Coming up on Radio 1 at
Resistor Values
Page 1 of 1 [4 Posts]
Ali M
PostPosted: Sun Sep 27, 2009 8:31 am    Post subject: Resistor Values Reply with quote  Mark this post and the followings unread
Hi there,
On some modules parts lists, there is no 1% or 5% does that mean they are just 5%?
And what wattage resistors should I use? or does it not matter?
Would it be worth getting better quality 1% resistors for the VCO module? Would this really improve the tracking?
thanks
yusynth
PostPosted: Mon Sep 28, 2009 2:40 am    Post subject: Reply with quote  Mark this post and the followings unread
In yusynth modules the default tolerance is 5% 1/4W unless specified otherwise. When 1% resistor are needed it is indicated on the schemo and the BOM.
In the VCO, only those resistors labelled 1% need to be 1%. Anyway you may use 1% resistors everywhere this won't impair the performance of the circuits.
Yves
Ali M
PostPosted: Mon Sep 28, 2009 3:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Would using 1% resistors where not needed increase performance?
yusynth
PostPosted: Mon Sep 28, 2009 4:56 am    Post subject: Reply with quote  Mark this post and the followings unread
No it would not, the sensitive parts are those already specified 1%
Yves
