please help me confirm my thoughts (CEM3379 filter/VCA)
Page 1 of 1 [3 Posts]
slugger
PostPosted: Thu Apr 01, 2010 7:36 am    Post subject: please help me confirm my thoughts (CEM3379 filter/VCA) Reply with quote  Mark this post and the followings unread
Ok, I'm pretty sure I've got this figured out, and under normal circumstances I would just wire it up & hope for the best, but considering the price of these chips I'm feeling more cautious- and since I'm still pretty new to this stuff, I'd rather ask a stupid question than fry something.
Anyway, my main question is this: the datasheet says "The maximum supply allowed across either device is 25 volts. Due to internal voltage regulators, the supplies do not have to be balanced: +5/-12 is allowed, as would be +12/-5. Since the maximum positive output swing of the filter is 2.9 volts below the positive supply, some loss in maximum VCF output will occur at +4.75 volt supply. For best performance with low power dissipation, use +9/-5 or +12/-5 supply voltages".
It seems to me that I should be able to power it from a +/-12V supply with no trouble, since that falls within the 25 volt range mentioned, is that correct?
the synthgeek pages - samples & stuff
my blog
delta32
PostPosted: Fri Apr 09, 2010 6:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Slugger,
This datasheet:
http://www.datasheetarchive.com/CEM3379-datasheet.html
specifically points out that indeed +12V/-12V is an acceptable power supply.
cheers[/url]
slugger
PostPosted: Fri Apr 09, 2010 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the confirmation. The datasheet was where I got my info, but the wording later on made me doubt myself. Being a bit of a n00b, I wanted to be sure I wasn't misunderstanding something.
my blog
