Clock divider behaving strangely
Page 1 of 1 [6 Posts]
OW
PostPosted: Sat Jul 30, 2011 9:39 am    Post subject: Clock divider behaving strangely Reply with quote  Mark this post and the followings unread
So I just finished putting together the yusynth clock divider and it's behaving very strangely.
It doesn't work when connected to the power supply, however, when I remove the power supply it works for a few seconds and the stops.
The circuit is not connected to -15V. Could it be the stereo jack wired incorrectly?
Any ideas on why it's doing this?
Any help would be greatly appreciated!
yusynth
PostPosted: Sun Jul 31, 2011 5:28 am    Post subject: Re: Clock divider behaving strangely Reply with quote  Mark this post and the followings unread
oscillate_wildly1 wrote:
There is no stereo-jack in this module.
Check the wiring of your jack sockets.
The -15V is not required for this circuit that why it is not connected.
Yves
OW
PostPosted: Sun Jul 31, 2011 5:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the reply.
On the wiring diagram IN 2 is show as a stereo jack as it has three connections going into it. If it is not a stereo jack, how should I wire three connections to a mono jack?
Thanks again!
 Filesize:  111.83 KB
 Viewed:  414 Time(s)
yusynth
PostPosted: Sun Jul 31, 2011 6:46 am    Post subject: Reply with quote  Mark this post and the followings unread
It is not a stereo jack it's a mono jack with switch ! The switch is on when no jack is inserted and breaks when a jack is inserted. On such socket there are three lugs, one for the tip of the jack, a second for the switch, and a third lug for the switch.
Therefore the wire from the tip-lug of the #1 INPUT is to be connected to the switch lug of #2 INPUT.
Yves
OW
PostPosted: Sun Jul 31, 2011 6:51 am    Post subject: Reply with quote  Mark this post and the followings unread
So something like this?
http://www.rapidonline.com/Cables-Connectors/Connectors-Audio-Video/Jack/6.35mm-Switched-jack-socket/63507
And all the other jacks are mono jacks right?
Thanks for all the help so far!
yusynth
PostPosted: Sun Jul 31, 2011 7:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes this it and the other jack sockets are simple mono.
Yves
