CMOS Theremin
Page 1 of 1 [4 Posts]
droffset
PostPosted: Tue Jul 14, 2009 7:33 pm    Post subject: CMOS Theremin
Subject description: CMOS Theremin
SURELY this must be in the Lunetta spirit? Laughing I'm so building one.
http://home.att.net/~theremin1/101/101.html
hexagon5un
PostPosted: Thu Aug 20, 2009 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Even more in the CMOS/Lunetta style:
I made an more minimal version of Art's design with a 74HCU04 for the oscillators fed straight into a 74HC86 XOR for the "ring modulation".
Copy his two oscillators (U1A and U1B, U2A and U2B) onto a single chip. The U in 74HCU04 is important -- I had trouble with oscillators syncing with each other when I used 74HC04's. Then just run the outs of those two oscillators straight into the XOR chip.
And because I'm really minimal, for output I just put a 100uF cap on the XOR out, to a speaker, and to ground.
For an antenna, I just use an alligator clip and a foot-square piece of aluminum foil, because then the whole shebang fits in your pocket.
I run it on a rechargeable 3.6v cell phone battery most of the time and I find it helps the range a lot to couple myself to the circuit's ground wire because the battery is not earth-grounded. So I pulled out the ground line to a patch of aluminum foil that I can contact with my fingers. Since this radically changes the frequency of the variable oscillator, you can use it as a simple playable gate for the sound.
I've attached my notes. I'm actually running a small workshop building these tonight at my local hackerspace. (www.hacdc.org).
 Filesize:  82.1 KB
 Viewed:  682 Time(s)
droffset
PostPosted: Thu Aug 20, 2009 6:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great idea, would make a fun evening project, cheers!
Edit: Spelling mistakes.
hexagon5un
PostPosted: Sat Aug 22, 2009 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Made this sketch for the class. You'll also need power and ground lines, and possibly a decoupling cap (10u?) across them. I located mine physically between the chips.
Enjoy.
 Filesize:  79.83 KB
 Viewed:  683 Time(s)
