Coming up on Radio 1 at
Arp 4072 VCF Bleedthrough Fix
Page 1 of 1 [25 Posts]
negativspace
PostPosted: Tue May 10, 2011 3:45 pm    Post subject: Arp 4072 VCF Bleedthrough Fix
Subject description: Clarification of instructions needed!
Yves,
I built one of these for a fellow over on Muffwiggler's and we're trying to fix the bleedthrough issue. He forwarded me some instructions you gave him, quoted here:
"The cure is to replace the resonance potentiometer by a dual gang model. Connecting the CW lugs in parallel, the CCW lugs in parallel, and one wiper lug connected to the normal resonance circuit while the other wiper lug connected to the R43 resistor."
I am unclear on one thing - when you say 'connect to R43' do you mean in place of R43, or to its input leg, or to its output leg? Thank you!
dstrength
PostPosted: Sat May 21, 2011 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think you're just replacing the T-connection on the schematic..so looking at the schematic, remove the T and tie the left side of R43 to the other wiper.
yusynth
PostPosted: Sat May 21, 2011 11:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok I am back home.
I mean "connect to" not "replace", this means unsolder the left leg of R43, solder a wire this leg and connect this wire to the wiper lug of the second potentiometer of the dual-gang pot.
Yves
negativspace
PostPosted: Sun May 22, 2011 1:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Perfect. Thanks for the clarification! Thanks to dstrength for the help too. I'm out of town on business right now but I will assemble the module next week and report back. Very Happy
negativspace
PostPosted: Sun May 29, 2011 10:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
This seems to do the trick. It absolutely kills the bleedthrough and seems to leave the low end intact at high resonance. The resonance control response is altered slightly - self-osc seems to come in differently - but it's neither more- or less-usable... just different. It still sings beautifully in self-oscillation and tracks my entire 5-octave keyboard. Very Happy
Thanks again.
yusynth
PostPosted: Sun May 29, 2011 11:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks again.
Fine then, I will add a note at my site.
Yves
Sebo
PostPosted: Fri Jun 24, 2011 3:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi:
I did the fix and now the bleedthrough is gone.
Thank you Yves!!!
Sebo
My Music:
yusynth
PostPosted: Sat Jun 25, 2011 12:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the feedback !
I will publish this mod then Cool
Yves
djfill
PostPosted: Wed Feb 08, 2012 5:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Guys...
I think I have the 'Bleedthrough' issue and just wanted to confim the symptoms with someone before I try this fix.
When I set the frequency to 0 and increase the reasonance, i can still hear the waveform slightly. Is this bleedthrough? (The answer seems obvious when i put it like this but I just want clarification before i start making a mess of my board.)
Thanks.
yusynth
PostPosted: Wed Feb 08, 2012 6:14 am    Post subject: Reply with quote  Mark this post and the followings unread
djfill wrote:
Hi Guys...
Thanks.
You answered yourself
Yves
Yves
djfill
PostPosted: Wed Feb 08, 2012 6:44 am    Post subject: Reply with quote  Mark this post and the followings unread
yusynth wrote:
djfill wrote:
Hi Guys...
Thanks.
Yves
I thought so...thanks Yves! (congrats on the new synth btw...looks great!)
sylvainmoreau
PostPosted: Wed Jun 26, 2013 5:36 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry i prefer to do a drawing because my english is missing some words here ..
is that correct ?
Posted Image
arp vcf 4072 in progress
sylvainmoreau
PostPosted: Fri Jun 28, 2013 1:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Up ?
yusynth
PostPosted: Fri Jun 28, 2013 12:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes you got it right
Yves
Pilastik
PostPosted: Sat Jun 29, 2013 2:49 am    Post subject: Reply with quote  Mark this post and the followings unread
viewing your drawings cw(3/6) will go on the right side and ccw(1/4) will go on the left
vladosh
Audio files: 55
PostPosted: Thu Jul 31, 2014 2:05 am    Post subject: Reply with quote  Mark this post and the followings unread
fixed mine too , thanks for sharing ,the resonance seems nicer this way Very Happy
alanwilder81
PostPosted: Wed Jan 25, 2017 8:24 am    Post subject: Reply with quote  Mark this post and the followings unread
hello Yves,
can you please further explain your statement ?
what's the " normal resonance circuit " the second wiper lug has to be connected to?
thanks
yusynth
PostPosted: Wed Jan 25, 2017 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Check the drawing six messages above (sylvainmoreau...
Yves
alanwilder81
PostPosted: Wed Jan 25, 2017 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
sorry Yves,
i've been trying to get my head around that diagram, but no, i can't seem to figure it out. CW and CWW are clear.
However, two wires are attached to the wiper. One goes to the R43 (the yellow one).
What about the blue wire (wiper). Where does it connect to the real circuit?
thanks ! scratch
 Filesize:  37.12 KB
 Viewed:  488 Time(s)
yusynth
PostPosted: Thu Jan 26, 2017 12:24 am    Post subject: Reply with quote  Mark this post and the followings unread
there it is
 Filesize:  103.74 KB
 Viewed:  23753 Time(s)
Yves
alanwilder81
PostPosted: Thu Jan 26, 2017 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Yves,
so, one wire from the wiper goes to the unsoldered left leg of R43.
And the second wire from the wiper goes to the point i circled in red, so that it closes the circuit ,right? Embarassed Embarassed
excuse the dumb questions, i hope i got it right this time ! Smile
 Filesize:  122.55 KB
 Viewed:  497 Time(s)
yusynth
PostPosted: Thu Jan 26, 2017 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes that's correct
Yves
alanwilder81
PostPosted: Thu Jan 26, 2017 6:57 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks a lot, Yves, for sharing with us this wonderful filter and for your technical help. That s priceless !! Smile Smile
alanwilder81
PostPosted: Sun Aug 27, 2017 2:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Yves,
can you please get me the ARP 4072 schematics you originally drew ? i mean the schematics before the dual pot modification.
many thanks!
yusynth
PostPosted: Sun Aug 27, 2017 3:05 am    Post subject: Reply with quote  Mark this post and the followings unread
The old schemo is there : http://yusynth.net/Modular/Commun/ARPVCF/ARP-4072-sch.jpg
Yves
