Clocking the sample & hold externally
Page 1 of 1 [14 Posts]
LektroiD
PostPosted: Thu Sep 23, 2010 7:13 am    Post subject: Clocking the sample & hold externally Reply with quote  Mark this post and the followings unread
Hi, I have finished the sample & hold, but can't seem to trigger it, I have been using a saw LFO to trigger other modules, but doesn't seem to trigger the sample & hold.
I would like to keep everything in time (although I have no sequencer as yet) I'm presuming I need to build a proper clock circuit; where would I find one, or should the saw LFO be OK, and maybe I've made a mistake on the S&H clock in?
Any help appreciated
LektroiD
PostPosted: Thu Sep 23, 2010 10:33 am    Post subject: Re: Clocking the sample & hold externally Reply with quote  Mark this post and the followings unread
Does your circuit work when clocked from the internal oscillator?
Can you try a square wave for your external clock instead of a sawtooth wave?
Note that the LED should light up with an external clock. Does it light up for you?
Sebo
PostPosted: Thu Sep 23, 2010 2:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry if I'm obvious, but... do you move the switch to the external position?
Sebo
My Music:
LektroiD
PostPosted: Thu Sep 23, 2010 3:58 pm    Post subject: Re: Clocking the sample & hold externally Reply with quote  Mark this post and the followings unread
Thanks for your reply, I get a faint glow on the LED (at best) when I use any sort of CV, but nothing seems strong enough to trigger it, doesn't matter where it's sourced from. I'm wondering if there's a way to increase the CV gain from the external input signals. Maybe a resistor is inhibiting this?
I'll investigate further, and report back with any findings.
LektroiD
PostPosted: Thu Sep 23, 2010 4:46 pm    Post subject: Re: Clocking the sample & hold externally Reply with quote  Mark this post and the followings unread
Look for a solder bridge in the LED driver circuit. Perhaps a short is pulling down the clock signal.
Also, try to apply a positive DC voltage to the ext input and measure your source voltage both plugged in and unplugged. If your unplugged voltage is, say 10v and your plugged in voltage drops a lot, say down to 3v -- then suspect a solder bridge.
Keep us posted!
yusynth
PostPosted: Sun Sep 26, 2010 11:28 am    Post subject: Reply with quote  Mark this post and the followings unread
The Sample&Hold circuit expects a positive SQUARE or a PULSE as an input. The sampling is triggerred by the rising edge of the PULSE.
You said that you are using a SAW LFO, a SAW is not recommended for this circuit because there is no schmitt trigger at the input. Check your SAW : if the stiff edge is a falling edge it won't work. If the stiff edge is a rising edge it should work. Try to reverse your saw.
Yves
LektroiD
PostPosted: Thu Sep 30, 2010 10:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've tried a square wave, but still not strong enough to run, at least the saw made the light flicker, albeit faintly. The Square doesn't even manage that.
I also tried swapping the TL074 with another from stock, just in case the op amp was blown. It seems there's simply not enough voltage coming in to drive it.
LektroiD
yusynth
PostPosted: Thu Sep 30, 2010 11:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Normally the clock input is expecting at least 5V (10V is better) to work properly. Normally the LED is shining mid-bright when externally clocked.
Yves
LektroiD
PostPosted: Sat Oct 02, 2010 7:00 am    Post subject: Reply with quote  Mark this post and the followings unread
This would be the problem, I'm using your VCLFO 1&2, which only push out +3.4V / -3.4V. I guess I need to build a specific clocking device to run this externally, either that or somehow increase the voltage between the input socket and the board. What does everyone else use for clocking?
LektroiD
yusynth
PostPosted: Sat Oct 02, 2010 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
The output range of the VC-LFO 1 & 2 should be more than +/-3.4V . Are you powering them in +/-15V ? You should have at least +4.2/-4.2V
I have just check with my module and I have no problem triggering the S&H with the VC-LFO.
Yves
LektroiD
PostPosted: Sat Oct 02, 2010 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I use the MFOS wall wart adaptor which is 12V. Maybe I need a different supply for these modules, what would you recommend?
LektroiD
yusynth
PostPosted: Sat Oct 02, 2010 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
The circuit were designed for +15/-15 but can also work for +12/-12 if some resisto values are modified.
In your very case I suggest thtat you replace the 4.7K resistor at the output of the square signal by a 10K, the resistor is labelled R17.
MOD for +/-12V Power supply
 Filesize:  117.16 KB
 Viewed:  16685 Time(s)
Yves
john trials
PostPosted: Thu Oct 22, 2020 6:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am having trouble with my sample and hold, too (powering it with +/-15v supply). It samples fine with the internal clock, but with an external clock/gate (0 to +5v gate), the LED illuminates with the gate, but slightly dimmer than with the internal clock.
It does not sample properly with this external gate.
Is there some modification that will get the circuit to sample with a +5v gate? It seems pretty useless if the external clock/gate has to be +10v or above.
The only difference with my circuit is a J102 FET, because I could not get a BF245C.
I'd hate to have to add an op amp gain circuit (3x gain) specifically for the external clock, and rewire the internal/external switch to accommodate this, but that is the only solution that I can think of.
john trials
PostPosted: Sat Oct 31, 2020 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Apology.
The Sample and Hold is working properly with an external clock, if the clock is a good signal.
I was feeding the Yusynth Comparator an envelope signal, and using the gate out as a clock for the Sample and Hold. For some reason, the Comparator gate output signal has a strange flicker on the rising and falling edges when running at a slow (<10Hz) rate.
So my Yusynth Comparator is not working properly. The Sample and Hold works fine.
Sorry. My mistake.
