
but how can i check if it's SPDT or DPDT?
it has 6 lugs, i thought SPDT has 3...
marfoski
PostPosted: Tue Dec 20, 2011 5:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Six lugs is fine. I can only imagine that you soldered one of the poles the wrong way. Check the excellent Yves' wiring diagram.
roman_f
PostPosted: Thu Jan 05, 2012 7:32 am    Post subject: Reply with quote  Mark this post and the followings unread
the mistake was a mixed soldering of the legs on that switch, btw
now works perfect
