Wavefolder B diodes
Page 1 of 1 [3 Posts]
Luka
PostPosted: Mon Dec 06, 2010 2:03 pm    Post subject: Wavefolder B diodes
Subject description: Re-Calculating to work with a different diode types
Hi Jurgen
I would like to build a variant on your wavefolder with different types of diodes, like GE diodes. How do you alter the circuit to handle the different forward voltage drop of the diodes?
problemchild
melbourne australia
jhaible
PostPosted: Thu Dec 09, 2010 7:45 am    Post subject: Re: Wavefolder B diodes
Luka wrote:
Hi Jurgen
There is no easy way to do this.
The way to do it would be:
Get a circuit simulator, like LTSpice.
Model the original circuit.
Get a component model for the new diode you want to use.
Change the circuit - resistors, mainly - until the circuit behaves like the previous one, but with the new diodes.
Caveat: not easy to get an accurate model for Germanium Diodes.
Caveat 2: Beware of leakage currents in Ge Diodes.
Caveat 3: If the end result matches the initial result - why then use different diodes?
JH.
Luka
PostPosted: Fri Dec 17, 2010 4:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks jurgen
problemchild
melbourne australia
