Obzenity
Posted: Thu Dec 10, 2009 3:01 pm Post subject:
Flimsy Knobs? |
| I've had my A6 for a short while now and while I love the sound, I have to say the knobs range from being sturdy to really flimsy and "wobbly". Is this normal for the A6? What are your units like? |
soundwave106
Joined: Nov 24, 2004 Posts: 331 Location: Elmo's Mud Wrestling Club
Posted: Thu Dec 10, 2009 5:49 pm Post subject:
| No problems with mine here... |
wildbill
Posted: Thu Dec 10, 2009 10:31 pm Post subject:
They're not 'rock solid', but they're not 'sloppy loose' either.
A little bit of wobble, but not enough to make me overly concerned I'd say. |
pinealapoptosis
Joined: Nov 07, 2008 Posts: 104 Location: Southeast US
Posted: Fri Dec 11, 2009 1:34 am Post subject:
My andromeda is the same as wildbill.Some of the knobs a re little more "loose" feeling than the others and have a little bit of play,but nothing to substantial. _________________ The Gnomes have learned a new way to say Hooray |
sunny pedaal
Joined: Nov 16, 2004 Posts: 735 Location: netherlands
Audio files: 12
Posted: Fri Dec 11, 2009 1:54 am Post subject:
| voyagers are better, never bother much with the a6's knobs though |
Numina
pinealapoptosis
Posted: Tue Dec 15, 2009 10:28 pm Post subject:
Well I wouldnt use the words flimsy or wobble to describe how my knobs feels.Its just that some of them seem to have a bit of "play" in them.The OSC semitone knobs dont wiggle or move at all but the smaller knobs like the cents and fine knobs are little bit more "loose".You can grab them and sort of wiggle them side to side.Not a lot of movement but it is noticeable compared to say,my master volume knob or the filter frequency and semitone knobs,which are completely stiff.
The first andromeda I had(which I returned for a stupid reason) also had the same trait.
I was so paranoid right after I bought the andromeda that sent it back and exchanged for a different one because I thought something was wrong with it.Now I actually have a real problem with mine and I kinda wish I had kept the first one because in reality it probably had nothing wrong with it.
As soon as the second one got here I had to take it apart and adjust the mod wheel because it wouldnt stay in place at all.It slowly roll to the completely off position or if it was more towards on it would roll completely on.There was no middle.All it took was a bit of adjusting though and now it stays in place well. _________________ The Gnomes have learned a new way to say Hooray |
Numina
Posted: Wed Dec 16, 2009 11:37 am Post subject:
What you're describing sounds normal. Some knobs on mine are slightly less 'solid-feeling' and have a little play in them than others. Nothing terribly concerning though. _________________ -------------------------------
www.numinamusic.com
https://www.facebook.com/Numinamusic
pinealapoptosis
Posted: Wed Dec 16, 2009 1:33 pm Post subject:
Ah ha, that is what I thought!  _________________ The Gnomes have learned a new way to say Hooray |
kpatz
Posted: Sun Dec 20, 2009 7:13 pm Post subject:
I think this is normal. The knobs have different sizes/types, and possibly makes of potentiometers underneath them, so they will each have a different "feel". Some will be stiffer than others. Some of the knobs may have 2-gang pots which tend to be a bit stiffer than single-gang pots.
I would think multiples of the same function knob (e.g. filter 1 cutoff vs. filter 2 cutoff) would have the same feel. |
Tim Kleinert
G2 patch files: 236
Posted: Mon Dec 28, 2009 10:48 am Post subject:
The pot shafts aren't screwed to the front panel, that's why they wobble a bit. That's normal and nothing to worry about. Securing 72 pots (!) to the panel would have increased the manufacturing price considerably, as it has to be done by manual labor. Also, in case of having to replace a pot (or a button), it would be alot more hassle first having to unscrew all the remainig pots in order to remove the panel board. So it's a reasonable compromise.
Just be careful (and use a dust cover too). |
Shreddie
Posted: Wed Dec 30, 2009 7:22 pm Post subject:
I'm terribly sorry but this thread has had me in stitches... All you lot talking the stiffness, sizes, types and wobbliness of your knobs!  |
