new in 'town'! some Qs!
Page 1 of 1 [2 Posts]
Varoudis
PostPosted: Wed Dec 23, 2009 6:07 am    Post subject: new in 'town'! some Qs! Reply with quote  Mark this post and the followings unread
Hello,
Im preparing myself to start slowly with the new year by building my first modular synth.
I think I have done a lot of reading (from the net, I havent found some book at the moment) and I thing the best way to start is by building Yusynth modules.
I will try to do as much DIY work as possible because Im low on cash (phd student...) but I have seen alot of site selling pcbs or giving away the design.
Questions: ( some info in my question might be WRONG!! correct me Smile )
1) Yusynth uses 210mm modules and 1/4' jacks but I have seen a lot DIY modules using 3.5mm jacks and sorter modules (in height). Because Ill do the panels myself with plex-glass and a lazer cutter can I make them smaller and use 3.5 jacks? Do you thing the Pots and the other panel components will fit?
2) I dont thing I have found a good DIY case and Power unit. Can you help me out with a link?
3) Comment or links with things that a total newbie has to see?
thnx
Tasos
yusynth
PostPosted: Sat Jan 02, 2010 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Tasos
I designed them this way because I like the 5U format and big jacks but there is no reason not going for a smaller standard. And if you like the 3U format this is no problem in general to use the yusynth PCBs.
Some people have built yusynth modules and integrated them behind 3U panels without problem, you can see some examples in the gallery section of each module.
Yves
