cheese_nucleus
Posted: Fri Mar 11, 2011 12:20 pm Post subject:
Proposal for an electonic hi/low switch with pushbuttons |
i want to build a universal switch module to give out hi / lo signals, for example to start / stop / reset 4040 counters and 4051 sequencers. i want to use momentary pushbuttons to do this. yes, i know, toggle switches would be the easiest way for this task, but i think a momentary pushbutton is more intuitive for starting/stopping sequencers.
i tried to build the circuit, attached to this thread (found on this website http://talkingelectronics.com/projects/TouchSwitch/TouchSwitch-1.html ). it's a toggle touch switch, using a 4049. the switch's output changes to high on one push, on the next, it changes back to low. an inverted output is also available. this switch is originally planned as a touch switch. i found it very unreliable, when i tested it.
so my question is: does anybody have an idea how to realize the same function, but with more reliability and maybe with less parts used?
| Description: |
| Filesize: |
3.65 KB |
| Viewed: |
12380 Time(s) |
| Description: |
| Filesize: |
3.65 KB |
| Viewed: |
12381 Time(s) |
Kabzoer
Posted: Tue Mar 15, 2011 2:17 am Post subject:
| You can use a T flip-flop to toggle, as far as i know... |
cheese_nucleus
Kabzoer
Posted: Tue Mar 15, 2011 12:36 pm Post subject:
| Yeah, I think the last one is JK flipflop wired as a T flipflop. |
cheese_nucleus
Posted: Tue Mar 15, 2011 2:24 pm Post subject:
| ok, so i breadboarded the 4011 circuit on the left today and it works perfectly. no delay and no failures like on the 4049 version! |
richardc64
Audio files: 26
Posted: Wed Mar 16, 2011 2:23 pm Post subject:
Since the 4011s are connected as inverters, each with both inputs tied together, you should be able to get 3 such circuits from one 4069. _________________ Revenge is a dish best served with a fork... to the eye |
cheese_nucleus
Posted: Wed Mar 16, 2011 3:10 pm Post subject:
| ok, that would be the circuit in the middle. 4069 and 4049 can be used indentically, am i right? |
richardc64
Audio files: 26
Posted: Thu Mar 17, 2011 2:31 pm Post subject:
| cheese_nucleus wrote: | | ok, that would be the circuit in the middle. 4069 and 4049 can be used indentically, am i right? |
Well, I referred to the left one, "Bild 7", but yeah, I guess a 4049 or 4069 would probably work in either circuit. _________________ Revenge is a dish best served with a fork... to the eye |
Kabzoer
Posted: Fri Mar 18, 2011 9:49 am Post subject:
| What is the difference between 4069 and a 4049? There must be a difference because the schematics in the datasheet are different. |
-minus-
Posted: Fri Mar 18, 2011 9:59 am Post subject:
| Well to start with, they are powered from different pins. This means that if you were substituting one for the other in a circuit, you would have to change the way the IC is powered. |
richardc64
Audio files: 26
Posted: Fri Mar 18, 2011 12:30 pm Post subject:
| -minus- wrote: | | Well to start with, they are powered from different pins. This means that if you were substituting one for the other in a circuit, you would have to change the way the IC is powered. |
Ooops. forgot about that, sorry. Also, 4069 is 14pins. 4049 is 16pins! Both should work, but they aren't pin-for-pin interchangeable.
The 4069 is six inverters. The 4049 is six inverting buffers. The input voltage can be higher than the supply voltage: It will translate 10volt or 15volt CMOS levels down to 5volt. _________________ Revenge is a dish best served with a fork... to the eye |
artifus
Draal
Joined: May 18, 2010 Posts: 308 Location: Oak Park, IL
Posted: Mon Mar 21, 2011 1:59 pm Post subject:
I've been a fan of many of ROG's projects for a number of years now. Fun stuff . _________________ Zontar Prevails! |
