Scott Stites/Buchla 291 adaptation
Page 6 of 8 [199 Posts]
Luka
PostPosted: Mon Aug 03, 2009 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Posted Image
far left module
(its a dual 291)
problemchild
melbourne australia
Scott Stites
Audio files: 97
PostPosted: Mon Aug 03, 2009 7:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Luka and Photon,
Those are both really nice looking modules!
Cheerios,
Scott
My Site
adambee7
PostPosted: Mon Aug 03, 2009 9:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice system you have there. Very Happy Very Happy
Photon
PostPosted: Tue Aug 04, 2009 5:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Luka--nice looking panels. Very Happy Did you wind up etching them?
Thanks Scott. I appreciate you sharing your tap points and input mixer. cheers!
Here are a couple more pics:
Posted Image
Posted Image
Luka
PostPosted: Tue Aug 04, 2009 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
no i got a bit tired of using pnp, it really wasnt being reliable enough
so i started using lazertran
so much better imo
tho i might start etching more when ive finished my synth
problemchild
melbourne australia
ericcoleridge
PostPosted: Sun Aug 09, 2009 11:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
99% done with my 291. This is the original Verbos dual layout. I need to re-wire it, it's a rats nest right now... but I was anxious to get it up and running:
 Filesize:  1.52 MB
 Viewed:  651 Time(s)
 Filesize:  1.34 MB
 Viewed:  803 Time(s)
numbertalk
PostPosted: Mon Aug 10, 2009 5:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks great!
frenchyinmunich
PostPosted: Sat Sep 05, 2009 8:58 am    Post subject: Mark verbos 291 clone component list Reply with quote  Mark this post and the followings unread
Hello,
Somebody here knows where I could find a component list of the Mark Verbos PCB 291 clone?
Regards,
F
Luka
PostPosted: Sat Sep 05, 2009 6:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
i think it is somethign like this
this is for a single filter so double everything
1r / FB 2
47k 2
62k 1
1.5k 4
15k 2
68r 1
1m 1
100k 1
10k 4
4m7 1
6k8 4
68k 1
1k 3
220r 1
2m2 1
10m 2
100k trim 1
5k trim 1
5k6 1
33k 2
4k7 2
470r 1
100uf 50v 2
10uf 50 1
470p 1
220p 1
901p 1
47p 1
22p 1
22n 2
470n 1
tl082 1
tl084 1
5534 1
vtl5c3 4
2n3566 2
1n4148 1
1n5228 1
problemchild
melbourne australia
frenchyinmunich
PostPosted: Sun Sep 06, 2009 4:21 am    Post subject: Merci Reply with quote  Mark this post and the followings unread
Perfect!!
Thank you very much!
F
frenchyinmunich
PostPosted: Sun Sep 06, 2009 10:35 am    Post subject: 1r fb2 Reply with quote  Mark this post and the followings unread
Thanks again for the list.
But, what means the 1r FB2?
Thanks,
f
frenchyinmunich
PostPosted: Sun Sep 06, 2009 10:55 am    Post subject: 291 component list Reply with quote  Mark this post and the followings unread
Again... The 910 pf...
Seems there's a problem...
Scott Stites
Audio files: 97
PostPosted: Sun Sep 06, 2009 12:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
A 1000 pF (1 nF) will do you just fine.
Cheerios,
Scott
My Site
KrIVIUM2323
PostPosted: Mon Sep 07, 2009 4:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
1 ohm resistor or a ferrite Bead. You can use either resistor or ferrite bead type (two needed )(ferrite bead allow better filtering if you have 'noisy' modules on the same supply).
Scott Stites
Audio files: 97
PostPosted: Mon Sep 14, 2009 6:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Super Yikes! I was just asked a question about the input mixer, and was shown that section of the schematic I'd uploaded - long story short, U4A and U4B (input mixer) was put into the schematic upside down! I found the schematic I drew (dated 2006) and corrected that part.
Many apologies to anyone who may have been led down that path....
Embarassed Embarassed Embarassed Embarassed
Here's the corrected version. Thanks, Photon.
Cheerios,
Scott
Corrected input mixer drawing.
 Filesize:  801.03 KB
 Viewed:  1180 Time(s)
My Site
Luka
PostPosted: Mon Sep 14, 2009 6:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
oh i thought i pointed that out awhile ago
to anyone with my pcb version this correction was made
problemchild
melbourne australia
Scott Stites
Audio files: 97
PostPosted: Mon Sep 14, 2009 6:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm sure you did and I missed that part of the thread (I drift in and out of consciousness now and then); I'm glad it didn't zap you in any case.
My Site
LetterBeacon
PostPosted: Fri Dec 18, 2009 4:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
To Luka and Photon:
I just want to confirm that Luka's PCB layout works as in, with no modifications needed?
Luka
PostPosted: Fri Dec 18, 2009 5:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
my layout needs a couple of kludges in the mod section unfortunately but the core section works
problemchild
melbourne australia
numbernone
PostPosted: Sat Dec 19, 2009 11:04 am    Post subject: Reply with quote  Mark this post and the followings unread
My 2 291s, which were built about a year apart behave completely different from one another. The first is quite tame and nice, while the second is a wicked beast that just loves to overload and distort in the worst/best fashion. Gonna be building the last one in 2010, and hope that I can dial it in to be very much on the money with Buchla, then I will have 3 kick ass filters from the same design.
It looks like by the end of next year there will be a lot more Buchla cloning than anyone previously imagined possible. Cant wait.
Luka
PostPosted: Sun Dec 20, 2009 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
same here
one is really aggressive the other is a bit more timid, i might change the vactrols the timid one
LetterBeacon i might be etching some more 291s next year so ill change the layout a little to fix the kludges and change the mods a little. i didnt use the processor, instead i set up opamp to buffer and mix the filters to run in parallel model, perhaps making a vero board arrangement might be more handy
problemchild
melbourne australia
LetterBeacon
PostPosted: Sun Dec 20, 2009 3:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Excellent, I'll hold off etching the current PCB for a bit then.
thermionicjunky
PostPosted: Mon Dec 21, 2009 11:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I also built a dual filter using Luka's layout. I'm pretty new to DIY and the project, including the kludge in the output buffer, was pretty easy. I love this filter. My filters behave quite similarly, with maybe a bit of difference in the gain trimmer settings. With the LP and HP taps, this is my ideal multimode. I knew that I wanted a vactrol-heavy modular, but now my appetite is insatiable. I want to build the Music Easel balanced modulator and I'm still hoping that someone will do a layout of a properly functioning vactrol panner.
Thanks to Luka, Scott, Mark and Don for the 291!
LetterBeacon
PostPosted: Mon Dec 21, 2009 12:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thats interesting to know. Are the kludges needed documented anywhere?
thermionicjunky
PostPosted: Mon Dec 21, 2009 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Luka sent out a diagram to the people using his boards. I believe that it was a simple matter of swapping pins 2 and 3 on the buffer IC. I suppose that you might as well wait for the layout to be redrawn, but it's not a big deal to correct it yourself if you can't wait.
