Posted: Tue Jan 26, 2010 4:16 pm Post subject:
SoundLab + + Finished at last Subject description: wiring complete , sounds are uploaded now
A Re-worked, condensed version of my soundlab+ due to start soon.
I cannot seem to lay down the soldering iron at the moment, long may it last he he .
Soundlab ++
extra things to be added to the previous plus version...
extra pwm / 2 sub osc's / ring mod / 8 chanel mixer (all waves & noise) / extra lfo and attenuators on all cv inputs.
here's a pic of the box (to be painted satin black) , panel has been drilled but needs the sticker lanced for the pots & switches & sockets.
Filesize:
143.05 KB
Viewed:
592 Time(s)
Last edited by Skrog Productions on Sat Mar 06, 2010 12:42 pm; edited 2 times in total
Posted: Wed Jan 27, 2010 5:52 am Post subject:
WOW Skrog that looks amazing !!!!
i wish i new how to add sub osc's and extra lfo and extra envelope.
i wish u the best with the upcomming project, good luck and dont forget to update!!!
Joined: Nov 07, 2009 Posts: 30 Location: Snowy Mountions, Australia
Posted: Wed Jan 27, 2010 4:14 pm Post subject:
Look's Brilliant, I really dig wooden case's!
like Isak said "i wish i new how to add sub osc's and extra lfo and extra envelope" is there some way you could enlighten us?
Also are you going to use a power supply?
Isak.
Hey thanks Isak, just finished the build, i'm going to post the details shortly.
Nice Work!
Thanks mtec , case is now drenched in black satin paint .
No internal power supply +9V / 0V / -9V comes in from a big external unit i built that feeds the modular system / Soundlab + + / future expansion of the modular .
Soundlab + + finished, hurray, my wiring enthusiasm levels are low now but it's going to be a worthy addition to the diy collection.
From Soundlab + to Soundlab + +......
Cloned the PWM section of the soundlab vco 2 to give vco 1 PWM & pulse out.
Built a simple 8 Channel audio mixer (from ray's odd's & end's section). Mixer level pots for vco1 ramp / vco1 pulse / vco1 sub.
Mixer level pots for vco2 ramp / vco2 pulse / vco2 sub.
Mixer level pots for Noise & Ring mod.
Cloned LFO on Soundlab schematic to give LFO2.
Built on perf board 2 of Roman Sowa's Frequency dividers using just the divide by 2 & divide by 4 (switchable on/off mixed with divide by2).
populated Mfos micro S&H.
Built the simple Ring mod from Mfos site , the analog devices AD633, and 2 simple pre-amps to boost the soundlab ramps for its 10V p/p inputs.
Attenuators on every cv input, 4 per vco , 3 on the vcf , 2 on the vca, allowing to dial in very small modulations to give bass sounds as thick as a recently over fed anaconda
Here's some pics , sounds to follow later on.
Thanks for looking.
Filesize:
74 KB
Viewed:
542 Time(s)
Filesize:
118.4 KB
Viewed:
510 Time(s)
Filesize:
103.43 KB
Viewed:
524 Time(s)
recorded just the soundlab on it's own, no reverb or fx just the synth.
Who needs 'synths' like that !!!.mp3
classic electro pop melody played via midi 2 cv to the Soundlab starts with 2 ramps & 2 pulses then 2 sub osc's come in (div./2) then switch div./4 in before the verse
Filesize:
1.04 MB
Viewed:
1885 Time(s)
Mfos 16 stp sequencer running Soundlab.mp3
MFOS 16 step sequencer gate & cv controlling the soundlab while i fool around with the dials
