Coming up on Radio 1 at
4069 Envelope Follower
Page 1 of 1 [7 Posts]
synthmonger
PostPosted: Sun Feb 22, 2009 11:14 am    Post subject: 4069 Envelope Follower
Subject description: works well!
You all might find this useful. I tested it out and it works well. You can get a reverse sweep by running one more gate at the end.
http://experimentalistsanonymous.com/diy/Schematics/ADSR%20Generators%20and%20Envelope%20Generators/CMOS%20Envelope%20Follower.bmp
RF
Audio files: 28
PostPosted: Sun Feb 22, 2009 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for posting that synthmonger - looks interesting.
www.sdiy.org/rfeng
bingmachine
PostPosted: Sun Feb 22, 2009 2:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
And what is the expected input signal peak-to-peak for this to work well?
/Erik
synthmonger
PostPosted: Sun Feb 22, 2009 5:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Haven't checked. I used a guitar and casio VL-1 which worked.
bingmachine
PostPosted: Mon Feb 23, 2009 4:17 am    Post subject: Reply with quote  Mark this post and the followings unread
That's all I need to know. Sounds great! Thanks!
All we need now is that single supply version of the Wasp-filter. Wink
/Erik Forsling
DGTom
PostPosted: Sun Jun 21, 2009 5:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I breadboarded this yesterday, & it works pretty nice, I didn't have (nor did the local supplier) any 2M2, so after gettting it up & running with 2 x 1M + 200K I replaced the 2M2 w/ a 1M pot, played a little bit with adding resistors to the pot (1M, 200K - even tried a 4M7!) but just the pot alone seemed to work best.
I am getting quite alot of voltage on the output with no input - guessing that is normal, I have a diode on the input as well, just in case, what I wonder is could you put an op-amp on the in or out to clean it up a little? I quite like the basic way the cct. works, you can hear the cap discharging in a nice bubbly way & the pot gives quite good control, from zero following to overlapping, not getting every peak smoothed out following.
Might just put a pot as a voltage divider on the output again so you can adjust the output.
Any tips or ideas from anyone else who played around with this cct. would be great Very Happy
synthmonger
PostPosted: Sun Jun 21, 2009 7:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you're getting a constant voltage on the output try adding a 100k resistor tied to ground on the input.
Youtube!
modular demos!
Whacky tunes!
