Coming up on Radio 1 at
 Forum index » Instruments and Equipment » Strings and things
Even Harmonic GTAK1
Post new topic   Reply to topic Moderators: BobTheDog
Page 1 of 1 [12 Posts]
BobTheDog
Audio files: 32
PostPosted: Thu Jun 25, 2009 11:18 pm    Post subject: Even Harmonic GTAK1
Subject description: Got a midi guitar and NI Kontakt 3? May be worth a look if so.
Hi Guys,
Interesting little thing at http://evenharmonic.com/products/gtak
Basically a KSP script that makes controlling Kontakt 3 from a midi guitar less of a pain.
I am going to look at the demo and see what it is like.
Andy
BobTheDog
Audio files: 32
PostPosted: Fri Jun 26, 2009 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
This is an excellent little thing, if you have Kontakt 3 and use midi guitar it is well worth the cash.
Apart from simplifying the whole process and reducing cpu by using a single instrument rather than 6 is also offers the following:
Allows you as many fret splits as you want
Allows you as many string splits and combinations as you want.
Allows you to use pick position if you have an axon to select instruments.
Its all very easy to use and comes with the full Kontact 3 library instruments changed to work properly with it.
Excellent value for money.
Andy
ReaktorFreak
PostPosted: Tue Jun 30, 2009 3:12 am    Post subject: Reply with quote  Mark this post and the followings unread
But can't we write the script ourselves ? Or is it too complicated ?
BobTheDog
Audio files: 32
PostPosted: Tue Jun 30, 2009 3:49 am    Post subject: Reply with quote  Mark this post and the followings unread
I think you pay the money to avoid having to write the script and change every instrument in the library.
ReaktorFreak
PostPosted: Wed Jul 01, 2009 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
That's very worth the money then ! Yeah, in Reaktor to implement MIDI guitar mode every ensemble needs to be modded..
BobTheDog
Audio files: 32
PostPosted: Wed Jul 01, 2009 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Did you see the thing I posted in the Reaktor Library about midi guitar and changing ensembles?
ReaktorFreak
PostPosted: Thu Jul 02, 2009 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Of course, MGC right ? Yeah, i see that the Acoustring has to be modded to be compatible with MIDI Guitar mode..
ReaktorFreak
PostPosted: Sun Jul 05, 2009 9:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Have you try converting the 6 pitchbend data stream to poly aftertouch ? If it's successful you could have pitchbend data for each voice independently. Although i have no idea how to use the poly aftertouch module Smile
BobTheDog
Audio files: 32
PostPosted: Mon Jul 06, 2009 12:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
MGC has got individual pitch-bend for each voice or am I misunderstanding you?
Andu
ReaktorFreak
PostPosted: Tue Jul 07, 2009 4:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, i mean for transmitting to external MIDI devices that supports poly aftertouch, but doesn't have MIDI guitar mode, probably this can be a workaround. Theoretically, the aftertouch containing pitchbend data is polyphonic, so it can be transmitted to the receiving device on one channel, along with Note Ons. Then maybe it can be setup somehow so each note from each string corresponds to the relevant poly aftertouch data that contains the pitchbend data from the relevant string. Then, hopefully the device can interpret poly aftertouch as a pitchbend (like in my Korg X5, mod wheel can be used as one-way pitchbend controller).
What makes me came with this idea is because poly aftertouch seems like the only polyphonic MIDI message type besides Note On/Off, as CC and pitchbend are both mono / global.
But anyway, maybe this isn't possible at all, i don't know..
BobTheDog
Audio files: 32
PostPosted: Tue Jul 14, 2009 10:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah I see.
So you would need something that could receive the 6 channels and send to one channel. For each channel you would take the last note on message and convert the current pitchbend to poly aftertouch on that note.
The only problem I see is that the guitar can produce the same midi note more than once if it is played on different strings, as each string would have a different pitchbend value we are then in trouble as there is a one to one relation between the note number and the polyphonic aftertouch data.
ReaktorFreak
PostPosted: Tue Jul 14, 2009 11:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, so the 6 channel can be merged perfectly into one, without discarding each channel pitchbend, like the known way. And just recently i've read a discussion about sending micro tuning scale information through poly aftertouch, so i figure maybe it can also be used for merging individual bend data. But like you said, it's hard to relate the pitchbend as aftertouch value for each note correctly, so it might ended up unrelated at all.
