Coming up on Radio 1 at
Framework for break-slicing from Kassen
Page 1 of 1 [6 Posts]
jirko
PostPosted: Fri Jan 08, 2010 8:10 am    Post subject: Framework for break-slicing from Kassen
Subject description: arguments type(s) do not match
Im trying to check out the Framework for break-slicing from Kassen but I get
this on the console;
[slicer kassen.ck]:line(127): arguments type(s) do not match:
[slicer kassen.ck]:line(127): ... for function 'dur[].cap(...)' ...
[slicer kassen.ck]:line(127): ...(please check the argument types)
in reference to this line:
dur_index.cap(peak_index.cap());
I cant figured out where the problem is.. Someone can help?
PostPosted: Mon Jan 11, 2010 9:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I ran into that too a few days ago when I was revisiting that code.
The issue is that the array implementation changed. To get that stuff to run back then I had to abuse the arrays a bit; back then .cap( int ) would work but it wasn't documented and would flush the array. Now I wouldn't write it like that any more (and wouldn't have to!). Until I get around to a more modern and cleaner version this might help;
dur_index.size(peak_index.cap());
Hope that gets you further, there may be one or two more lines like that.
jirko
PostPosted: Fri Jan 15, 2010 4:24 am    Post subject: Reply with quote  Mark this post and the followings unread
the error disappears but I cant get sound of it. anyway, thanks for the reply.
alexbarbed
PostPosted: Fri May 20, 2011 4:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is great - I was just starting to work on my own code when I thought "I'll just check the forum..."
This does just what I wanted. Many thanks indeed. Very happy.
GrandJu
PostPosted: Mon May 23, 2011 5:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Chuckers,
Where can I find this framework?
I cannot find it with a "search" Embarassed
Thanks
Ju
alexbarbed
PostPosted: Mon May 23, 2011 12:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
if you scroll down this link a bit, you'll find an attached file called breaking.ck from Kassen. It's that.
http://www.electro-music.com/forum/viewtopic.php?highlight=beat+slice&t=33705
